Calculating Power Output of Rotating Object with Mass M, Radius R, and Speed V
In summary, an object with a mass of 60 kg and a radius of 5 meters can generate 3000 watt of electrical power.
Hanababa
An object with a mass M is rotating around an axis, with an arm of radius R at a certain speed V.
Assuming that the movement is constant, and a 100% efficiency, how many watt of electrical power can this device generate ?
For example purpose, we can take M=60 kg, R=5 meters and V=10 meters per second.
I can't find all the formulas and am lost with the units.
Thanks a lot
Maybe the first thing could be to figure out the rotational energy of the device. First you need the moment of inertia, which you need to do with the mass, the radius and the Huygens-Steiner theorem (also known as Parallel Axis theorem).
Once you figured that out (I leave it to you to find the formulas with this hints, I just found that you should be able to do that), you can calculate the angular velocity, this time you need the given radius and the given velocity. Insert into the formula for [tex]E_{rot}[/tex], calculate it and then we can talk again :).
Huygens-Steiner theorem:
I parallele(moment of inertia) = I(cm) + MR²
Then, K (the rotational energy) is
K = 1/2 * I parallele * V²
So, K = 1/2 * (Icm + MR²) * V²
So remaining questions are:
1. how do you get Icm ?
2. As an energy K should be in Joule, which is a watt.second. I need a result is watt only.
If Icm is indeed equal to 0, we would then have
K = 1/2 * 60 * 5² * 10²
K = 75000 Joule ??
Thank you Lunar Lander
K = 75000 Joule ??
You are on the right track, but you miss that you can't use v directly. You have to use the angular velocity, which is [tex]\omega=\frac{v}{r}[/tex].
In this case here you have this mass rotating around an axis at the distance r=5 m. For this case (a mass rotating around an axis), the HS-theorem reduces to [tex]I=M \cdot R^{2}[/tex].
Right,
so K = 1/2 * M * R² * (w)² with w = V/R
K = 1/2 * M * R² * (V/R)²
K = 1/2 * 60 * 5² * (10/5)²
K = 3000 Joule ??
It must be wrong because on the above formula, we see that the R² are cancelling themselves, which would mean that R is not relevant, cannot be. Sorry, I am a bit lost..
Your value is correct, as the unit of omega is sec-1. Thus there are no R2 which cancel each other.
So you now arrived at the energy. The equation for getting the power of an electric generator is Pel=Pmech-Ploss. The last one is zero, as you gave 100% efficiency. The electrical power thus should be equal to the power required to spin up the mass. However, there normally should be a time given, as the power is equal to the energy pro unit time. I think someone else needs to pick up here...
But you are welcome Hanababa! :)
Thanks again,
does it mean that if the device is operating for 1 year, so the value W in watt would be
K = W * 365*24*3600
K = W * 31536000
So, about 31,5 Megawatt of electrical production per year ?
1. How do I calculate the power output of a rotating object?
To calculate the power output of a rotating object, you need to use the formula P = 2πMVR, where P is the power output, M is the mass of the object, V is the speed of rotation, and R is the radius of rotation.
2. What units should I use for the variables in the power output formula?
The units for power (P) are watts (W). The units for mass (M) can be kilograms (kg) or any other unit of mass. The units for speed (V) should be in meters per second (m/s). The units for radius (R) should be in meters (m).
3. Can I calculate the power output of a rotating object with other variables?
Yes, the formula for power output can also be written as P = ωMVR, where ω is the angular velocity of the object. You can also use this formula to calculate the power output if you have the angular velocity instead of the speed of rotation.
4. How does the mass and speed of rotation affect the power output of a rotating object?
The mass of the object affects the power output in a linear way, meaning that the higher the mass, the higher the power output. The speed of rotation, on the other hand, affects the power output in a quadratic way, meaning that the power output increases exponentially with an increase in speed.
5. Are there any other factors that can affect the power output of a rotating object?
Yes, the efficiency of the rotating mechanism can also affect the power output. A more efficient mechanism, such as one with lower friction, can result in a higher power output. The shape and design of the rotating object can also impact the power output. For example, a smooth and streamlined shape can result in less air resistance and therefore a higher power output.
