Sound Vibration
  1. Aug 1, 2017 #1
    How can one reduce the vibrations entering the house? And why do certain sounds vibrate more in certain place, but quiet fown if you move a bit further away.
    2. Relevant equations
    3. The attempt at a solution
    I was thinking it's something to do with the fact that sounds wave are mechanical waves, they need a medium to be propagated. I thought maybe a vacuum or something of the sort could help.
  3. Aug 1, 2017 #2
    Is there a diagram for this problem? The problem as stated is far to vague for us to give anything but wild guesses.
  4. Aug 1, 2017 #3
    No, there isn't any diagram. It is just a theory question where we are meant to explain how vibrating sounds (ex those from air-conditioners) entering the house could be reduced.
    Thanks
  5. Aug 1, 2017 #4
    haruspex
    Rather impractical.
    Think about the paths the sound takes to get into the house. What do the vibrations have to pass through?
    For the next part, what do you know about standing waves?
  6. Aug 2, 2017 #5
    epenguin
    Sound in air or other gas is a pressure wave transmitted essentially by molecules colliding. Vacuum - no molecules - no sound transmitted. I think this was first demonstrated by Robert Boyle who rigged up a bell he could shake and then created a vacuum, and no sound came out any more. He was a pioneer in creating vacuums, hi-tech for the epoch, and a lot of our concepts, almost unconscious are due to him and a few others of his time clarifying how air and gases were real substances. His experiments established things now so obvious that nobody ever thinks about or mentions them - although sound was not transmitted he showed that electrical and magnetic forces and of course light were. (subject to correction this is my memory of things read long ago.)
  7. Aug 2, 2017 #6
    haruspex
    True, but as I posted, that would be rather an impractical way to stop noise entering a house. There are easier ways.
  8. Aug 2, 2017 #7
    Vibrations pass through air.
    We only dealt with mechanical waves. We just mentioned that stationery waves are found for example in string instruments.
  9. Aug 2, 2017 #8
    I was initially thinking of double glazing or cavity walls. However, these are quite impractical as well since one assumes the house is already built.
  10. Aug 2, 2017 #9
    haruspex
    What if all the doors and windows are closed?
    Yes. One of the reasons for adding that to a house is to reduce incoming noise.
    Ok, but stationary waves are key to answering the second question.
  11. Aug 2, 2017 #10
    So apart from closing all doors and windows (which is not that ideal in summer) and double glazing, what other options would you suggest?
    Thank you very much for your patience!
  12. Aug 2, 2017 #11
    haruspex
    No, I'm not suggesting closing all doors and windows. I am pointing out that sound still gets through even if they were all closed.
    Even in summer, it would be unusual, if not impossible, to have all doors and windows open. Only a portion of windows can be opened, generally.
    So, how does sound get through a closed door or window, and what might you be able to do to reduce it?
  13. Aug 2, 2017 #12
    So if you close the door or a window, air isn't entering the room you're in, but sound waves travel through the glass of the window or the wood of the door.
    The problem is how to stop sound from entering. Maybe you can use soundproof materials that absorb sound?
  14. Aug 3, 2017 #13
    haruspex
    Yes, that would certainly help stop sound coming through the walls. In what other way would that help?
    Windows are more of a problem because sound absorbing materials might tend to be light absorbing too. We've mentioned double glazing. (What do you think is the reason that helps?)
  15. Aug 3, 2017 #14
    Maybe the vibrations are less powerful? I'm not sure on this one.
    Double glazing works because of the thin air gap layer between the two glass panes, so sound doesn't enter, since some of it is reflected back
  16. Aug 3, 2017 #15
    haruspex
    Think about what happens to the sound after it has come into a room.
    Yes. Each transition to a different medium results in some reflections, increasing the opportunity for absorption.
  17. Aug 4, 2017 #16
    It echoes depending on how much the room is full or empty (as in it echoes less in a room with a lot of furniture)
  18. Aug 4, 2017 #17
    haruspex
    Yes, and any soundproofing on the walls will help deaden reflections too.
    Now to the second question, why does the sound intensity vary from place to place within a room?
  19. Aug 4, 2017 #18
    Maybe it varies depending on how close or far away one is from the source of the sound?
  20. Aug 4, 2017 #19
    haruspex
    No. As I wrote, it is to do with standing waves, though it perhaps would have been more helpful to say interference patterns.
  21. Aug 4, 2017 #20
    What does it have to do with standing waves and interference patterns? And what are interference patterns exactly? I am a bit lost here.
    Also, how would you detect the source of a sound if it is not heard the same within a room and how close or far away you are does not make any difference? And to reduce the vibrations, would there be a simpler way than double glazing or soundproof materials?
    Thanks and sorry for asking too many questions!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Sound Vibration
Loading...
