Special triangles and Unit Circles HELP
I have no idea why dextercioby wrote that.In summary, the problem is asking for the exact value of 1/cot(theta) given that sin(theta)= -4/7 and theta is between 3pi/2 and 2pi. Using the unit circle, we can determine that cos(theta)= sqrt(33)/7. Therefore, 1/cot(theta) or tan(theta) is equal to -4/sqrt(33).
aisha
584
If [tex] sin theta = \frac {-4} {7} and \frac {3 pi} {2} < theta < 2 pi [/tex]then determine the exact value of [tex] \frac {1} {cot (theta)} [/tex]
I don't know where to start I know to set up a circle with a cartesian plane but what am I supposed to do? :uhh:
Okay,lemme get it straight...
You're given that
[tex] \sin\theta=-\frac{4}{7} [/tex] (1)
and
[tex] \frac{3\pi}{2}<\theta <2\pi [/tex] (2)
and u're asked
[tex] \frac{1}{\cot\theta} [/tex] (3)
Then the angle is in the IV-th quadrant where the 'sine' is negative and the cosine is positive.
Use the formula
[tex] \sin^{2}\theta+\cos^{2}\theta =1 [/tex](4)
and the fact that 'cosine' is positive to find the 'cosine'.
Then
[tex] \frac{1}{\cot\theta}=\tan\theta=\frac{\sin\theta}{\cos\theta} [/tex](5)
,okay??
Daniel.
Ok how do u know that the angle is in the 4th quadrant? How do u use that formula?? I am way too confused on this one y does it say <theta , 2 pi?
You're given that
and
and u're asked
Use the formula
Then
,okay??
Daniel.
I guess,though u've been working with the trig.circle,u've never made a sign table for 'sine' and 'cosine'.
Besides,the 4-th quadrant is defined by
[tex] \frac{3\pi}{2}<\theta < 2\pi [/tex]
Which formula to use?
Daniel.
ok yes I understand how the angle is in the forth quadrant, how do u use the eqn [tex] \sin^{2}\theta+\cos^{2}\theta =1 [/tex]
?? What do I have to do to solve this question are there any diagrams involved?
That is a second order algebraic eq.in 'cosine' of theta,since u know that the sine is -4/7.Solve it,knowing that u must accept the positive value.
Daniel.
PS.No diagrams,just algebra.
Daniel.
when u say solve what do u mean?? Does -4/7 mean that the opposite is -4 and 7 is the hypotenuse?
Im not sure how to solve for cos?
sin(theta) = -4/7, cos(theta) = unknown.
but you know:
sin^2(theta) + cos^2(theta) = 1
(-4/7)^2 + cos^2(theta) = 1
solve for Cos, and since it's a squareroot you're going to get a positive and negative answer, take the positive answer (since cos's positive in the restrictions given of 3pi/2 < theta < 2pi)
[tex] \sin^{2}\theta=(\sin\theta)^{2} =\frac{(-4)^{2}}{7^{2}}=\frac{16}{49}[/tex]
[tex] \cos^{2}\theta=1-\sin^{2}\theta=1-\frac{16}{49} =\frac{33}{49} [/tex]
[tex] \cos\theta=\pm\sqrt{\cos^{2}\theta}=\pm \frac{\sqrt{33}}{7} [/tex]
U need to chose the plus sign (remember that the angle is in the IV-th quadrant,where the 'cos' is positive)
[tex] \cos\theta=\frac{\sqrt{33}}{7} [/tex]
So now find the tangent.
Daniel.
OR you could draw a right triangle, make one angle theta, and put in 4 as the side opposite theta, and 7 as the hypotonose (since Sin = opposite/hypotonose = 4/7 [change -4 to 4 since you can't have a negative length of a side])
Use pythagorem theorm to find that the 3rd side = radical 33, and see that Cos(theta) = adjacent / hypotonose = radical 33 / 7.
*also keep in mind that cos must be positive since the restrictions given puts it in Q4 where cos is positive. so make cos positive and solve your equation knowing what sin= and what cos=.
*radical means squareroot.
does [tex] \cos = sqrt (\frac {65} {49} )[/tex]?
cos = (sqrt(33)) / 7
your denominator's right, your numerator's not.
I don't know what I am doing wrong? The solution I have is [tex] \frac {-4} {sqrt 33} [/tex]
That's the answer to the problem and it is correct.
Daniel.
lol but I am still stuck :tongue2:
Yeah 1/cot = tan = -4 / sqrt33.
That's correct.
but how do u get that?
Tan = Sin / Cos.
You're given Sin = -4/7
Find Cos.
Sin^2 + Cos^2 = 1
(-4/7)^2 + Cos^2 = 1
Cos^2 = 1 - (-4/7)^2
Cos = SQUAREROOT ( 1 - (16/49))
Cos = Squareroot (33 / 49)
Cos = Squareroot(33) / 7
[You know squareroot of 49 doesn't = -7, and it = 7, because it's in Quadrent 4, where Cosine MUST be positive.]
So now you have: Sin = -4/7, Cos = Squareroot(33) / 7
1/Cot = Tan = Sin/Cos = (-4/7) / (squareroot(33)/7) = -4/squareroot(33)
Get it?
aisha, it's best to draw a right angle triangle, with the hypotenuse being 7 and one of the sides being 4. Using Pythagoras theorem, the other side will be [tex] /sqrt 33 [/tex]
You know that cot theta = 1/(tan theta), right?
So, tan theta = (length_of_opposite) / (length_of_adjacent)
Hence, cot theta = (length_of_adjacent) / (length_of_opposite)
So, cot theta will be [tex] - \frac {/sqrt 33}{4}[/tex]
With what? You were just told that the solution you give is correct.
The way I would approach this problem is:
First draw a picture: a unit circle on a pair of axes.
You are told that theta lies between 3pi/2 and 2 pi and you should know (MEMORIZE) that the axes correspond to 0 (at (1,0), pi/2 (at (0,1), pi (at (-1,0), 3pi/2 (at (0,-1) (and 2pi again at (1,0)). This is a circle with radius 1, diameter 2, and so circumference 2pi- those numbers just measure the distance around the circle.
Theta is between 3pi/2 and 2pi so you should mark a point on the circle between (0,-1) and (1,0) (i.e. in the fourth quadrant as dextercioby originally said). Since points on the unit circle have coordinates (cos(theta), sin(theta)), knowing that sin(theta)= -4/7 tells you that y= -4/7. The equation of the circle is x2+ y2= 1 so you must have x2+ 16/49= 1= 49/49 . That is:
x2= 33/49 and so x= cos(theta)= +&radic;(33)/7 (positive root because x is positive in the fourth quadrant).
Now that you know both sin(theta) and cos(theta) you know that 1/cos(theta)= tan(theta)= sin(theta)/cos(theta)= (-4/7)(7/sqrt(33))= -4/sqrt(33).
As for "where do I use [itex]sin^2(x)+ cos^2(x)= 1[/itex]?", you don't HAVE to use it directly.. I basically used it when I wrote the equation of the circle, x2+ y2= 1, which, since x= cos(theta) and y= sin(theta), is the same thing.
thursdaytbs said:
Tan = Sin / Cos.
Find Cos.
Sin^2 + Cos^2 = 1
Get it?
I Understand this one quite well, the thing is with the diagram Is my hypotenuse 7 and then the opposite side -4?? when I do a^2+b^2=c^2 how come I do not get square root of 33 for the other side? I get square root of 65 how come when we square we are not squaring the negative? Sin is not positive in the forth quadrant. CAN SOMEONE PLEASE TELL ME PLEASE!
1. What are special triangles?
Special triangles are triangles with specific angles and side lengths that have simple and easily calculable values. The two most commonly known special triangles are the 45-45-90 degree triangle and the 30-60-90 degree triangle.
2. How do I use special triangles to find trigonometric ratios?
Special triangles can be used to find trigonometric ratios by using the known values of the angles and side lengths. For example, in a 45-45-90 degree triangle, the sides are in a ratio of 1:1:√2, so if you know the length of one side, you can easily find the lengths of the other sides using this ratio.
3. What is a unit circle?
A unit circle is a circle with a radius of 1 unit, usually centered at the origin (0,0) on a graph. It is used in trigonometry to represent the relationship between the angles and the coordinates of points on the circle.
4. How do I use a unit circle to find trigonometric ratios?
A unit circle can be used to find trigonometric ratios by using the coordinates of points on the circle. The x-coordinate represents the cosine value and the y-coordinate represents the sine value. The tangent value can be found by dividing the sine value by the cosine value.
5. Why are special triangles and unit circles important in trigonometry?
Special triangles and unit circles are important in trigonometry because they provide a way to easily calculate trigonometric ratios for specific angles. They also help in visualizing and understanding the relationships between angles and sides in triangles, which are fundamental concepts in trigonometry.
