Calculating Wavelength of H_α for a Receding Star
In summary, we discussed the H_alpha line of hydrogen and the wavelength of a bright red light with a value of 656.1 x 10^-9 m. We then calculated the expected wavelength of the H_alpha line from a star receding with a speed of 3000 km/s, using the formula \lambda=\lambda_o+\frac{\lambda_ov}{c}. This accounts for the doppler shift, which increases the wavelength when objects move away from the observer.
azatkgz
186
One of the most prominent spectral lines of hydrogen is [tex]H_\alpha[/tex] line.A bright red light with wavelength of [tex]656.1\times 10^{-9}m[/tex].What's the expected wavelength of the [tex]H_\alpha[/tex] line from a star receding with a speed of 3000 km/s?
Is it just [tex]\lambda=\lambda_o-\frac{\lambda_ov}{c}[/tex]
I believe that should be: [tex]\lambda=\lambda_o+\frac{\lambda_ov}{c}[/tex]
When objects move away from the observer, the doppler shift, increases the wavelength (red-shifts it).
Sam
where \lambda_o is the observed wavelength, v is the speed of recession, and c is the speed of light?
Yes, that is the correct formula to use. In this case, we can plug in the values given for the observed wavelength (656.1 nm) and the recession speed (3000 km/s) to solve for the expected wavelength of the H_alpha line. This would result in a wavelength of approximately 657.0 nm, slightly longer than the observed wavelength due to the receding motion of the star. This is known as the Doppler effect, where the wavelength of light is shifted due to the relative motion between the source and observer. This can be a useful tool for studying the motion and velocity of stars in our universe.
1. What is the formula for calculating the wavelength of Hα for a receding star?
The formula for calculating the wavelength of Hα for a receding star is given by λ = λ0(1 + v/c), where λ0 is the rest wavelength of Hα (656.3 nm), v is the velocity of the star, and c is the speed of light (299,792,458 m/s).
2. How do you determine the velocity of a receding star?
The velocity of a receding star can be determined by analyzing its spectral lines. By measuring the shift in the wavelength of Hα, using the formula mentioned above, the velocity of the star can be calculated.
3. Why is the wavelength of Hα for a receding star longer than its rest wavelength?
This is due to the Doppler effect, which causes the wavelength of light to appear longer when the source (in this case, the star) is moving away from the observer.
4. Can the wavelength of Hα be used to determine the distance of a receding star?
Yes, the wavelength of Hα can be used to determine the distance of a receding star by using the Hubble's Law, which states that the velocity of a galaxy (or star) is directly proportional to its distance from Earth.
5. How accurate are the calculations for the wavelength of Hα for a receding star?
The calculations for the wavelength of Hα for a receding star can be very accurate if the measurements of the spectral lines are precise. However, errors can occur due to factors such as the resolution of the instrument used, the presence of interstellar dust, and the accuracy of the velocity measurements.
