Special relativity problem
An astronaut went to sun from earth by a rocket. According to the clock in the rocket, the traveling time was 5 minute. What was the velocity of the rocket?
( earth is 8 light minute away from sun)
[itex]t = \frac {t_0}{\sqrt {1 - \frac{v^2}{c^2}}}[/itex]
According to the reference frame of earth, the distance between sun and earth is, [itex]L_0 = 8\cdot 60 \cdot c [/itex]
Let, the time required to travel this distance be [itex]t_0[/itex] [according to earth];
So, [itex]t_0 = 5 \cdot 60 \cdot \sqrt {1 - \frac{v^2}{c^2}}[/itex]
and the velocity, [itex] v = \frac {L_0}{t_0} = \frac { 8\cdot 60 \cdot c }{ 5 \cdot 60 \cdot \sqrt {1 - \frac{v^2}{c^2}}} = \frac { 8c }{ 5 \sqrt {1 - \frac{v^2}{c^2}}} [/itex]
[itex]v^2 = \frac {64c^2}{25(1 - \frac{v^2}{c^2})}[/itex]
[itex]v^2 \cdot 25(1 - \frac{v^2}{c^2}) = 64c^2[/itex]
Simplifying, [itex]\frac{25}{c^2} (v^2)^2 - 25 (v^2) +64c^2 = 0 [/itex]
But, the solution of this equation is complex number.
Answers and Replies
Orodruin
Staff Emeritus
Insights Author
6,652
You are doing the time dilation in the wrong way. ##t_0## is the proper time, i.e., the time for the astronaut and should be smaller than the time in the Earth reference frame.
Look, we are calculating the distance according to earth. So, shouldn't we take the time according to earth?
Orodruin
Staff Emeritus
Insights Author
6,652
Yes, and you are not. The quantity ##t_0## is the time elapsed for the astronaut.
I got it. We have to calculate the time interval between two events : 1. The rocket starts from earth , 2. The rocket reaches the sun. And these two events occured at the 'same location' in the reference frame of rocket. So, the time measured from the rocket is to be taken as the proper time.
There is another way to solve the problem. According to earth, both the earth and the sun are stationary (as it is described for this problem), and according to the rocket they are moving. So, the distance between the sun and earth is contracted in the reference frame of the rocket. So, ## L = L_0 \sqrt { 1 - \frac{v^2}{c^2}}##
Orodruin
Staff Emeritus
Insights Author
6,652
That's more like it. :)
Likes arpon
Related Threads on Special relativity problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
