some bloke
- 278
- 96
- TL;DR Summary
- If there is a liquid medium which has an additional force exerted on it, how does this affect the buoyancy and positioning of a floating ball?
This is a thought experiment which I have had rattling around in my head for a while, and I think that it is too specific to find any answers for by google-fu alone, so I'm hoping someone here can help me to understand this!
I have a fair understanding of buoyancy. The medium in which an object sits is pulled downwards by gravity, as is the object. If the object is pulled less than the body of medium it displaces, then it floats upwards.
My next thought is the results of a non-uniform force being applied to the liquid, but which doesn't affect the object. Imagine, if you will, a liquid which can be pulled by magnetism, and a floating ping-pong ball. (I don't know if such a liquid exists, ferrofluid doesn't seem to remain fluid near magnets!).
The fluid is in a tub. The ball is floating in the centre. If I place a magnet directly below the ball, it will float higher, as the fluid is pulled down with more force than before. What if I place the magnet in the corner? The fluid will be pulled towards it, but the ball will not. Would it create a slope? would the ball roll down it? If the ball were held in place with a force-meter attached, which direction would the force act?
Now, what if there is just enough magnetic pull to cancel out the weight of the fluid, and the tub is inverted - will the ball float up, or fall down, when fully immersed in the fluid?
In microgravity, what happens to buoyancy? Does the ball sit on the outside of the floating sphere of fluid, or is it pulled into the centre by the surface tension? What if the fluid was encased in a sphere (to prevent it from moving), and a magnetic field turned on - I think the ball would float away from the magnetic pull, is this right?
Another question: If you put said sphere containing the liquid and the ball onto the arm of a centrifuge and span it up to, say 5G's, the ball would float inwards as the liquid is forced outwards. If you then had a magnetic field which pulled the liquid inwards which canceled the force from the centrifuge, what forces are being exerted on the ball at this point? Is there a way to make the ball float freely (IE neutral buoyancy) in the liquid, whilst it is still being spun at the equivalent of 5G? What sort of forces might a sensor inside said ball register (assuming it was immune to the magnetic fields effects)? would it be akin to free-falling inside a lift - where it feels weightless - or would the sensor continue to experience 5G's of acceleration from the centrifuge (which I suspect, as it is still being spun!)Thankyou for your time with this! I'm full of questions and can seldom find anything which helps me to understand, and have little resources with which to do experiments (if they are even possible)!
