Solving this limit without a calculator
In summary: Imagine that x is on the x-axis and the function f(x) is on the y-axis. The left-hand limit is at the point where the y-axis touches the x-axis and the right-hand limit is at the point where the y-axis crosses the x-axis. Since the left-hand limit does not equal the right-hand limit, the limit at a does not exist.
Shay10825
338
Is there anyway to do this without calculatior and without graphing it?
lim (x-3)/(x-2)
x->2+
Yes. Think of it this way: in the denominator, you are subtracting 2 from a value just barely larger than 2; what does that equal? You should be able to figure it out from there.
I know the answer is neg inf. But how do you know if the answer is inf, a number or if it does not exist? Like for the problem:
lim (x^2)/(x^2+16)
x->4-
The answer is .8 but how would I know this without a calc and without graphing it?
Would taking the derivative help? I heard that taking the derivative could help in some cases. Is this true?
lim (x-3)/(x-2)
x->2+
in this case, the denominator approaches 0 while the numerator approaches 1. What happens to a fraction when it’s denominator gets small?
Try comparing 1/10, 1/1, 1/.1, and 1/.00000001. If it’s denominator was infinitely close to 0 it would approach infinity no mater what finite value it’s numerator is.
lim (x^2)/(x^2+16)
x->4-
would be 1/2.
How do you know this is continuous without graphing it and without a calculator?
lim (x^2)/(x^2+16)
x->4-
How do you know this is not continuous without graphing it and without a calculator? Do all functions that are not continuous have a lim of inf or neg inf?
lim (x-3)/(x-2)
x->2+
First you need to define continuity before you can ask what is continuous.
A continuous function satisfies the following:
lim f(x) = f(a)
x->a
Get it? A function is continuous when a is in its domain. The domain is defined as what you can "put in" the function.
Here is the function box:
DOMAIN -> F -> RANGE
F spits out Range. For every number in the domain, the number should come out as the functions range. What is the functions range?
Let's look at x^2. You can put any number in there. Thus, the Domain is the set of Real Numbers, which is any number. Can you get a negative from x^2? No, you cannot. Thus, the Range would be [0,infinity).
For the question:
lim(x-3)/(x-2)
x->2+
Is it defined when x=2? No, it is not. Is it defined for every other number? Yes, it is. Therefore, the Domain is (-infinity,2)U(2,infinity). In other words, the function is continuous everywhere, but not at x=2.
For that question, I believe you can only solve it numerically. In other words, with a calculator by taking values very close to 2. i.e. 2.0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001 :) This way you know for sure it is right!
I'm kidding there. Something like 2.0001 should be sufficient.
JonF said:
lim (x-3)/(x-2)
x->2+
Is JonF saying that whenever the denominator approaches 0, the limit would be infinity?
Yes, he is.
lim1/x=infinity
x->0
Try 1/0.001 and then 1/0.000001.
The numbers get ... bigger ... and bigger.
Note:
Infinity is not a number.
In general, if the limit of the numerator is not 0 but the limit of the denominator is 0, then the limit is "infinity". I put that in quotes because, as JasonRox said, infinity is not a number. That's really just a way of saying that that the limit does not exist (in a particular way).
For that reason alone, here is the guideline to whether or not a limit exists.
The limit must be a finite number.
What if the limit of the numerator is 0 then what?
If the denominator is not zero, then it equals zero.
Think about it.
As x approaches 0 for x/5, it gets closer and closer to 0. Therefore, the limit is zero. It does exist since 0 is a finite number.
If it looks something like this x/x and x approaches 0, then it equals to 1.
NOTE: It is very important to note that it is not 0/0 equals 1 because x never equals to 0, but only approaches zero. Therefore, 0.0001/0.0001 = 1.
Well when does a limit not exist (when is it not inf and the answer is does not exist)? Would every limit be a number or inf? Also how do you know if a limit is pos inf or neg inf?
What does "inf" mean?
A limit exists when it is defined as a finite number.
Also, for the limit as x approaches a for the function f(x). The left-hand limit must equal the right-hand limit.
If you get 5 coming from the left of a, and 8 coming from the right, you can not conclude that the limit at a is b (b is constant - finite number). Why? Because 5 and 8 do not equal. You can't choose one or the other. In this case, you say it does not exist and explain why. You need to show that the left-hand and right-hand limit do not equal.
Look at the graph below.
--------o...
It's kind of lame, but it will give you an idea. Ignore the dots. Know when approaching from the left the value is b, but approaching from the right it equals b-1. They do not equal.
Look at this graph.
-------o--------
Even though it is not defined at a (or o), we know the limit is b.
Can you tell me why that is?
inf means infinity
Because it approaches the same number from each side?
Why is the answer the limit does not exist? How would I know this without a calculator and without graphing them?
lim 1+ (1/x)
x->0-
and
lim 2/sinx
x->0+
For the first one, it should be negative infinity.
I explained earlier why that is.
In other words...
lim 1/x
x->0
...does not exist. First of all, the left and right don't equal. One is positive infinity and the other is negative infinity. Second of all, infinity is not finite so it doesn't exist.
Note: Just because it doesn't exist does not mean we must ignore that it equals infinity. The fact that it equals infinity tells us how the graph may look like and how the function behaves when x approaches 0.
For the second limit, take a wild guess.
Hint: It is VERY similar to the first.
But I don't understand how you would know the behavior of the graph without graphing it and using a calculator. How do you know the left and right don't equal without a graph or calculator?
By direct substitution, theorems, and definitions.
For x approaches 0, 1/x equals infinity.
We can't necessarily do that by hand since it isn't a finite number. It is a definition given in textbooks that it equals infinity.
I understand now. Thanks for your help :smile:
No problem.
Learn to love limits. :)
1. How do I solve a limit without using a calculator?
To solve a limit without a calculator, you can use algebraic or graphical methods. Algebraic methods involve simplifying the expression algebraically, while graphical methods involve estimating the limit using a graph.
2. What is the purpose of solving a limit without a calculator?
Solving a limit without a calculator helps develop a deeper understanding of the concept of a limit and allows for a more precise and accurate answer compared to using a calculator. It also helps to strengthen algebraic skills and problem-solving abilities.
3. Can all limits be solved without a calculator?
Not all limits can be solved without a calculator. Some limits may require more advanced techniques such as L'Hopital's rule or Taylor series. However, most limits encountered in basic calculus courses can be solved without a calculator.
4. What are some common mistakes when solving a limit without a calculator?
Some common mistakes when solving a limit without a calculator include forgetting to check the continuity of the function, not simplifying the expression fully, and not considering the behavior of the function near the limit point.
5. Are there any tips for solving limits without a calculator?
Yes, some tips for solving limits without a calculator include identifying and using known limits, factoring the expression, and using algebraic manipulation to simplify the expression. It is also important to carefully analyze the behavior of the function near the limit point.
