Proving Equivalence of Subspaces: x+y+z=0
In summary, the statement says that if x,y, and z are vectors such that x+y+z=0, then x and y span the same subspace as y and z.
Dafe
145
Here's a statement, and I am supposed to show that it holds.
If x,y, and z are vectors such that x+y+z=0, then x and y span the same subspace as y and z.
N/A
If x+y+z=0 it means that the set {x,y,z} of vectors is linearly dependent. Because of this dependence, the vectors cannot span a subspace with dimension greater than 2.
That is, they can span subspaces with dimensions 0,1 and 2.
  • If they span a subspace with dim=0, then x=y=z=0.
  • If they span a subspace with dim=1, then two vectors are negative multiples of each other with the third one being the zero vector.
  • If they span a subspace with dim=2, then one is a linear combination (with -1 as coefficients) of the other two.
In all these cases x and y span the same subspace as y and z.
Any suggestions are greatly appreciated.
Thanks.
I think you are missing the point of the question.
Let v be in the subspace spanned by x and y. Then v= ax+ by for some numbers a and b. But x+ y+ z= 0 so x= -y- z. v= a(-y- z)+ by= (b-a)y+ (-a)z. That is, v is a linear combination of y and z and so is in the span of y and z.
That proves that the subspace spanned by x and y is a subspace of the span of y and z. I will leave it to you to show that the span of y and z is a subspace of the span of x and y.
Let v be in the subspace spanned by y and z, Then v= ...
Ah, I certainly missed the point of the question!
Let v be in the subspace spanned by y and z.
Then v=ay+bz for some numbers a and b.
But x+y+z=0 so z=-x-y.
v=(a-b)y+(-bx), that is, v is a linear combination of y and x and so is in the span of y and x.
This proves that the subpsace spanned by y and z is a subspace of the span of y and x.
We have now proved that the subspace spanned by x and y is the same as the one spanned by y and z.
Thank you!
1. What is the meaning of "Span of Subspace"?
The "span of subspace" refers to the set of all possible combinations of vectors that can be created by a given set of vectors in a specific subspace. It represents the entire space that can be reached by linear combinations of the original vectors.
2. What does the equation x+y+z=0 represent in this context?
In this context, the equation x+y+z=0 represents a plane in three-dimensional space. Each solution to this equation represents a point on the plane, and the plane itself represents the subspace in which all linear combinations of the vectors in the set can be found.
3. How is the span of subspace related to linear independence?
The span of subspace and linear independence are closely related concepts. If the vectors in a subspace are linearly independent, then their span will be the entire subspace. However, if the vectors are linearly dependent, then their span will only be a subset of the subspace.
4. Can the span of subspace be visualized?
Yes, the span of subspace can be visualized in three-dimensional space. For the equation x+y+z=0, the span would be a plane passing through the origin and perpendicular to the vector (1,1,1). This plane represents all possible combinations of the vectors in the subspace and can be visualized as a flat surface.
5. How is the span of subspace useful in linear algebra?
The span of subspace is a fundamental concept in linear algebra that helps us understand the properties of vector spaces and their subspaces. It allows us to determine the dimension of a subspace, identify linearly independent vectors, and solve systems of linear equations. It is also important in applications such as data analysis, computer graphics, and physics.
