Heat Capacity: Units, Mols & Avogadro's Constant
In summary, the conversation is discussing the equation for heat capacity for constant volume and pressure, which is Cv = Cp - R. The units for Cp are J/k, and for R they are J/k mol. The question is whether the mol should be eliminated, and if so, if Avogadro's Constant is involved. It is then mentioned that the correct units for Cp are kJ/kgK, which can be rewritten as kJ/kmol*K. The difference between the gas constant and universal gas constant is also mentioned. Finally, the conversation talks about the use of the equation Cp = Q/dT, and an example where Cp is calculated to be 50 J/K.
jimmy42
51
I have the equation for heat capacity for constant volume and pressure.
Cv = Cp -R
So for Cp I have the units J/k and for R the units are J/k mol. So my question is related to that mol. Is it right that I need to get rid of that mol? if so how? Does it involve Avogadro's Constant? Or do I have the wrong units for Cp?
Thanks.
The units for cp is kJ/kgK which can be rewritten as kJ/kmol*k. Although I know that R to be the gas constant and not the universal gas constant.
I have
Where Q is the energy as heat and dT is the change in temp in Kelvin.
Cp = Q/dT
Cp = 100J / 2K
Cp = 50 J/K
So, is that not right? R = molar gas constant.
1. What is heat capacity?
Heat capacity is the amount of energy required to raise the temperature of a substance by one degree Celsius.
2. What are the units of heat capacity?
The units of heat capacity are joules per degree Celsius (J/°C) or calories per degree Celsius (cal/°C).
3. How is heat capacity measured?
Heat capacity is measured by heating a known mass of a substance and measuring the change in temperature.
4. What is the relationship between heat capacity and molar heat capacity?
Molar heat capacity is the heat capacity per mole of a substance. It is directly proportional to the heat capacity and is dependent on the number of moles of a substance rather than its mass.
5. What is Avogadro's constant and how is it related to heat capacity?
Avogadro's constant is a number that represents the number of particles in one mole of a substance. It is related to heat capacity through the molar heat capacity, as the heat capacity of a substance is directly proportional to the number of particles present.
