Special Relativity Spaceship Question
In summary, the two space ships, with a proper length of 100m each, are moving in opposite directions at a speed of 0.75c. Bob sits at the front of his ship and sees a clock at the end of Anna's ship. Using the equations of special relativity, we can determine that the position of Bob's window is 66.1m from the end of his ship, and the clock in Anna's ship reads 4.45 * 10^-7 seconds.
Lucille
31
bob and anna are in two space ships of proper length 100m; anna's ship passes bob's and is moving in the -x dir at v=0.75c. the front of anna's ship and the tail of bob's ship coincide at x=x'=t=t'=0. bob sits at the window in his ship and sees a clock inside anna's ship
a) what position is the window in bob's space ship
b) what time does this clock in anna's ship read
x'=gamma(x-vt)
x=gamma(x'+vt')
t'=gamma(-v/c^2*x+t)
t=gamma(v?c^2*x+t')
delta t = gamma delta to
L = Lo/gamma
a)
so if bob sees the clock at the end of anna's ship, then:
L=Lo/gamma = sqrt(1-v^2/c^2)*Lo = sqrt(1-0.75^2)*(100)=66.1m <-- position of bob's window in his spaceship (distance from the end of his spaceship to the window)
b)
i tried :
x=100m
v=0.75c
t'=x'/v = 4.45 * 10^-7 s
But I'm not sure if this is correct...
One thing that isn't clear: Bob is situated at the front of his space ship?
Chet
The question doesn't state that. It's asking where the window is - I'm guessing that's the point at which he can see Anna's clock, and her window is at the end of her spaceship.
So, under this interpretation, you are looking at the event at which x' = L0 and t = 0. In part a, you showed that ##x=L_0/\gamma##. Now all you need to do is substitute this into the equation for t'.
Chet
Your approach for part a) is correct. For part b), you are on the right track, but there are a few errors in your calculations.
First, the equation you are using, t'=x'/v, is for time dilation, not for finding the time on a clock in a moving frame. The correct equation is t' = gamma(t-vx/c^2), where t is the time on the clock in the stationary frame (in this case, Bob's frame) and x is the distance between the clock and the observer (again, in this case, Bob). So, using the values given in the problem, we have:
t' = gamma(t-vx/c^2) = gamma(0-0.75*100/299792458^2) = 4.45 * 10^-7 s
This is the correct time on Anna's clock as observed by Bob. Note that this is the same value you calculated, but with a different equation.
1. What is the Special Relativity Spaceship Question?
The Special Relativity Spaceship Question is a thought experiment used to illustrate the principles of special relativity. It involves two spaceships traveling at high speeds relative to each other and explores how time, length, and mass are affected by their relative motion.
2. Why is the Special Relativity Spaceship Question important?
The Special Relativity Spaceship Question is important because it helps us understand the counterintuitive effects of relativity, such as time dilation and length contraction. It also has practical applications in fields such as astrophysics and GPS technology.
3. How does the Special Relativity Spaceship Question relate to Einstein's theory of relativity?
The Special Relativity Spaceship Question is based on Einstein's theory of special relativity, which states that the laws of physics are the same for all observers in uniform motion. It is used to illustrate the principles of this theory and clarify its implications.
4. What are some of the key concepts explored in the Special Relativity Spaceship Question?
The Special Relativity Spaceship Question explores concepts such as time dilation, length contraction, relative motion, and the constancy of the speed of light. It also highlights the relativity of simultaneity and the equivalence of mass and energy.
5. Is the Special Relativity Spaceship Question just a theoretical concept or does it have real-world applications?
The Special Relativity Spaceship Question is primarily a theoretical concept used to understand the principles of special relativity. However, it has several real-world applications, including the accuracy of GPS technology and the understanding of high-speed phenomena in astrophysics.
