Sound wave : find the speed
  • Thread starter k77i
k77i
28
A radar device emits microwaves with a frequency of 3.20e+09 Hz. When the waves are reflected from a van moving directly away from the emitter, the beat frequency between the source wave and the reflected wave is 838 beats per second. What is the speed of the van? (Note: microwaves, like all forms of electromagnetic radiation, propagate at the speed of light c = 3.00e+08 m/s.)
frequency of beat = |f1-f2|
f' = [(v-vo)/v]fo
where v is the speed of emitted frequency (the speed of light on this case), vo is the speed of the observer and fo is the frequency of the observer
The above equation is for when the observer is moving away from the source and the source is stationary
First i found the frequency of the observer (van) by using the first equation:
f(beat) = |f1-f2|
838 = |3.20e+09 - f2|
So f2 = 3 199 999 162
Then i used the second equation to find v0 (speed of the van):
f' = [(v-vo)/v]fo
3 199 999 162 = [(3.00e+08 - vo)3.00e+08]3.20e+09
this gave me vo = 78.56m/s, but according to the homework it's not right
Is it beacause im not supposed to consider f2 as f'? If not im not exactly sure how to solve for vo.
Answers and Replies
AtticusFinch
129
There are actually two doppler shifts here. Since these are radio waves I'm not sure if you can use the classical doppler equations (due to relativity).
The van is first a moving observer. The incident frequency is reflected at some frequency f'. You only know the incident frequency.
Now the van becomes a moving source of reflected microwaves (can you see why?) Apply the appropriate doppler equation using the f' from earlier as your incident frequency and 3 199 999 162 as your observed frequency.
k77i
28
ok so i get why the van is first the observer then becomes the source.
so if i do it like that, I should set up the first equation as:
f' = [(v-vo)/v]fo = [(1 - vo/3.00*10^8)]3.2*10^9
Is this right? because then i still didn't find the f' from the first equation which you're telling me to use as the incident frequency (fo) in the second equation when the van is the source
AtticusFinch
129
If you're teacher wants you to ignore relativity you are correct so far.
Now, like you are saying, write another equation for the van as a moving source. The initial frequency is f' and the observed frequency is given as 3 199 999 162. If i remember correctly it should look like this:
3199999162=(v/(v+vs))f'
but you have already expressed f' in terms of vo which is equal to vs.
So through substitution you'll get a equation with only one unknown.
k77i
28
Alright then basically the final equation should look something like this?
3199999162 = ((9.6*10^17)/(3*10^8+x))-(9.6*10^17x)/(9.6*10^16+3*10^8x), where x is the value of the speed of the van.
Because this gives me 'no solution'
AtticusFinch
129
Ok that's fine. Remember beats can mean the incident frequency is either lower than the emitted by 838 Hz or higher than the emitted by 838 Hz. You know the lower one didn't work so try the higher one.
Suggested for: Sound wave : find the speed
  • Last Post
  • Last Post
  • Last Post
22K
  • Last Post
22K
  • Last Post
  • Last Post
33K
