Is space dependent on the presence of matter?
In summary, according to relativity, space cannot exist without matter, and time is not an invariant by definition. Physical laws describe the motion of objects in space, and time can be slowed down or sped up depending on the relative motion of the time observers.
Starship
92
If space is the absence of mass-energy (which are absolute), then how do we know it exists physically (with no observer)? Also is it possible that time does not dilate (isn't time invariant by definition?) but the clocks slow down due to energy conservation principles at work?
I am totally confused...
Well, how do you know you exist? This seems rather philosophical to me.
It is philosophical. The philosophy of space-time goes back to Gottfried Leibniz. Can physical space exist separately from matter? If the answer is no then the relative is abstract and depends on the absolute.
The best theory at this time sais that space is not only defined by matter, but exists in itself. Read about Einstein and Mach.
Can physical space exist seperately from matter and energy? What is the evidence?
No evidence. It´s what the theory says. And it is otherwise very successful.
Mach's view was that space is non existent by itself - it is only what lies inbetween the matter - Einstein believed you could have a totally empty universe, and write equations that predicted things about space even though you regarded space as empty of matter. But that is only an if proposition - in reality all evidence points to the fact that while space may not be made out of chucks of matter, it is nonetheless a plenum of activity - it has many measurable properties like inductance , capacitance, and impedance, and some local property that is most likely the origin of inertia - this was one of the characteristics Einstein dwelled upon - as opposed to the ideas of Mach. As Democrities opined - it is only the atoms and the void that is real - and perhaps, in reality, the universe may be even less substantive - maybe it is only the void that is real.
Einstein's equations allow the possibility of time dilation and time travel, which is a contradiction because time is an invariant by definition. There is no dynamics in the time axis, otherwise nothing could move and we get a block universe.
General relativity allows movement in space, not in spacetime.
I don't think so... perhaps the way you define "time" is non-standard?
What does "dynamics in the time axis" mean? And why do you think we aren't in a block universe? (for background on the block universe/block time concept, see http://www.american-buddha.com/myster.flow.physics.htm Scientific American article by physicist Paul Davies)
General relativity describes fixed worldlines on a fixed spacetime.
Time travel is absolutely possible. I've traveled seven days since last week! :)
Also, not only do Einstein's equations allow the possibility of time dilation, time dilation is routinely shown to exist experimentally. Time dilation is one of the better established parts of relativity theory actually.
I join the others in questioning where you get your definition of time being invariant. Defined as it is in physical laws, time passes at different rates depending on the relative motions of the time observers.
There certainly is room, in the classical picture of GR, at least, to call all of 4-D time space a pre-determined set piece. Free will is not necessary to the classical theory. Fate is entirely consistent with it. But, quantum mechanics does not necessarily agree on that point and many people think that there is an underying quantum mechanical explanation of GR.
Consider this excerpt from Einsteins Leyden address:
...There can be no space nor any part of space without gravitational potentials; for these confer upon space its metrical qualities, without which it cannot be imagined at all. The existence of the gravitational field is inseparably bound up with the existence of space...
http://www.europhysicsnews.com/full/27/article4/article4.html
Does this mean space cannot exist without matter? Not entirely. Under the equivalence principle, space could still exist in a universe that consisted solely of energy. But such a universe would probably be unstable and suffer a cataclysmic transition event, such as a big bang.
In simple terms, relativity is a four dimensional pythagom's theorem. Time is one leg of that hypertriange, hence cannot be invariant.
1. What is space and time dilation?
Space and time dilation is a phenomenon in which the passage of time and the spatial dimensions of an object are affected by its velocity. This means that an object moving at high speeds will experience time passing slower and its length will appear shorter than when it is at rest.
2. What causes space and time dilation?
The cause of space and time dilation is the theory of relativity, proposed by Albert Einstein. According to this theory, the laws of physics are the same for all observers, regardless of their relative motion. As an object's velocity increases, time and space become relative to the observer's frame of reference, resulting in dilation.
3. How is space and time dilation measured?
Space and time dilation can be measured using various methods, such as clocks and other timekeeping devices. For example, if two clocks are synchronized and one is placed on a spaceship traveling at high speeds, upon returning to the starting point, the clock on the spaceship will show less elapsed time due to the effects of dilation.
4. What are the practical implications of space and time dilation?
The practical implications of space and time dilation are significant in the field of space travel and exploration. For instance, astronauts on the International Space Station experience time passing slower than those on Earth due to their high velocity. This can also affect GPS systems, as the satellites in orbit experience time dilation, which must be accounted for in order to maintain accurate measurements.
5. Is space and time dilation only applicable to objects moving at high speeds?
No, space and time dilation can also occur in the presence of strong gravitational fields. This is known as gravitational time dilation, where the closer an object is to a massive body, the slower time will pass for that object. This has been observed in experiments such as the famous Hafele–Keating experiment, where atomic clocks were flown around the world and showed a difference in elapsed time upon their return to the starting point.
