Exploring the Mystery of Space Time: Visualizing One Dimensional Strings
In summary, space time is invisible to us, but we make models to represent it. A 1D string is sketched as a line as usual. You will find lots of examples online and in books on string theory. Right but string theory is a theory, isn't there an actual way to test space time and make it visible? Depends what you mean by "visible". You can show that the behavior of objects in space and time is consistent with a particular model we are interested in. Ferisntance - the various demonstrations of general relativity show that this geometric treatment of space and time works. There is length contraction to have a more definite shape of this behavior, but most
fredreload
250
I've been wondering, space time is supposed to be consists of one dimensional string as described in the string theory, but how exactly does space time looks like since it is invisible to us. Is it possible to get a sketch of such one dimensional strings?
Astronomy news on Phys.org
As usual, we make models to represent things that are otherwise invisible.
You can show that the behaviour of objects in space and time is consistent with a particular model we are interested in.
There is length contraction to have a more definite shape of this behavior, but most of the time you move at a straight path.
When you jump you don't move along a straight path through space with time.
Some experiments probing the geometry of space time involve light rays ... eg. with gravitational lensing.
But you still have not said what you mean by "visible".
Considering yr last comment, it would help to know your education level too.
I graduated from university back in 2009 with a B.S. degree and currently working. Visible as of showing what this one dimensional string would look like, I know it is too small to see, but the general direction would maybe be in a certain direction or shape, and if there is a way to make these string visible to see? Gravitational lensing would be showing space and time curvature in a much wider sense.
Sorry, after reading more I think the article more focused on the attosecond laser pulse structure than the space time structure. Let me know if I'm wrong. It's a pretty cool concept though, sigh.
afaik there is no phenomena that can show that string theory is underlying the physics we currently know in the same sense that gravitational lensing shows that general relativity underpins Newtonian gravitation and motion. If there were, the string theory would have been confirmed.
Well I am thinking of tracing out the structure that's made up of the one dimensional strings in the 3 dimensional world. Based on special relativity described in Wikipedia here it is believed that spacetime follows a one-dimensional curve. I can be misreading it. So if it is possible to trace out such a structure, let it be a whirlpool or some flow of direction it would be interesting to visualize it.
I think he means that a stationary point looks like a line in spacetime.
A point in 3-space traces out a 1D curve, over time, called a "trajectory"... you probably don't find this mysterious.
In 3+1 space-time, a point is called an "event" - related events trace out 1D curves in space-time called a "world-line".
The simplest worldline is where the event is stationary wrt the observer - in which case it is a straight line up the ct axis.
The concept "follow a curve" does not apply to space-time: it is the mathematical framework that we use to do geometry in.
http://preposterousuniverse.com/grnotes/grtinypdf.pdf
Well, we apply the 3D cartesian structure to space time. I think space time is of a different structure, so I'll leave it at that. I can provide an explanation, but it would be a bit of self speculation. On top of that I do not have a correct structure of space time either, so I thought sketching it would get me the correct structure.
Look up "geometry of space time" ... we would generally say that space-time is non-euclidean, but it is usually represented on cartesian space-time diagrams. Its just that the space-time 4-ball does not look like a euclidean 4-sphere. You can see this if you just do it in 2D, where one dimension is time (ct), and plot all the points where the space-time length is 1. ie. If you put y=ct then you are plotting ##x^2-y^2=1##.
Apart from that, "flat" case, the precise geometry will depend on the situation.
ie. http://casa.colorado.edu/~ajsh/schwp.html
... and what is observed depends also on what the observer is doing.
We don't have to use cartesian coordinates, for instance the geometry in the link is more usefully expressed in spherical-polar coordinates. More generally, space-time geometries get represented in a coordinate-independent form.
Please look through the link my last post.
You should probably get used to the way space-time gets described before starting down your own path.
My idea of spacetime would be something more like a curved one dimensional string. Although these geometry does look interesting surrounding any spherical mass. Even if space time is not around a spherical mass it should still exhibit some type of one dimensional structure that cannot be seen but still can be found by the present day technology. The test which we conducted for a warped space time is this. Although it is assumed that without a spherical mass or black hole the spacetime is still "flat", which is contrary to my belief, that they should behave more like a curved string. For a curved string it should be visible to the human eye like a jumbled wire, but for some reason it is invisible.
Well, I don't have to prove the structure to attempt to discover it right?
Anyone else thinks if space time has a shape and if there is a way to test it?
The shape of space-time is a well established concept in physics ... you seem to be using the words to describe something else which is unclear right now.
Until you can say what you mean, nobody can help you.
What do you mean by "dimensional structure"? Can you provide an example?
Well space time is not a standard 3 dimensional cartesian structure, that I am sure of. Imagine a cube made out of blocks like a Rubik's cube here. If I have a figure of myself in one of the "block", then my figure is supposed to repeat itself for a standard cartesian structure does in all of the blocks (27 blocks in a Rubik's cube, so that would be 27 figures). You might ask, why is the figure repeating, right there is only 1 figure, but the repeating structure of space time, or what space time can contain shows the duplicate of the figure by 27 times. So the only way for the figure to "not repeat itself" in these blocks of space time, is that every single block of space time structure must be different from each other and continuous. We represent this differences in the space time structure with a "number" for distance. But how the space time structure differ from each other remains unknown, thanks to various resources I was able to come to this conclusion. So what kind of structure is space time if it is "not" a 3 dimensional cartesian structure, I can't really say, my best guess is a structure that is different in every direction so that allows space time to hold different things within, else the figure would just repeat itself in every length. Keep in mind the space time structure changes from length contraction in relativity, so it might contain a "shape" with minimum and maximum value. You can do a lot of things with a minimum and maximum value.
Right, since space time has a unit structure, I expect it to look like a line, I can be wrong.
Unit structure source edu for reference.
1. What are one dimensional strings?
One dimensional strings are theoretical objects in physics that are thought to be the fundamental building blocks of the universe. They are believed to be incredibly small, with a length of about 10^-33 centimeters, and are thought to vibrate at different frequencies to give rise to different particles and forces.
2. How are one dimensional strings related to space-time?
According to string theory, which is a theoretical framework in physics, space-time is made up of one dimensional strings. These strings vibrate and interact with each other to create the fabric of space-time. This theory attempts to reconcile the theories of general relativity and quantum mechanics.
3. How can we visualize one dimensional strings?
Since one dimensional strings are incredibly small and exist in dimensions beyond our own, it is not possible to directly visualize them. However, scientists use mathematical models and computer simulations to visualize and study the behavior of these strings.
4. What is the significance of exploring one dimensional strings?
Exploring one dimensional strings is important because it could potentially lead to a unified theory that explains all of the fundamental forces and particles in the universe. It also has the potential to provide a deeper understanding of the nature of space-time and the origins of our universe.
5. How does the concept of one dimensional strings impact our understanding of the universe?
The concept of one dimensional strings has greatly impacted our understanding of the universe by introducing a new theoretical framework that attempts to unify all of the fundamental forces and particles. It also challenges our traditional understanding of space and time, and pushes the boundaries of what we thought was possible in our universe.
  • Astronomy and Astrophysics
  • Beyond the Standard Models
