Special relativity in the plane acoustic and electromagnetic wave
  1. Jan 8, 2009 #1
    Let us envision three frames of reference I, I’ and I” in standard configuration with I’ moving with velocity V relative to I and I” moving with velocity u relative to I and with velocity u’ relative to I’. Let O, O’ and O” be the spatial origins of the frames respectively; O, O’ and O” coinciding at the origin of time in the three frames (t=t’=0).
    Accept the following notations g(V)=1/sqr(1-VV/cc); g(u)=1/sqr(1-uu/cc) and g(u’)=1/sqr(1-u’u’/cc).
    Let I” be the rest frame of a rod located along the permanently overlapped axes x,x’x” where its length is L0. Observers from I detect simultaneously the space coordinates of the ends of the rod, subtract them obtaining that its length is L related to L0 by
    L=L0/g(u). (1)
    Following the same procedure observers from I’ obtain for the length of the moving rod
    L’=L0/g(u’). (2)
    Combining (1) and (2) we obtain that L and L’ are related by
    L=L’g(u’)/g(u). (3)
    Expressing the right side of (3) as a function of u’ via the addition law of parallel speeds
    u=(u’+V)/(1+Vu’/cc) (4)
    the result is
    L=L’/[g(V)(1+Vu’/cc)]. (5)
    I underline that (4) could be derived without invoking the Lorentz transformations.
    Introducing the physical quantities k=1/L and k’=1/L’ we obtain that they transform as
    k=g(V)k’(1+Vu’/cc). (6)
    If the rod is generated by a particle moving with speed u for a proper time interval t(0) i.e.
    L=ut(0) (7)
    in I and
    L’=u’t’(0) (8)
    then (6) becomes
    k=g(V)[k’+V/t’(0)cc]=g(V)[k’+Vf’/cc] (9)
    where f’=1/t’(0) has the physical meaning of frequency. If the rods are generated by light signals then L=ct(0) and L’=ct’(0) (6) becoming
    k=k’sqr[(1+V/c)/(1-V/c)] . (10)
    We obtain the transformation equations for the frequencies f and f’ starting with f=ku and f’=k’u’. Combining them and taking into account (4) the result is
    f=g(V)f’(1+V/u’)=g(V)(f’+Vk’) (11)
    which becomes in the case of rods generated by light signals
    f=f’sqr[(1+V/c)/(1-V/c)]. (12)
    Would you accept all that as a introduction in special relativity in the acoustic and in the electromagnetic plane waves?
Draft saved Draft deleted
