menniandscience
- 99
- 2
space time fabric is not phisical concept, hence we have to ask, how do mass effect at all it? there can not be an interaction between those two
"Spacetime fabric" is a phrase I generally only see in pop-sci books, not in the scientific literature.meni ohana said:space time fabric is not phisical concept
DaleSpam said:"Spacetime fabric" is a phrase I generally only see in pop-sci books, not in the scientific literature.
meni ohana said:space time fabric is not phisical concept, hence we have to ask, how do mass effect at all it? there can not be an interaction between those two
Rap said:Why do you say that spacetime is not a physical concept?
Rap said:So you meant to say that spacetime is not a physical object, so how can mass affect it?
meni ohana said:yes, that's my question
ZapperZ said:Why is it so important TO YOU that you need to clarify that it is not a "physical object"? How does this change the physics? You can call it a cow for all we care. How does it change the physics?
The way you keep having to change what you meant to say seems to indicate that you haven't thought these things through. Are you just making things up as you go along?
Zz.
Neandethal00 said:Space is physical, Time isn't.
That is why I have difficulty in accepting time as a dimension.
meni ohana said:as for the question: space is not made of anything.
space is not 'phisical' but containing the the phisical. so how body make it deform, what is the chain of phisical-causality
meni ohana said:1.why being cynical (atribute to me bad things). in my language it's easyer for me to articulate, unlike in english - not.
2. there is nothing wrong with keep sharpining the question and make it more accurate
3. i could have continue calling it space time fabric but it might give wrong connotation
as for the question: space is not made of anything. in phisics action and re-action are always on the same substrate. it would be easier to see that as the dualistic view of human, when some people argue that there is soul and body yet it can't be explained how one interact with the other.
ZapperZ said:You didn't answer my question. How would it change or affect the PHYSICS of how we do things? How would such a definition make any difference?
If I call something a boson or a fermion, it makes TREMENDOUS difference in the physics. Calling Pluto to be either a planet or not a planet makes ZERO difference, both to the physics, and to Pluto itself! All you are doing is trying to put labels on things at the superficial level, without any indication that such a label actually has a physical significance. We call such an exercise in the physics forums "a waste of time".
Zz.
Rap said:Why do you say space is not made of anything, not physical? Why do you not say that , since it deforms, then it is made of something, it is physical? Maybe we must say that because we have discovered that it does bend, therefore it is physical?
meni ohana said:i ask you: how does mass affect space? [knowing it is does not help]
By increasing the time-time term of the stress-energy tensor (and potentially other terms also if the mass is moving).meni ohana said:i ask you: how does mass affect space? [knowing it is does not help]
meni ohana said:we have to ask, how do mass effect at all it? there can not be an interaction between those two
general relativity introduces a finite coupling coefficient between curvature of spacetime, described by the Einstein curvature tensor, and the stress energy tensor which describes the mass–energy which gives rise to the curvature.
The coupling coefficient [itex]c^4/(8\pi G)[/itex] is an enormous number, of order 1043. This expresses the extremely high stiffness of space which is the reason that the Newtonian law of gravitation is an excellent approximation in normal circumstances,
The existence of gravitational waves is intuitively obvious as soon as one recognizes that spacetime is an elastic medium.
I don't know about stretching, but it definitely stores energy.meni ohana said:is spacetime elastic and strech like a rubber (stores energy?!?)
If the curvature tensor is changing wrt time then there is a distribution of stress-energy tensor which is changing wrt time.meni ohana said:Space has no individual parts that can be tracked through time.
if space has no time how can it changed?
potential energy?DaleSpam said:I don't know about stretching, but it definitely stores energy.
Space time is a mathematical concept that combines the three dimensions of space and the one dimension of time into a single four-dimensional continuum. It is used to describe the physical universe and the relationship between objects in it.
Space time is not a physical object because it cannot be touched or observed directly. It is a mathematical model that helps us understand the structure of the universe, but it does not have a physical existence in the same way that objects in space do.
Space time affects objects in the universe by providing a framework for understanding how they move and interact with each other. The curvature of space time, caused by the presence of massive objects, determines the path of objects traveling through it.
Yes, space time can be thought of as the fabric of the universe. Just as fabric is made up of threads woven together, space time is made up of the three dimensions of space and the one dimension of time woven together to create the structure of the universe.
Einstein's theory of relativity is based on the idea of space time, as it describes how the laws of physics are the same for all observers in any frame of reference. It also explains how the curvature of space time is affected by the presence of matter and energy, and how this affects the motion of objects in the universe.
