• Support PF! Buy your school textbooks, materials and every day products Here!
Special relativity question
  • Thread starter kavamo
I have correctly figured out part a but am stuck on part b. Thanks for your help in advance.
An unstable particle called the pion has a mean lifetime of 25 ns in its own rest frame. A beam of pions travels through the laboratory at a speed of 0.587c.
(a) What is the mean lifetime of the pions as measured in the laboratory frame?
30.75 ns
(b) How far does a pion travel (as measured by laboratory observers) during this time?
m
[ Delta t x c (speed of light) ] / 2
using the answer from part a and converting to meters:
[(3.075E-8)(3E8)] / 2 = 4.6125 I've checked for errors and always come up with this number--which according to the web program is incorrect.
What am I not doing/understanding?
Answers and Replies
Doc Al
Mentor
44,945
1,206
:confused: Where in the world did you get this formula?
Hint: How fast is it moving? How long is it moving for? How do you calculate distance traveled?
I got the formula from my professor.
As far as I can tell it is moving at 0.587c = 176100000 m/s for 25 ns.
Distance = rate x time.
So then I suppose I would do the following:
176100000 m/s x (2.5 x 10^-10) = 0.044025 meters?
Doc Al
Mentor
44,945
1,206
It must be meant for some specific application--but not this one.
Why 25 ns? Stick to the lab frame.
That's all you need.
o.k. then,
176100000m/s x (3.075 x 10^-10) = 0.05415075 ~ 0.0542 and convert to meters = 5.4 m
Doc Al
Mentor
44,945
1,206
o.k. then,
Two things, the first being the most important:
- check your exponents
- use a more accurate value for the time in part a (redo it); only round off at the end.
thank you I should have typed:
176100000m/s x (3x 10^8)x 30.75 (the answer from part a) = 5415075000
then convert from nano to meters (9 decimal spaces to the left) = 5.41 meters
which is the correct answer. Thank you for your guidance. K
Related Threads on Special relativity question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
