Sound wave attenuation
  1. Nov 27, 2013 #1
    Why does water attenuate sound waves more than air? Is it because of it's bulk modulus? This is what I understand. Speed through a medium is determined by the elastic component over the inertial component. Since water has a much greater bulk modulus (elastic component) than air, it makes the wave travel faster in water. What I don't understand is how is it that the speed is faster yet it's attenuation is also greater. Since a sound wave travels faster through water than air shouldn't it also be more resistant to attenuation?
  3. Nov 27, 2013 #2
    davenn
    2017 Award
    hi silversurf
    you are coming from an incorrect assumption
    attenuation of sound in water is much less than in air for a given freq
    here's just one example from some tables
    Attn in Air dB/km @ 1kHz = 14dB/km @ 10% RH; 5.3 dB/km @ 90% RH ( Relative Humidity)
    Attn in seawater dB/km @ 1kHz = 0.07 dB/ km @ 0 deg C 0.05 dB/km @ 30 deg C
    http://www.kayelaby.npl.co.uk/general_physics/2_4/2_4_1.html
    hence why whale song can be heard over huge distances
    cheers
    Dave
  4. Nov 27, 2013 #3
    tiny-tim
    that's why the whales left the land, to live in the water! :wink:
  5. Nov 27, 2013 #4
    davenn
    2017 Award
    haha :smile:
    D
  6. Nov 27, 2013 #5
    sophiecentaur
    2017 Award
    It is true that water attenuates the level of sound that you can hear, when you are immersed in water. This is not due to losses in the transmission through the water but in how well the sound power is matched from the source into the water medium and then how well it is matched to your ears.
    You mention modulus. This (and the density), affects the impedance of sound waves in a medium (high in water and low in air). Your ears evolved to match sound in air, using very flimsy diaphragms and tiny levers (the ossicles). The displacement in air (for a given power level) is much greater than that in water and the movement at the entrance to the cochlea will be very much less for waterborne sound. I imagine that dolphins have a similar problem hearing sound when they are out in the air - for the converse reason.
Loading...
