• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Specifict Heat capacity of Air.
  • Thread starter hhhmortal
What is the the specific heat capacity at constant volume of Air?, with temperature 300k and pressure = 1 atm.
2. Relevant equations
3. The attempt at a solution
Do I assume that this is a diatomic ideal gas and thus Cv = 5/2 ?
Thanks.
mgb_phys
7,744
Try it and see how close you get to the experimental value ?
Cp = 1003.5 J kg−1 K−1
Ok, well I've assumed air is a diatomic gas and that:
Cv = 5/2 R = 20.785
What other equation could I use to work out the precise value of Cv for air?
Mapes
A few issues with that:
1) "Specific" implies per unit mass, not per mole.
2) Air is a combination of gases, not all of which are diatomic.
3) Air is not a perfectly ideal gas.
4) Additional heat capacity arises from diatomic bond stretching.
Depending on how introductory your thermo class is, issues (2), (3), and (4) may be ignored.
mgb_phys
7,744
Cv = 20.7643 J mol−1 K−1 for air at STP, pretty close to an ideal gas
You could re-calculate it assuming 1% Argon (the major non-diatomic consituent of air) but to account for the difference between the nitrogen and oxygen is a much more complicated model.
Ok thanks. I might as well post the whole question because I can't seem to get the right answer.
(Q) Find the thermal conductivity of air under the following conditions:
T = 300 K
pressure = 1 atm
density of air = 1.29 kg/m^-3
coefficient of viscosity is 1.75 x 10-5 Pa.s
Average speed of air molecules is 466 m/s
Mean free path of air molecules is 942 x 10^-10 m
Do I use equation:
Thermal conductivity = [n<v>λ / 3][Cv/6.02 x 10^23]
When I do though, I dont get the correct value....
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
