Special Relativity Approximation of Gravitation
In summary: The Lagrangian in part 2 could be legitimate if it satisfies the following: 1. There must be a force between the particle and the background. 2. The force must be attractive. 3. The force must be constant (or at least have a very small variation). 4. The particle must move in a straight line (or at least have a straight line trajectory). The first two conditions are easy to satisfy - the force between the particle and the background is always gravity. The third condition is a little more difficult, but if the Lagrangian satisfies the following two conditions, then the particle will move in a straight line: 1. The force is
tomdodd4598
138
Hey there,
I have two questions - the first is about an approximation of a central gravitational force on a particle (of small mass) based on special relativity, and the second is about the legitimacy of a Lagrangian I'm using to calculate the motion of a particle in the Schwarzschild metric.
First of all, I should mention I have not yet properly studied GR, but have simply had some ideas about how to calculate trajectories of particles using different metrics.
1. A couple of sources, including Susskind's theoretical minimum, show that the Lagrangian of a free relativistic particle (in flat spacetime) is: [tex]L=-m{ c }^{ 2 }\sqrt { 1-\frac { { v }^{ 2 } }{ { c }^{ 2 } } } [/tex] I noticed that, in spherical coordinates, this is equal to: [tex]L=-m{ c }^{ 2 }\sqrt { \frac { -{ \eta }_{ \mu \nu }{ \dot { x } }^{ \mu }\dot { x } ^{ \nu } }{ { c }^{ 2 } } } [/tex] where [tex]\eta =\begin{pmatrix} -1 & 0 & 0 & 0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & { r }^{ 2 } & 0 \\ 0 & 0 & 0 & { r }^{ 2 }\sin ^{ 2 }{ \theta } \end{pmatrix}[/tex] is the metric for flat spacetime.
Now, I can add a potential energy term to this Lagrangian, so could I not simply add a gravitational potential energy term [tex]L=-m{ c }^{ 2 }\sqrt { \frac { -{ \eta }_{ \mu \nu }{ \dot { x } }^{ \mu }\dot { x } ^{ \nu } }{ { c }^{ 2 } } } +\frac { GMm }{ r } [/tex] and solve the Euler-Lagrange equations?
When I do this, and set the initial conditions such that the particle is in an elliptical orbit, I actually do get an apsidal precession, but the rate of this precession is much smaller than that I get from what I did below.
2. Having noticed the form of the Lagrangian above, I decided to change the flat metric to the Schwarzschild one, and set θ to be π/2 so that I could simplify the problem: [tex]\eta \rightarrow g=\begin{pmatrix} -\left( 1-\frac { { r }_{ s } }{ r } \right) & 0 & 0 & 0 \\ 0 & { \left( 1-\frac { { r }_{ s } }{ r } \right) }^{ -1 } & 0 & 0 \\ 0 & 0 & { r }^{ 2 } & 0 \\ 0 & 0 & 0 & { r }^{ 2 } \end{pmatrix}[/tex] This gives me the Lagrangian: [tex]L=-m{ c }^{ 2 }\sqrt { \frac { -{ g }_{ \mu \nu }{ \dot { x } }^{ \mu }{ \dot { x } }^{ \nu } }{ { c }^{ 2 } } } =-m{ c }^{ 2 }\sqrt { 1-\frac { { r }_{ s } }{ r } -\frac { { \left( 1-\frac { { r }_{ s } }{ r } \right) }^{ -1 }{ \dot { r } }^{ 2 }+{ r }^{ 2 }{ \dot { \varphi } }^{ 2 } }{ { c }^{ 2 } } } [/tex] Solving the Euler-Lagrange equations of this Lagrangian gives me an apsidal precession much larger than the one before.
My two questions boil down to this: First, what are the main issues with the SR approximation in part 1, and is the Lagrangian in part 2 (using the Schwarzschild metric) legitimate?
As an extra, perhaps, why do the two Lagrangians both give rise to an apsidal precession, but with different rates of precession?
Thanks in advance :)
The principle of stationary action says ##\int L \, dt## must be stationary. (Sometimes you'll see this written less precisely as extremal action, or even more loosely as "least action").
We note that ##\sqrt{1-v^2/c^2} dt = d\tau##, where ##\tau## is proper time. Because m is constant for a test particle and c is always constant, we can re-write the action integral as ##-m c^2 \int d\tau##, thus the principle of stationary action boils down to the principle of stationary proper time.
When we go from flat space-time of SR to the curved space-time of GR, there isn't any additional "potential" added to the Lagrangian L. We still have ##\int d\tau## being stationary, that principle will give us the correct equations of motion for a force-free test mass in curved space-time.
The problem with the suggested Lagrangian is that it doesn't describe gravity but the motion in an attractive coulomb potential. It's simply the wrong interaction to describe gravity (abelian massless gauge field rather than a massless spin-2 field for gravitation).
The ingenious insight by Einstein was that the most natural way to obtain a relativistic theory of gravitation is to "geometrize" it by assuming a pseudo-Riemannian manifold, which makes it compatible with the equivalence principle.
Likes tomdodd4598
Right, I see - thanks. So it's simply a coincidental fact that both give rise to precession.
But is it still a better approximation than the non-relativistic one, and is my Schwarzschild Lagrangian valid?
Even in classical mechanics most central potentials lead to precession. The Kepler problem and harmonic potentials are very special cases.
I see... so I'm guessing that my approximation has no reason to be any more accurate than the Newtonian one.
Yes, and you can show that they are the only potentials that lead to closed curves (for the non-relativstic problem only; already with special relativistic kinematics you get a precession).
A while ago we had a topic here about a picture you sometimes encounter when discussing precession, like
Those can be a bit deceiving, because it suggests that precession is purely a geometric phenomenon. As Orodruin indicates, it isn't.
Likes tomdodd4598
Right, I understand now - thanks everyone!
So, from what's been said above, my Schwarzschild Lagrangian is fine, and my attempted SR-based approximation would be used to describe, as an example, a charged particle orbiting another oppositely charged one (of much greater mass), right?
If you use your original Lagrangian but are careful to use coordinate values (where the coordinate speed of light varies from the standard value) and work in isotropic coordinates (where the space term in the metric has the same factor in all directions and the "coordinate value of c" doesn't depend on direction) then the Euler-Lagrange equations become equivalent to the geodesic equations.
Likes tomdodd4598
Aha! Thank you very much, Jonathan. I was wondering why my numerical solutions to the geodesic equations were different to those from the Lagrangian, especially close to the Schwarzschild radius - I'm very glad I came back to this thread because it seems I had accidentally forgotten about what you told me.
However, I am now very confused - if I solve the geodesic equations, not only do I get a totally different trajectory (probably to do with what Jonathan said), but also a precession which occurs in the opposite direction to that which I would expect.
I'm sure that your approach of attempting to add a potential to an SR Lagrangian will not give results consistent with GR, although I don't have the time and patience to check out the details.
By the "original" Lagrangian, I just mean the SR Lagrangian without any potential term but with the coordinate speed of light ##c## varying as a function of the location as determined by the metric, which also means that the coordinate rest mass ##m## varies (since ##mc^2## varies with dimensions of coordinate energy, which is determined by the time dilation factor). However, this is not a good way to understand GR; it is rather that once you have got to grips with the Schwarzschild solution in isotropic coordinates, this provides a neat way to relate it back to SR and Newtonian theory. Also, be aware that using ##c## and ##m## in this way to mean coordinate values rather than local values is extremely unconventional. In a textbook treatment of the GR Lagrangian you will find everything expressed in terms of tensor expressions involving the metric (which effectively converts between local values and coordinate values), but in this simple case of a static metric in isotropic coordinates it is possible to simplify the Lagrangian by using symbols to represent the coordinate speed of light and the coordinate rest mass, and if you simply use ##c## and ##m## for the purpose (with an appropriate warning to the reader!) the result looks exactly the same as the SR Lagrangian.
The Euler-Lagrange equations in this form are equivalent to the geodesic equations in that they determine the same space-time path, but they are not identical in form because they give the rate of change of coordinate momentum ##(E/c^2) \, \mathbf{v}## rather than coordinate velocity ##\mathbf{v}##. For a static metric, ##E## is constant but the coordinate speed of light varies with radial position.
You should not expect to be able to compute the perihelion precession from any simplified model as it is dependent on the second-order (post-Newtonian) term in the potential (that is, the time dilation factor in the metric). If the time dilation to post-Newtonian accuracy is ##1 - Gm/rc^2 + \beta/2 \, (Gm/rc^2)^2## then the amount of precession depends on ##\beta##. For General Relativity, ##\beta = 1##.
I think I understand what you mean. However, my issue is that the equations of motion from the E-L equations of this Lagrangian
$$L=-m{ c }^{ 2 }\sqrt { 1-\frac { { r }_{ s } }{ r } -\frac { { \left( 1-\frac { { r }_{ s } }{ r } \right) }^{ -1 }{ \dot { r } }^{ 2 }+{ r }^{ 2 }{ \dot { \varphi } }^{ 2 } }{ { c }^{ 2 } } },$$
which is the Schwarzschild Lagrangian, are very different to the equations of motion I get from the geodesic equations
$${ \ddot { x } }^{ \mu }={ \Gamma }_{ \alpha \beta }^{ 0 }{ \dot { x } }^{ \alpha }{ \dot { x } }^{ \beta }{ \dot { x } }^{ \mu }-{ \Gamma }_{ \alpha \beta }^{ \mu }{ \dot { x } }^{ \alpha }{ \dot { x } }^{ \beta }.$$
I would have expected that they were the same, but obviously I'm missing something (sorry if it's obvious). Is this because of a similar coordinate based issue that you are talking about? Or perhaps my Schwarzschild Lagrangian is invalid?
As I said, you original Lagrangian is the motion of a charged relativistic particle in a electrostatic Coulomb field. That's obviously very different from the motion of particle in the gravitational field of a static spherical mass.
The equations of motion of the Lagrangian
$$L=-mc^2 \sqrt{g_{\mu \nu} \dot{x}^{\mu} \dot{x}^{\nu}}$$
is, by definition, the geodesic equation. It's even the most general form for the most general parameterization of the geodesic. In this case you use the coordinate time as indpenedent variable, and this leads to different-looking equations for the geodesic.
It's much simpler to use the proper time of the (massive) particle. Then you can use the simpler Lagrangian
$$L=\frac{1}{2} g_{\mu \nu} \dot{x}^{\mu} \dot{x}^{\nu}.$$
Here, the parameter is automatically proportional to the pseudolength of the curve, because since the Lagrangian doesn't depend explicitly on that parameter, the "Hamiltonian"
$$H=p_{\mu} \dot{x}^{\mu}-L=L$$
is conserved, and thus you can normalize it to 1 (or ##c^2##, if you want proper time as the independent variable).
But that's exactly why I am confused. I am using that Lagrangian with the Schwarzschild metric, and I'm getting totally different equations of motion and trajectories to when I use the geodesic equations which involve the Christoffel symbols.
Yes, but with this Lagrangian you get a different equation, because your parameter can be anything. In the form you wrote it, it's the coordinate time of the Schwarzschild coordinates.
If you use a parameter proportional to the proper time, you get the form with the Christoffel symbols. To see this we set
$$L=-\sqrt{g_{\mu \nu} \dot{x}^{\mu} \dot{x}^{\nu}}=-\sqrt{G}.$$
The Euler-Lagrange equation reads
$$\frac{\mathrm{d}}{\mathrm{d} \lambda} \frac{\partial L}{\partial \dot{x}^{\mu}}=\frac{\partial L}{\partial x^{\mu}}.$$
Now we have
$$\frac{\partial L}{\partial x^{\mu}}=-\frac{1}{2 \sqrt{G}} \frac{\partial G}{\partial x^{\mu}}$$
and
$$\frac{\mathrm{d}}{\mathrm{d} \lambda} \frac{\partial L}{\partial \dot{x}^{\mu}} =-\frac{1}{2} \frac{\mathrm{d}}{\mathrm{d} \lambda} \left (\frac{1}{2 \sqrt{G}} \frac{\partial G}{\partial \dot{x}^{\mu}} \right).$$
Only if ##G=\text{const}## along the trajectory you get the equation with the Christoffel symbols.
Now you used the correct equation for general parameters and then fixed the parameter to the coordinate time ##t##. For this choice in the case of the Schwarzschild metric, you don't get the equation with the Christoffel symbols, because the coordinate time is not proportional to the proper time ##\tau##.
Right. So is this equation,
$${ \ddot { x } }^{ \mu }={ \Gamma }_{ \alpha \beta }^{ 0 }{ \dot { x } }^{ \alpha }{ \dot { x } }^{ \beta }{ \dot { x } }^{ \mu }-{ \Gamma }_{ \alpha \beta }^{ \mu }{ \dot { x } }^{ \alpha }{ \dot { x } }^{ \beta },$$
where dots represent derivatives by ##t##, wrong? Things would make much more sense to me if they were, because I'm still struggling to understand how the equations of motion can be different if my parameter in both cases is ##t##.
EDIT: Some possibly interesting and useful information: as the magnitude of the velocity get closer to ##c##, the two sets of equations of motion yield increasingly similar trajectories. Is it possible that my geodesic equation, which I got from here, is only valid for massless particles?
You can just write down the Euler-Lagrange equation from your action. Then you get the correct equations of motion, describing the geodesic in the 4D pseudo-Riemannian spacetime in somewhat unfortunately chosen coordinates. However, sometimes an explicit 1+3 decomposition (choice of "time slices") can be advantegeous to solve the dynamical systems of Einstein equations and the motion of matter and radiation, particularly when it comes to numerics. You can use this as well for massless particles since the coordinate time does not depend on the choice of proper time as the parameter, which becomes meaningless for massless particles. Nevertheless you can also express the null geodesics in terms of a scalar parameter. You can use the quadratic Lagrangian. The only difference to timelike geodesics is that for the trajectory the Lagrangian becomes 0 rather than a value >0.
Unfortunately, I can no longer record my animated graphs on Mathematica due to a horrible update to the application I used to use to record the desktop, but I will try to explain the difference in the motion I get when using the Lagrangian (with the square root) and the (questionable?) geodesic equation I showed in post #17. My initial conditions are always such that the radial velocity is 0.
When using the Lagrangian, aside from issues simply due to tiny inaccuracies in the numerical solution near the Schwarzschild radius, the particle, depending on the initial radial position and angular velocity, either:
falls in towards the event horizon, slowing down as it should,
orbits with an apsidal precession or
gets flung out and escapes, following a path that becomes straighter as it gets further from the origin.
However, there is one big issue which is that if I set the angular velocity to be such that the speed of the particle is equal to that of light (at that radius), then the calculation fails due to infinite expressions appearing. I, of course, also get no solution if the mass is 0.
When using the geodesic in post #17, things sometimes look a little odd. Either:
the particle falls in towards the event horizon, slowing down as it should,
orbits in a strange, skewed path which seems to have negative apsidal precession (only if the initial speed is lower that that of light) or
gets flung out and escapes, but instead of just escaping in a similar way to before (or like in Newtonian gravitation), the particle seems to curve away from the origin and shoot off such that it's velocity vector is almost perfectly in line with the origin.
Unlike before, however, I can set the initial speed to that of light (at that radius) without any issues, and there's no issue with the mass like before.
It's these drastically differing results that's really confusing me right now.
Anyway, something's telling me that I simply need to do a bit more studying to get these things better understood - thanks all for your help :)
I understand you now, and think I have it right. In the line element I set ##dτ## to 0 and made ##t## my parameter by dividing everything by 1 - rs/r, and then used the new metric tensor :)
If you set ##\mathrm{d} \tau=0##, you get null geodesics (the world lines of fictitious massless particles).
Yeh, that's one of the things I was looking for, since neither the Lagrangian nor the weird geodesic I found were able to give me them. I'm not just using the proper time for timelike geodesics and coordinate time for lightlike ones.
http://arxiv.org/abs/1106.1568
Well this is a paper which shows that philosophers don't have a clue, how the progress of science really works. Of course, from the point of view of today, where we have GR and with it the idea that spacetime is different from Newtonian spacetime, it's simple to say that it is obvious.
Nonsense. What philosophers? The paper is authored by a working high energy physics phd, that has just been been given the Humboldt research award in the field of particle physics(host was Grojean from DESY). Besides the concept of effective theory is mainstream in QFT.
I think it is perfectly relevant to the OP question.
Doesn't this just show that Orodruin was correct? This paper doesn't seems to do much more than just look at some simple modifications of Newton's Law, and that one of them happens to give the Schwarzschild effective potential.
Well, I quoted his answer, and then gave the link to illustrate it.
Actually I'd say the paper does do a bit more. It stresses the idea of effective theories way of giving more importance to the symmetries (in this case the spherical symmetry of central potentials) than to the specific way this symmetry is best approximated depending on the specific circumstances, whether it is a inverse-square law or others. It suggests that as long as one has a conceptual way to restrict the deviation from the specific law, in this case c as a limiting velocity that enters through the use of Lorentzian metrics, this effective theory heuristic is a valid one to explore new physics.
One can question whether it would really have helped find a solution for Mercury precession in the 19th century, everything looks easier after the fact now that we have GR. But the take-away message I see is that it could be worth to use this heuristic at this point in the quantum gravity conundrum after nearly a century without any substantive progress.
I think this heuristic has already been used in quantum gravity. The problem is that, as those who tried to use it in the 1960s and 1970s discovered, the "effective theory" in question turns out to be just General Relativity. In other words, the effective field theory you get for a massless spin-2 field, which is what a quantum field describing gravity would be, has a field equation which turns out to be just the Einstein Field Equation. The "quantum gravity conundrum" is that we don't know the new fundamental theory to which this effective field theory is an approximation. I don't see how the heuristic described in the paper solves that problem, any more than applying it in the 19th century would have given you the full theory of GR.
Likes tomdodd4598
1. What is the Special Relativity Approximation of Gravitation?
The Special Relativity Approximation of Gravitation is a theory that describes how gravity works within the framework of Einstein's theory of special relativity. It takes into account the effects of time dilation and length contraction on the force of gravity, which are predicted by special relativity.
2. How does the Special Relativity Approximation of Gravitation differ from Newton's law of gravitation?
The Special Relativity Approximation of Gravitation differs from Newton's law of gravitation in that it takes into account the effects of special relativity, while Newton's law does not. The theory also predicts slightly different values for the force of gravity in extreme cases, such as near the speed of light.
3. What are the key concepts of the Special Relativity Approximation of Gravitation?
The key concepts of the Special Relativity Approximation of Gravitation are time dilation, length contraction, and the equivalence principle. Time dilation and length contraction describe how time and space are affected by an object's speed, while the equivalence principle states that gravity is equivalent to acceleration.
4. How does the Special Relativity Approximation of Gravitation explain the bending of light near massive objects?
The theory explains the bending of light near massive objects through the concept of space-time curvature. According to the theory, the presence of a massive object causes a curvature in space and time, which affects the path of light passing near it.
5. What are the practical implications of the Special Relativity Approximation of Gravitation?
The Special Relativity Approximation of Gravitation has many practical implications, including correcting for the effects of special relativity in GPS systems, understanding the behavior of objects near the speed of light, and providing a more accurate description of the force of gravity in extreme cases.
