Some Particular Forces
  • Thread starter mike_24
A block with a weight of 3.0N is at rest on a horizontal surface. A 1.0N upward force is being applied to the block by means of an attached vertical string. What are the magnitude and the direction of the force of the block on the horizontal surface? I was wondering what it meant by the attached vertical string, is the string attached to the top of the block and then to a ceiling?
Answers and Replies
radou
3,120
Yes, that makes sense.
This seems like a very easy problem, if I'm approaching it properly. You would have your 3.0N down as your mg and the T would be 1.0N up. Would that mean that the megnitude would be 2.0N downward as a final answer?
Newtons to Pounds
I was just wondering how you convert newtons to pounds
If any one knows this it would be muchly appreciated
Thanks
radou
3,120
Yes, that is the correct answer.
Sadly, I can't help about the conversion question, but I'm 100% sure that you could google-up an answer in any time.
Related Threads on Some Particular Forces
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
30K
