Homework Help: Specific Heat
  1. Jul 18, 2009 #1
    The Earth intercepts 1.27 x 10^17 W of radiant energy from the Sun. Suppose the Earth, of volume 1.08 x 10^21 m3, was composed of water. How long would it take for the Earth at 0°C to reach 100°C, if none of the energy was radiated or reflected back out into space?
    2. Relevant equations
    Q=mc*deltaT
    3. The attempt at a solution
    I just want to make sure that I did this correctly because the answer choices are all similar and vary by degrees of magnitude and I would like to avoid a simple mistake. Multiply the volume by 1000 to get the weight in kilograms, then multiply by 100, the temperature change. Multiply this by the specific heat. So:
    1.27 x 10^17 = 1.08 x 10^24 kg * 4186 * 100
    divide both sides by Q, gives a value in seconds. Convert to years which is approximately 113 years. Is this correct?
  3. Jul 18, 2009 #2
    rock.freak667
    your equation should be
    (1.27 x 10^17)*t = 1.08 x 10^24 kg * 4186 * 100
    But other than that, it looks like it should be correct.
