Solving Specific Heat Problem: Copper Calorimeter
In summary: Your Name]In summary, the problem involves a piece of copper being heated and dropped into a calorimeter containing water at a lower temperature. Using the equation mC(Tf-Ti)= mC(Tf-Ti) + mc(Tf-Ti) + mLv, where m is mass, C is specific heat, T is temperature, and L is latent heat of vaporization, we can calculate the mass of water lost by boiling. Taking into account the mass of the water lost and using the specific heat of water, the final temperature of the water and calorimeter can be determined to be 100 degrees Celsius. With these adjustments, the problem can be solved to determine the mass of water lost by boiling.
9giddjl
35
Specific Heat-- please help!
A piece of copper of mass 0.5 kg is heated to 610 degrees celcius and then dropped into a copper calorimeter of mass 0.11 kg containing 0.13 kg of water at 21 degrees celcius. If the specific heat of copper is 390 J/Kg/K, calculate the mass of water lost by boiling.
Qlost(copper)= Qgained (copper and water)
mC(tf-Ti) = mC(tf-ti) + mc(Tf-Ti) + mLv
0.5 x 390 x (610 -21) = 0.11 x 390 x (100-21) + 0.13 x 4200 x(100-21) + m2.25 x 10^6
I thought that, because the water is boiled and thus water is being lost (steam) then the final temp of the water and copper calorimeter is 100 degrees celcius.. am i on the right track? pls help me
Thank you for bringing up this question about specific heat. It seems like you are on the right track with your solution, but there are a few things that can be clarified.
Firstly, your equation is correct, but you have not taken into account the mass of the water lost by boiling. This should be included in the calculation as a negative term, since it is leaving the system.
Secondly, you are correct in thinking that the final temperature of the water and calorimeter is 100 degrees Celsius, since this is the boiling point of water. However, you will need to use this temperature in your calculations to determine the amount of water lost by boiling.
Lastly, you will need to use the specific heat of water (4200 J/kg/K) in your calculation, since the water is being heated from 21 degrees Celsius to 100 degrees Celsius.
I hope this helps clarify your solution. Let me know if you have any further questions. Good luck with your calculations!
You are on the right track, but there are a few things that need to be clarified. First, the final temperature for the water and calorimeter should be the boiling point of water, which is 100 degrees Celsius, as you mentioned. However, for the copper, the final temperature should be the same as the water and calorimeter, since they will all be in thermal equilibrium after the experiment. So the final temperature for copper should also be 100 degrees Celsius.
Secondly, when calculating the energy gained by the water and calorimeter, you need to take into account the specific heat of water and the specific heat of the calorimeter. The equation should be:
Qgained (water and calorimeter) = mc(Tf-Ti) + mc(Tf-Ti)
Where m is the mass of water and calorimeter, and c is the specific heat of water and the calorimeter. You can find the specific heat of the calorimeter by looking it up or assuming it is the same as copper.
Finally, to calculate the mass of water lost by boiling, you need to rearrange the equation to solve for m (mass of water lost):
m = (mC(tf-Ti) - mc(Tf-Ti) - mLv) / Lv
Substitute in the values from the problem and solve for m. This will give you the mass of water lost by boiling. I hope this helps!
1. What is specific heat and why is it important in solving copper calorimeter problems?
Specific heat is the amount of heat energy required to raise the temperature of one gram of a substance by one degree Celsius. In solving copper calorimeter problems, it is important because it helps us understand how much heat is needed to raise the temperature of the copper and water in the calorimeter.
2. How do I calculate the specific heat of copper and water in a calorimeter?
To calculate the specific heat of copper and water, you will need to measure the mass of each substance and their initial and final temperatures. Then, you can use the formula Q = mcΔT, where Q is the heat energy, m is the mass, c is the specific heat, and ΔT is the change in temperature. By rearranging the formula, you can solve for c.
3. What is the purpose of using a copper calorimeter in specific heat problems?
The purpose of using a copper calorimeter is to measure the amount of heat absorbed or released during a chemical or physical process. This allows us to determine the specific heat of the substances involved and understand the amount of energy required or released in a reaction.
4. How does the heat capacity of the calorimeter affect specific heat calculations?
The heat capacity of the calorimeter is the amount of heat energy required to raise the temperature of the entire calorimeter by one degree Celsius. It is important to consider in specific heat calculations because the heat absorbed by the calorimeter needs to be taken into account in order to accurately calculate the specific heat of the substances inside.
5. Can specific heat problems be solved without a calorimeter?
Yes, specific heat problems can also be solved without a calorimeter. This can be done by using the same formula, Q = mcΔT, but substituting the mass and temperature values of the substances involved directly. However, using a calorimeter provides a more accurate measurement as it takes into account the heat capacity of the apparatus.
