Specific heat question
  1. Feb 16, 2016 #1
    A copper container (mass: 100 g) holds 200 g of water. The temperature of the container and water is 20°C.
    A 150-g piece of copper heated to 80°C is placed in the water. The water is stirred thoroughly. After sufficient time elapses, to what temperature does the water change? From 1 - 5 below choose the best answer. Assume that no heat is transferred to or from the environment. The specific heat of water is 4.2J/g.K, and the specific heat of copper is 0.4 J/g.K.
    2. Relevant equations
    Q=mc delta t
    3. The attempt at a solution
    My attempt is that since no heat is transfer to or from the environment, the heat lose by the 150g piece of copper is equal to the the heat gain by the copper container and the water in it.
    Let the final temperature be Tf
    Let Q1 be the heat energy lose by the 150-g piece of copper
    Q = mc delta T
    Q1 = 150g x 0.4J/g.k x (Tf - 80°C)
    = 60 Tf - 4800
    Let Q2 be the heat energy gained by the copper container and the water in it
    Q2 = {100g x 0.4J/g.k x (Tf - 20°C)} + {200g x 4.2J/g.k x (Tf - 20°C)}
    = 40 Tf - 800 + 840 Tf - 16800
    = 880 Tf - 17600
    Q1 = Q2
    60 Tf - 4800 = 880 Tf - 17600
    820 Tf = 12800
    Tf = 15.61°C
    The answer is wrong, may I know what's the problem of my answer? @@
  3. Feb 16, 2016 #2
    SteamKing
    Staff Emeritus
    You've assumed the opposite direction of heat flows in the various components of this system.
    For example, take the 150-gram piece of copper which is heated to a temperature of 80 °C and then placed in the water. It is reasonable to assume that Tf in this case is going to be less than 80 °C. Similarly, for the water which has an initial temperature of 20 °C, it would be reasonable to assume that Tf is going to be greater than the initial temperature.
    You need to correct the temperature differences in your equations to reflect these facts.
  4. Feb 16, 2016 #3
    Oh now I get it! How clumsy am I haha, thanks for you help :D
Have something to add?
Draft saved Draft deleted
Similar Discussions: Specific heat question
  1. Specific Heat Question (Replies: 14)
Loading...
