Linear Dependence and Basis in Vector Spaces | Matrix Determinant Properties
  • Thread starter alexngo
In summary, when two vectors are parallel, they are linearly dependent. This is a theorem that is stated in your textbook or found online. Matrix multiplication does not affect the determinant of a matrix, unless a row operation sweeps the matrix to the identity. Row operations on an n x n matrix have no effect on the determinant.
alexngo
If two non-zero geometric vectors are parallel then they are linearly dependent.
For all n x n matrices A,B and C, we have (A - B)C = CA - CB
Let V be a vector space. If S is a set of linearly independent vectors in V such that S spans V,then S is a basis for V.
For all n x n matrices A and B, we have det (A + B) = det (A) + det (B)
If A is a matrix with det(A) = 0, then there are no solution to the equation Ax = b for any column vector b where b is not equal to 0
Row operations on an n x n matrix A have no effect on the determinant of A
For all n x n matrices A, we have det(A^t) = det(A)
What do you think?
1. For the first one, you could start by looking up the definition of "linearly dependent", for example.
2. matrix multiplication is associative.
3. What is a basis?
4. look up the properties of the determinant.
5. You can solve Ax = b by multiplying by the inverse of A from the left.
6 and 7: look into the properties of the determinant again.
1. When is a set of two vectors linearly dependent?
2. It is certainly true that (A - B)C = AC - BC, since matrix multiplication distributes. However, is it always true that AC - BC = CA - CB?
3. What is the definition of a basis?
4. You can easily construct a counterexample to show that this is false. (Use matrices that are almost all zero and the identity matrix.)
5. There's a solution if and only if a = A^{-1}b, which is true as long as A^{-1} exists. Does det(A) = 0 say anything about the existence of A^{-1}?
6. How does each of the following row operations affect the determinant of a matrix: (1.) Multiplying one row by a scalar multiple of another row, (2.) Interchanging two rows, (3.) Adding a scalar multiple of one row to another row?
7. This is almost trivial.
it seems as though you can solve all these yourself within 15 minutes probably! You certainly come across bright enough. Just look up the words for things you don't know the definition of, I'm sure they are listed in the register of your book or even wikipedia or google. Then if you don't understand, come back.
for 5, this is a theorem I'm sure your book states, otherwise think of when a matrix can be swept to the identity by row operations. Then use det(I) is not zero (you might want to use the result of 6 here though)
6, try one or two simple 2x2 or 3x3 matrices and I'm very sure you will have a suspicion about the determinant rules, which is easy to explain. Try it, you'll succeed.
1. What is the purpose of true and false questions in science?
The purpose of true and false questions in science is to test the knowledge and understanding of scientific concepts and principles. They are often used as a tool to assess critical thinking skills and to determine if a person has a basic understanding of a particular subject.
2. How do scientists ensure the accuracy of true and false questions?
Scientists ensure the accuracy of true and false questions by thoroughly researching and reviewing the information presented in the question. They also use multiple sources and conduct experiments to verify the correctness of the statement before including it in a question.
3. Can true and false questions be biased?
Yes, true and false questions can be biased if they are written with the intention of misleading or manipulating the test-taker. It is important for scientists to use objective and neutral language when creating true and false questions to avoid any potential bias.
4. How can true and false questions be helpful in understanding complex scientific concepts?
True and false questions can be helpful in understanding complex scientific concepts by breaking them down into smaller, more manageable parts. They allow the test-taker to focus on one specific aspect at a time and provide a clear answer, which can aid in comprehension and retention of the information.
5. Are true and false questions only used in multiple-choice tests?
No, true and false questions can also be used in other types of assessments, such as fill-in-the-blank or short answer questions. They can also be used in everyday scientific discussions to prompt critical thinking and promote a deeper understanding of a particular topic.
