Something seems to be wrong
  • Thread starter medwatt
medwatt
123
Hello,
Suppose y=x^2. So dy/dx=2x. If we let x=t then we have a vector valued function r(t)=<t,t^2>. Hence r'(t)=<1,2t>. As can be seen we will not have the gradient after we take the modules of r'(t). Where am I going wrong. Also suppose I went on plotting r'(t) I will get a vertical line which is pretty useless and not as informative as dy/dx=2x. What's happening?
Answers and Replies
Office_Shredder
Staff Emeritus
2021 Award
5,092
1,099
r'(t) gives a vector which points in the direction of the tangent line of the graph of r(t). The absolute value contains some information but is dependent on your specific parametrization of r(t) so won't give you information about the graph of y=x2.
Since we're in only 2 dimensions, you immediately get that a vector pointing in the direction (x,y) has slope y/x, which means the slope of the tangent line is 2t/1 = 2t which is what you expect
medwatt
123
I already know that dy/dx={dy/dt)/(dx/dt). I was trying to plot the velocity vectors which resulted from diff the parametric equations. instead of attaching these velocity vectors to points as on the plane curve in text books I decided to shift all of these vectors to the origin to see what curve they'd define. I was then going to plot acceleration vectors and see that they are indeed perpendicular to the original. What is wrong with the parametrization that I used and if I used gradient parametrization will that solve the vertical line of r'(t) I'm getting?
Office_Shredder
Staff Emeritus
2021 Award
5,092
1,099
I don't understand what information you are expecting to get out of the graph of r'(t), and why the fact that it's a perpendicular line is supposed to be surprising.
medwatt
123
Well I am practising maths in mathematica and I remember reading in a dynamics book that velocity vectors could be plotted to trace a velocity plane curve. In those days I simply acquiesced to the information. But the concept was never explored further in the book except when differentiating unit vectors. But now since I'm not the one doing the plotting I just wanted to investigate the velocity vectors. I know that the acceleration is 2m/s2 so seeing a vertical line although already indicated by the i component of r'(t) would make anyone think the acceleration is infinite and the vertical line is pretty useless. It makes using parametrization seem useless. So looking at projectile motion particularly velocity v(t)=<uCos(t),uSin(t)-gt> you will also see the same straight line.
Office_Shredder
Staff Emeritus
2021 Award
5,092
1,099
You would calculate the acceleration by finding r''(t) and getting (0,2). The slope of that line in the x-y plane does not correspond to the second derivative of y=x2, and in general trying to mix and match parametrization derivatives and y=f(x) derivatives like that is not going to work.
When I see the vertical line for r'(t) it tells me that your parametrization is linear in the x coordinate.
Suggested for: Something seems to be wrong
  • Last Post
29K
  • Last Post
