Some Derivatives Questions
  1. Jun 20, 2011 #1
    Let f(x) = axe^((bx)^2). Find the value for a times b if it's known that there's a max value of 2 at x = 3.
    Second, There is one line which is tangent to the curve y = 1/x, at some point A and at the same time tangent to the curve x^2 at some point B. What is the distance between
    A and B?
    2. Relevant equations
    For the first I realize that I have f'(3) = 0 and (I think) f(3) = 2.
    Second, I think I can set the derivatives equal to each other and solve for x.
    3. The attempt at a solution
    I can then use these equations to solve for a and b, however I guess this is more an algebra problem because I seem unable to do so. I also need verification that that second equation makes sense. If it does, I think I'll be more able to do this question because I can solve for b in a way I couldn't with the first equation (if I took ln of both sides ln0 would be undefined and it wouldn't make sense, I think).
    Second, when I tried to solve for x I ended up with x = 1/2 which lead me to a solution eventually, by the distance formula, of 9/16 + 1/16 which is not correct based on the test answers.
    Any help would be appreciated here, thanks guys!
  3. Jun 20, 2011 #2
    lanedance
    how about showing your algebra?
    [tex] f(x) = axe^{(bx)^2} [/tex]
    [tex] f(3) = 2 = a3e^{(b3)^2} = 27ae^{b^2} [/tex]
    now how about the dervative?
  4. Jun 20, 2011 #3
    lanedance
    for the 2nd the tangents will be parallel, but it states a single line will also pass through both points, so you've got a little more info than just the tangent direction. you can describe the line by a gradient (tangent direction) and an intercept
  5. Jun 20, 2011 #4
    lanedance
    note or 1 that you'll need to apply the chain rule (and product rule)
    [tex]\frac{d}{dx}g(f(x)) = g'(f(x))f'(x) [/tex]
    then i think the exponential part should cancel
  6. Jun 20, 2011 #5
    I'm sorry about taking so long to respond to my own thread, I really appreciate the help but some things came up around here that I had to take care of.
    f(3) = 2 = a3e^{(b3)^2} = 27ae^{b^2} - I don't even quite know why this is true.
    The problem I have with the derivative is that I'll get f'(3) = 0 = a(e^b3^2) + a3(e^b3^2)(6b) = (a + a3)(e^b3^2) = a4(e^b3^2), which I don't know how to solve further because anything I put on the other side will end up being zero. Should I have instead put that a(e^b3^2) = -(a3(e^b3^2)(6b)) or?
  7. Jun 20, 2011 #6
    lanedance
    your conclusions here are correct
  8. Jun 20, 2011 #7
    lanedance
    not too sure what you're doing here , but you have 2 equations and 2 constants so can solve, assuming there is a solution
    f(3) = 2 = 3ae^{(b3)^2}
    f'(3) = 0 = a(e^b3^2) + a3(e^b3^2)(6b) = (e^b3^2)(a+3a6b)
    clearly form the first, a is non-zero
    2/(3a) = e^{(b3)^2}
    substitute this into the 2nd
