Special Relativity Problem -- Speeding through a red light to make it look green
In summary, a noted physicist was stopped by police for running a red light while driving at a high speed. The physicist argued that due to his speed, the light appeared green to him. The judge let him off the red light charge but fined him for speeding. Using the relativistic Doppler shift equation, it was determined that the physicist was traveling at 0.628 times the speed of light. This would result in a fine of almost $68,000 for traveling over the speed limit by over 67,800 km/hr. The ratio of the frequencies of red and green light, 4:3, was used to find the correct solution for the physicist's speed. Additionally
iaberrant
By now i must be driving you guys crazy with my relativity questions , but this is my last one! i swear! =]
A noted physicist was stopped by police for traveling through a red traffic light. The physicist argued that to because he was traveling fast, the colour of the light had changed from the red wavelength to that of a green wavelength
The judge said that he would let him off the charge of running the red light, but would fine him for speeding at the rate of one cent for every 100km/hr he was traveling over 100km/hr
Was he fined? and how much was his fine?
Assume
c=3x10^8ms-1
frequency of red light=4.5x10^14 Hz
frequency of green light= 6.0 x 10^14 Hz
Would this problem also be related to the Dopper Shifty as the change of colour of the traffic lights? And therefore would the doppler shift be appropriate to use in this case ? But i have come across a relativistic doppler formula; f/f0 = √[(1 + v/c)/(1 - v/c)] ?
there is a non relativistic doppler formula ?
hence ;
∆f = f0*(v/c)
v = ∆f/f0 * c
where ;
∆f = 1.5*10^14
f0 = 4.5*10^14
v = 0.33 c
How can i go about this problem and any other ideas of what is involved in solving the problem ?
Thankyou in advance~!
According to our modern day understanding of physics, light is neither a wave nor a particle. Sometimes, light behaves as a wave, sometimes as a particle, but not both at the same time. Light, as a wave that exhibits wave motion, is a periodic motion characterized, among other things, by a wavelength ##λ~##, a period ##T_0~##, and a wave frequency ##ν~##.
##\dots~λ~\Rightarrow~\begin{cases}\begin{align} & \text {the distance traveled by the wave along the } \nonumber \\
& \text {direction of propagation in one period or one cycle} \nonumber \\
& \text {of the motion before the next cycle is repeated}~\dots\nonumber \end{align}\end{cases}##
##\dots~T_0~\Rightarrow~\begin{cases}\begin{align} & \text {the time to complete one cycle and travel } \nonumber \\ & \text { the distance of one wavelength }~ λ~\dots\nonumber \end{align}\end{cases}##
##\dots~ν~\Rightarrow~\begin{cases}\begin{align} & \text { tells the number of waves passing } \nonumber \\ & \text {through a given point in a given time }~\dots\nonumber \end{align}\end{cases}##
The larger the period ##T_0## (the longer it takes for one complete cycle to pass through), the longer the wavelength ##λ~##, and the smaller the frequency ##ν## (the fewer the number of full cycles that pass through). Being more familiar with length in the Special Theory of Relativity, we consider the wavelength of light in this problem instead of the frequency.
##\dots~## for red light ##~\Rightarrow~##average ##~λ_\rm R## = 685##×10^{-9}## m = 685 nm##~\dots~##
##\dots~## for green light ##~\Rightarrow~##average ##~λ_\rm G## = 533##×10^{-9}## m = 533 nm##~\dots~##
Red light becoming green with ##~λ_\rm R~\gt~λ_\rm G~\Rightarrow~##length contraction##~\dots~##
##\Rightarrow~λ_\rm G## = ##λ_\rm R[1 - (v/c)^2]^{1/2}\Rightarrow~1 - (v/c)^2~##= ##(λ_\rm G/λ_\rm R)^2~##= 0.605443##~\dots~##
##\Rightarrow~(v/c)~##=##~(0.394557)^{1/2}~##= 0.628##~\Rightarrow~v~##= ##(0.628)c~\Rightarrow~v~##=##~1.884 ×10^8~\rm m ⋅ \rm s^{-1}~##...
##\Rightarrow~v~##=##~6.7824 ×10^8~\rm km ⋅ \rm hr^{-1}~\Rightarrow~v/(100~\rm km ⋅ \rm hr^{-1})~##=##~6.7824 ×10^6~##gives the number of times in excess of the 100##~\rm km ⋅ \rm hr^{-1}~##speed limit if the red traffic light appears green to the driver.
Being charged of a fine at the rate of one cent for every 100##~\rm km ⋅ \rm hr^{-1}~##he was traveling over 100##~\rm km ⋅ \rm hr^{-1}~##, the driver must pay a total fine of almost $68,000.
@kumusta -- Because this thread is over 10 years old, it is okay for you to post a solution. Just keep in mind that for current schoolwork/homework threads, solutions cannot be provided by us. The student must do the bulk of the work. Thanks.
Everything clear. No solutions for current schoolwork/homework threads.
Likes berkeman
Thanks too.
For the record, the number provided by @kumusta does not use the relativistic Doppler shift equation. The answer I got with ##\beta = v/c=\frac{7}{25}## from using the equation ##\dfrac{f_{\text{source}}}{f_{\text{receiver}}}=\sqrt{\dfrac{1+\beta}{1-\beta}}## is $30,200 plus change.
Likes hutchphd, PeroK and berkeman
My solution took into account the relativistic effect of length contraction only, if it could be called as such. I failed to consider the fact that time is not absolute but is generally different for different observers. So obviously, the solution that I gave cannot be the correct one. Many thanks to kuruman for pointing it out.
Likes berkeman and kuruman
While looking at kuruman's post #6, I noticed that since ##(1 - β) < (1 + β)~##, then he must have used the frequency of green light for ##f_\rm {source}~##and the frequency of red light for ##f_\rm {receiver}~##:
kuruman said:
... the answer I got with ##\beta = v/c=\frac{7}{25}## from using the equation ##\dfrac{f_{\text{source}}}{f_{\text{receiver}}}=\sqrt{\dfrac{1+\beta}{1-\beta}}## is $30,200 plus change.
I think it should be the other way around since the source, which is the traffic light, must have shown red and not green. I suspect now that there's also something wrong with kuruman's computations.
Anyway, the answer ##~v = (0.628)c~## that I got must be rather high. Knowing the fact that frequency and wavelength are related by the equation ##~v = fλ = λ/T~##, taking relativistic time dilation into account too, with larger value of ##~T~##, aside from length contraction, would clearly give a smaller value for ##~v~## than the one which treats time as an absolute quantity.
  • Skeptical
Likes PeroK
The ratio of the frequencies is ##r=\dfrac{6.0}{4.5}=\dfrac{4}{3}.##
The solution of ##\dfrac{4}{3}=\sqrt{\dfrac{1+\beta}{1-\beta}}## is ##\beta=+\dfrac{7}{25}.##
The solution of ##\dfrac{3}{4}=\sqrt{\dfrac{1+\beta}{1-\beta}}## is ##\beta=-\dfrac{7}{25}.##
Since the fine is for speeding and not velocitying, the sign does not matter and the defendant has to pay the same fine in either case.
kuruman said:
velocitying
TIL a new word at PF... :smile:
  • Love
  • Haha
Likes SammyS, DaveC426913, jbriggs444 and 1 other person
velocity [ vuh-los-i-tee ]
noun, plural ve·loc·i·ties
rapidity of motion or operation; swiftness;
a high wind velocity
verb (used without object), ve·loc·i·tyed, ve·loc·i·ty·ing
to move in a fixed direction
we velocitied from the Northside to the Southside in record time
  • Skeptical
Likes berkeman
You using the Urban Dictionary again? This is what I get with Google... :smile:
Truth be told not even the Urban Dictionary has the word as a verb, I looked. I made it up initially for post #9 and then came up with a dictionary-style definition after seeing your post #10. Hey, that's how the language evolves, no? If enough people use a word in a new context, it will find its way into the real dictionaries.
Likes berkeman
For the record, it appears that velocitying is the name of a YouTube channel.
https://www.physicsforums.com/attachments/289187
It's been in YouTube since February 2007?
But post #9 was made only yesterday, Thu16Sept2021
kuruman said:
Truth be told not even the Urban Dictionary has the word as a verb, I looked. I made it up initially for post #9 and then came up with a dictionary-style definition after seeing post #10 ...
Then YouTube has the copyright for the word velocitying.
You cannot copyright this word. At least in the U.S. The doctrine of merger applies. In the U.S. you are allowed to copyright the expression of an idea (i.e. the book "Huckleberry Finn") but not the idea of a child floating down a river on a raft with a slave. If there are only a limited number of ways to express an idea, the expression merges with the idea and the expression becomes uncopyrightable.
Trademark, however, follows a different standard. Which explains how the phrase "Super Bowl" can be trademarked, even though it would not be copyrightable.
Likes hutchphd
It's okay if that is so. But I think no one has the right to claim just a couple of days ago that a new word originated from him when that particular word already existed more than 10 years ago.
I assume you are referring to my posts #11 and #13.
Firstly, I never claimed that I originated a new word. The word "velocity" has existed as a noun for centuries (velocitas in Latin). I acknowledged so explicitly in #11 by showing the existing noun and, beneath it, the verb "to velocity" and then again in #13 where I stated "If enough people use a word in a new context, ##\dots~##"
Secondly, what I made up from the word "velocity" is its use as a verb. To that end, I provided a dictionary-like definition complete with past tense to show that the verb is regular. I included a sentence to illustrate its use in a sentence as an intransitive verb without an object.
Thirdly, the use of "velocitying" in YouTube is irrelevant and only superficially akin to the verb defined in #11, but it is not a verb or part thereof. It is the name of a playlist, therefore a noun, and conveys no action. An example of its use in a sentence might be, "Velocitying is a YouTube playlist" in which, as a noun, it serves as the subject of the copulative verb "is".
Fourthly, I believe that the original question posed by the OP has been fully, albeit belatedly, answered therefore I will henceforth cease and desist posting more silliness on this revenant thread.
  • Haha
Likes hutchphd and jbriggs444
I'm sorry but I disagree with this assesment in post #17 regarding this thread:
kuruman said:
... I believe that the original question posed by the OP has been fully .. answered ...
The solutions given in post #6 and #9 are somewhat arbitrary and has some inconsistencies:
I pointed these things out in post #8:
It seems that no attention was paid to my misgivings and they only fell on deaf ears.
Without knowing the correct solution then, I would have just forgotten it and left things as they were. But just recently, I think I found the correct solution and I would like to share it to others.
I'll send the right solution in the next post.
Our ears are not deaf. I can only speak for myself when I say that if I have nothing to add to what I have already said, I say nothing. I will make an exception and repeat myself except in more detail. Start with $$\frac{f_{\text{source}}}{f_{\text{receiver}}}=\sqrt{\frac{1+\beta}{1-\beta}}.$$Obviously it's the ratio of frequencies that matters. Looking at the numbers, the lower frequency is red. Thus, if ##f_{\text{source}}=3##, then ##f_{\text{receiver}}=4.## The source is approaching the receiver, which means that ##\beta## is negative. To ensure that, we replace ##\beta## with ##-|\beta|## in the equation and then solve to find the relative speed:$$\frac{f_{\text{source}}}{f_{\text{receiver}}}=\sqrt{\frac{1-|\beta|}{1+|\beta|}}=\frac{3}{4}.$$ If you solve that equation, you get ##|\beta|=\frac{7}{25}.## The point I tried to make earlier is that whether you write the frequency ratio as 3/4 or 4/3, you will get ##|\beta|=7/25## and the fine is the same.
Does this address your misgivings? As I stated elsewhere, we aim to please.
The correct formula for relativistic Doppler shift can be found in Fowles's book ##\text {Intro. to Modern Optics}~##, 2nd Ed.,©1975. It says there that the observed frequency (frequency received) ##~f'~## is given by $$ f' = f \sqrt { \frac {1 - β } {1 + β } }~\Leftarrow~\begin{cases} {\begin{align} ~& {\rm {either} }~β\gt0~\text {if the source and receiver } \nonumber \\ & \text {are moving away from one another} ~\dots \nonumber \\ & {\rm {or} }~β\lt0~\text {if they are moving toward each other}~\dots \nonumber\end{align} }\end{cases} $$ where ##~β = v/c~.~##The special theory of relativity removed the distinction between observer in motion and source in motion so that what is important now is only the relative motion between them. Notice that when the source and the receiver are moving away from each other so that ##~β\gt0~##, then ##~1 + β \gt 1 - β~## which gives ##f'~\lt~f~## that signifies a decrease in the observed frequency and a corresponding increase in the wavelength ##\lambda~##. Frequency and wavelength are inversely proportional
to each other, meaning that if one of them increases, then the other decreases.
In the particular instance of an overspeeding driver traveling through a red traffic light, we have the second case in the relativistic formula mentioned above, namely the one where the source and receiver are moving toward one another. The correct formula to apply is the one with ##~β\lt0~## so we make the replacement ##~β = -v/c~## and get $$ f' = f \sqrt { \frac {1 + v/c } {1 - v/c } }~\Leftarrow~\begin{cases} {\begin{align} ~& [1 + v/c~] \gt [1 - v/c~]~\text {indicating that} \nonumber \\ & f'\gt f,\text {showing an increase in frequency} \nonumber \\ &
\text {that shortens the wavelength}~\dots\nonumber\end{align} }\end{cases} $$Solving for ##~v~## we obtain ##~v = c[~(f'/f)^2 - 1~]/[~(f'/f)^2 + 1~]~\dots##
Substituting the values for the average frequency of green and red colors of light: $$\dots~f_{\rm green} = 565~{\rm THz} = f'~\dots~f_{\rm red} = 440~{\rm THz} = f~\dots$$ $$\dots~v = (0.245)c = 7.35~×~10^7~{\rm m} · {\rm s}^{-1} = 2.646~×~10^8~{\rm km} · {\rm hr}^{-1}~\dots$$ $$\dots~ \begin{cases}\begin{align} & \text { the number of times in excess }\nonumber \\ & \nonumber \text { of the 100 km} · {\rm {hr}^{-1}}~{\rm {speed} }~\Rightarrow~2.646~×~10^6\nonumber \end{align}\end{cases}$$ Almost $26,500 fine must be paid for one cent every time the 100 km/hr speed limit is exceeded.
iaberrant said:
Assume
c=3x10^8ms-1
Your frequencies are not the same as the ones given by the OP.
@kuruman ... Of course they are, they both have the same order of magnitude
There are minimum and maximum values of the frequency for any given color. I used the average value.
You said in post #21:
I posted in #20 to which post #21 was referring to:
I replied in post #22 to answer #21:
##\text {terra} = 10^{12}##
Are you claiming that two numbers are equal if they share the same order of magnitude? Most traffic court judges would disagree.
There you mentioned nothing about ##|β|~,## that ##β## can be ##\pm~.## Then, suddenly in post #19, only after 10 messages had already been posted, you surprisingly come up with the idea that ##β~,## in the formula you used in #9 , can be ##\pm~.## Why didn't you post #19 much earlier or come up with the idea of ##\pmβ~## somewhat sooner so that you could have informed us forum viewers about it for even just a couple of days ago already, and not just now belatedly after I started writing my post #20. It takes me quite a long time to finish writing my posts, and I know that forum mentors have the special privilege of viewing what ordinary forum members are writing in a thread. If ordinary forum viewers use PhysicsForums' platforms to chat only with their friends about things that have nothing to do with physics, then the PhysicsForums' administrative staff and mentors have all the right to do something to avoid their platforms being misused and abused. But some sort of privacy must also be allowed to forum viewers only while they are writing their posts to answering a thread. But exactly how, I cannot make any suggestion. Also, I think some sort of checks and counter checks must be used to prevent those with special privileges to abuse the special treatment given to them.
This argument won't stick in physics as it doesn't stick in everyday life. If one's favorite loan shark expects one to pay him back the $75,000 that one owes and one gives him only $15,000, no matter how much one insists that it's the "same order of magnitude", one will end up with broken kneecaps ##\dots~## if one is lucky.
I have said all I have to say on this thread.
Likes jbriggs444
@jbriggs444 ...
Of course I wasn't talking about any two numbers having the same order of magnitude in general. I was talking to kuruman about these numbers given by the OP
in post #1:
iaberrant said:
frequency of green light= 6.0 x 10^14 Hz ... frequency of red light=4.5x10^14 Hz
and these numbers that I wrote in post #20:
I know that they are not equal but for the purposes of my discussion with kuruman, I considered them equal in the first order of approximation. Am I wrong in doing that?
Be that as it may, I'm glad that I don't know how to drive, so I'm sure I'll never have anything to do with a traffic court judge.
Likes hutchphd
Then I do not understand what point you are arguing and will have to follow the excellent example of @kuruman and bow out of this thread.
kuruman said:
This argument won't stick in physics as it doesn't stick in everyday life. If one's favorite loan shark expects one to pay him back the $75,000 that one owes and one gives him only $15,000, no matter how much one insists that it's the "same order of magnitude", one will end up with broken kneecaps ##\dots~## if one is lucky ...
@kuruman ... You know fairly well what we were talking about. We were not arguing about the acceptability of settling a $75,000 debt by paying back only $15,000 , which you mentioned in post #26 and that seem to imply, that according to my own point of view, should be acceptable because they have the same order of magnitude.
Rather, we were talking about the acceptability of two values for two different colors of light. In post #21, you referred to the values (whose positions I rearranged a bit for better viewing) given by the OP:
iaberrant said:
frequency of green light= 6.0 x 10^14 Hz ... frequency of red light=4.5x10^14 Hz ...
and stated there:
You were referring to the values that I used in post #20:
But each color of visible light lie within a certain range of values of frequencies and wavelengths as can be seen below.
As long as a color remains within its range of recognized values, it keeps its color. I used the average values so they are found at the middle of their accepted intervals. What could be so objectionable about that? Slight differences in numerical values that lie within a narrow range could not possibly produce colors that are drastically different from one another.
But now I noticed also another dissimilarity aside from the slightly different numbers that I used. The OP gave values of frequency in powers of 10 while I used those given in SI units of THz (terahertz). Should that be a big problem to someone already familiar with the numerous physical concepts and principles in physics?
I really don't understand why you always seem to make me appear stupid whenever I noticed any inconsistency in what you are saying. I have nothing personal against you. I just want clear and consistent scientific explanations of things. Remember that you said your aim is to please? I don't want you to please me by accepting what I say that are unresonable and senseless to you. I'm sure that you won't ever do that to anybody. And I also happen to know that I have no right to tell you how to please others who even just want to learn. You should know that yourself. You were a student before.
1) What is the Special Relativity Problem?
The Special Relativity Problem refers to the phenomenon where an object traveling at high speeds experiences a different passage of time and a change in its length and mass, as observed by a stationary observer.
2) How does Special Relativity relate to speeding through a red light?
When a car is traveling at high speeds and passes through a red light, the driver may perceive the light as green due to the effects of Special Relativity. This is because the light signals from the traffic light are traveling at a certain speed and the car is also moving at a high speed, causing a distortion in the perception of time and distance.
3) Is it safe to speed through a red light based on the effects of Special Relativity?
No, it is not safe to speed through a red light, even if it may appear to be green due to Special Relativity. This is because the laws of physics and traffic rules still apply, and it is important to follow them for the safety of yourself and others on the road.
4) Can Special Relativity be used as an excuse for running a red light?
No, Special Relativity cannot be used as an excuse for breaking traffic laws. While it may explain the phenomenon of perceiving a red light as green, it does not justify breaking the law and putting oneself and others in danger.
5) How is Special Relativity accounted for in traffic light systems?
Traffic light systems are designed and timed based on the laws of physics and the average speed of vehicles. Special Relativity is not a factor in the design of traffic light systems, as it only applies to objects traveling at extremely high speeds close to the speed of light.
