Homework Help: Spaceship relativity problem
  1. Sep 5, 2010 #1
    A spaceship is moving with a velocity [tex]0.8c\hat{x} [/tex] towards a planet. At some instant it explodes into two pieces such that the rest mass of the first piece is one thirds the original rest mass while the rest mass of the second piece is half the original one.
    The problem is 1D such that the first piece moves to the left while the second one moves to the right.
    Find the velocity of the second piece.
    2. The attempt at a solution
    I assume the rest mass of the spaceship is [tex]M_{0}[/tex].
    Energy conservation:
    [tex] \frac{M_{0}c^{2}}{\sqrt{1-0.8^{2}}}=\gamma_{1}(\frac{M_{0}}{3})c^{2}+\gamma_{2}(\frac{M_{0}}{2})c^{2} [/tex]
    (1):
    [tex] \frac{5}{3}=\frac{1}{3 \sqrt{1-(v_{1}/c)^{2}}} + \frac{1}{2 \sqrt{1-(v_{2}/c)^{2}}} [/tex]
    Momentum conservation:
    [tex] \frac{M_{0}(0.8c)}{\sqrt{1-0.8^{2}}} = -\gamma_{1}(\frac{M_{0}}{3})v_{1}+\gamma_{2}(\frac{M_{0}}{2})v_{2} [/tex]
    (2):
    [tex]\frac{4}{3}c= - \frac{v_{1}}{3 \sqrt{1-(v_{1}/c)^{2}}} + \frac{v_{2}}{2 \sqrt{1-(v_{2}/c)^{2}}} [/tex]
    However, these equation are too hard to solve so there must be another way to look at this.
    Help! =)
  3. Sep 5, 2010 #2
    Re: relativity
    anyone?! .. this problem is freaking me out :pulling my hair out:
  4. Sep 5, 2010 #3
    jcsd
    Re: relativity
    Hi, perhaps make things a little easier for yourself by 1) starting in the orignal rest frame of the ship set and 2) set c=1 then just change back to the frame you want and put c back in at the end.
    Just remember that
    [tex]\frac{v}{c} = \sqrt{1-\frac{1}{\gamma^2}}[/tex]
  5. Sep 5, 2010 #4
    Re: relativity
    what do you mean by this:
    Is it to set the velocity of the ship to be zero?
  6. Sep 5, 2010 #5
    jcsd
    Re: relativity
    Sorry I deleted a bit. I meant start in the original frame of the ship (i.e. the frame travelling at 0.8c to one we want to get our answers in). TBH not really necessary, it's just how I started the problem myself.
  7. Sep 5, 2010 #6
    Re: relativity
    Sorry, but I still don't get you ... what do you mean by "start in the original frame of the ship"? How will it change my "insolvable" equations that are written above?
  8. Sep 5, 2010 #7
    jcsd
    Re: relativity
    Anyway this is what I got (in the frame of the ship):
    [tex]\frac{\gamma_1}{3} + \frac{\gamma_2}{2} = 1[/tex]
    therefore:
    1) [tex]\gamma_2 = 2- \frac{2\gamma_1}{3}[/tex]
    for the momentum:
    [tex]\frac{\gamma_1 v_1}{3} + \frac{\gamma_2 v_2}{2} = 0[/tex]
    therefore:
    2)[tex]\frac{\sqrt{{\gamma_1}^2 -1}}{3} + \frac{\sqrt{{\gamma_2}^2 -1}}{2} = 0[/tex]
    Then 1 into 2 find the Lorentz factors, convert back to right frame and put c back in.
  9. Sep 5, 2010 #8
    Re: relativity
    first of all, thanks alot!
    The answer for this solution is:
    [tex] v_{1}=0.633c[/tex] and [tex] v_{2}=0.479c[/tex]
    while the correct answer should be:
    [tex] 0.853c[/tex]
    what could be the mistake?
  10. Sep 5, 2010 #9
    Re: relativity
    nevermind ... I've obtained the right answer ...
    THANKS ALOT!!
  11. Sep 5, 2010 #10
    Re: relativity
    By solving the equations in the rest frame of the original spaceship we got:
    [tex]\to v_{1}=0.633c[/tex] and [tex] v_{2}=0.479c[/tex]
    and by solving the "regular" equations (from the 1st post in this thread) we'd get:
    1) [tex] \frac{5}{3}=\frac{1}{3 \sqrt{1-(v_{1}/c)^{2}}} + \frac{1}{2 \sqrt{1-(v_{2}/c)^{2}}} [/tex]
    2) [tex]\frac{4}{3}c= - \frac{v_{1}}{3 \sqrt{1-(v_{1}/c)^{2}}} + \frac{v_{2}}{2 \sqrt{1-(v_{2}/c)^{2}}} [/tex]
    [tex]\to v_{1}=0.665c[/tex] and [tex] v_{2}=0.912c[/tex]
    My question is: What's the relationship between these results? i.e. between both [tex]v_{1}'s[/tex] and [tex]v_{2}'s[/tex].
  12. Sep 5, 2010 #11
    vela
    Staff Emeritus
    Education Advisor
    Re: relativity
    You can use the relativistic velocity addition formula to relate the velocities from one inertial frame to those in another.
  13. Sep 5, 2010 #12
    Re: relativity
    I tried to relate them by using the velocity transformation formula:
    [tex]u_{x}' = \frac{u_{x}-v}{1-\frac{vu_{x}}{c^{2}}}[/tex]
    where [tex] v=0.8c [/tex] and [tex]u_{x}[/tex] is the corresponding velocity ... however, nothing worked :D
  14. Sep 5, 2010 #13
    vela
    Staff Emeritus
    Education Advisor
    Re: relativity
    Your speeds in the planet's rest frame are wrong. I actually don't find a solution where one piece moves to the left in that frame.
  15. Sep 6, 2010 #14
    Re: relativity
    for the sake of my insight ;), can you please tell me how you've reached this coclusion?
  16. Sep 6, 2010 #15
    vela
    Staff Emeritus
    Education Advisor
    Re: relativity
    I had Mathematica solve your equations in the planet's frame. It produced two solutions, neither of which match yours, and in both cases, the sign of the velocities indicate both pieces move to the right.
    Also, look at the velocities you found in the ship's rest frame. The speed of the first piece is less than 0.8c, so when you transform to the planet's rest frame, it has to be moving to the right.
