What is the true relationship between speed and mass?
In summary, as particles in cyclotrons increase speed and approach the speed of EMR, they require more and more energy to continue accelerating. This is because the object's mass increases with speed, as explained by Einstein. However, this does not mean that the mass of the particle actually increases. Instead, it is a result of the particle's perception of spacetime changing as it accelerates. This effect can be calculated using the Lorentz transforms. Ultimately, this is why particles cannot reach the speed of light, because the closer they get to it, the more differently they "see" spacetime and the harder it becomes to accelerate.
  • #36
DW said:
You are talking to a physicist. ME. And I am telling you otherwise.
Perhaps we should ask more than one?
http://www.Newton.dep.anl.gov/askasci/phy99/phy99186.htm
http://www2.slac.stanford.edu/vvc/theory/relativity.html
http://www.cavendishscience.org/bks/rel/mass.htm
http://www.fnal.gov/pub/inquiring/more/light/light_page15.html
http://www.egglescliffe.org.uk/physics/relativity/relmass/relmass.html
http://www.bartleby.com/65/ma/mass.html
  • #37
Those are all layman overviews of special relativity, not advanced modern treatments on the subject. I wouldn't take them as absolute gospel. Take it from a physicist who specializes in relativity: there is no such thing as "relativistic mass" nor is there such a thing as "rest mass". There is only one quantity -- "mass" -- which is invariant in all reference frames.
  • #38
If the mass is constant (as Einstein believed) , then the "something" is connected to the acceleration. When the particle is at rest in the observer's reference frame, it "sees" spacetime the same way as the observer does. However, as it accelerates, it begins to "see" spacetime differently. It undergoes the famous dilations and contractions. How it "sees" spacetime may be calculated using the Lorentz transforms. The faster it goes, the more differently it "sees" spacetime.
Remember that the force is being applied to the particle itself, not to the observers reference frame, so it is the particles system of measuring the universe that counts. So we must use it's PROPER velocity, not its reference frame velocity.This is why, it will get closer and closer to c, but never quite gets there.
DW's great site gives the correct formulas for calculating these things.
Would this be the same as when one is sitting in a car going at a certain speed. To the observer in the car things don't like as fast as to an observer outside the car seeing how fast the car is traveling?
  • #39
The particle sees length and time the same just as if it were at rest. It sees the LAB lengths shrunk and the lab time dilated. And the lab sees IT'S lengths shrunk ant time dilated. And this is a real effect not illusion. For example the lab sees the fast moving particle's lifetime before decay as thousands of times longer than the particle itself experiences, and this enables experiments on the particle that couldn't otherwise be done.
  • #40
Yes, but the proper velocity [tex]U^{i}[/tex] in [tex]p^{i} = mU^{i}[/tex] Is the proper time derivative of coordinate position. As he is saying it is the time according to the particle that is used in that velocity calculation and it is time dilation that then yields the relation [tex]p^{i} = \gamma mu^{i}[/tex]. What is happening is that the law of momentum that the particle obeys is a tensor law expressed by the four-vector equation [tex]p^{\lambda } = mU^{\lambda }[/tex]. This is the frame invariant law for a massive particle. Written explicitly in terms of the definition of four-vector velocity this is [tex]p^{\lambda } = m\frac{dx^{\lambda }}{d\tau }[/tex]. Time dilation yields the factor of [tex]\gamma [/tex] from [tex]dt = \gamma d\tau [/tex] resulting in [tex]p^{\lambda } = \gamma m\frac{dx^{\lambda }}{dt} = \gamma mu^{\lambda }[/tex]. That is where the [tex]\gamma [/tex] comes from, not from the mass. Without the four-vector law as the physics one could not even understand where the mass - rest energy equivalence even comes from because asserting [tex]p^{i} = \gamma mu^{i}[/tex] as the relativistic law and changing the meaning of the word mass to mean [tex]\gamma m[/tex] is not sufficient to imply that [tex]E_{0} = mc^{2}[/tex].
  • #41
This all seems to be a debacle over canonical use of language, not about anything substantive. Some quantities are invariant and some are not. We have to deal with BOTH.
What conceivable harm arises by defining a "relativistic mass" by γm? No, it isn't invariant to a lorentz transformation. No problem. It all worked just fine back when.
  • #42
For example of what harm arises just read the first post in this thread.
  • #43
Dook said in post #1: When particles in cyclotrons increase speed and near the speed of EMR they require much more energy for a further increase in speed. Einstein says this is because the object increases mass with speed.
Well, I reckon those statements are incorrect. The particles don't need more energy; the same amount would increase the speed. And I don't think Einstein said that mass increase prevents acceleration. I think Einstein said that a mass particle reaching lightspeed would be impossible since one would have necessarily raised the particle mass infinitely in doing so. That isn't the same thing as merely accelerating a fast particle.
Increasing a speed to, say, twice the speed has more to do with composition of particle velocities (lorentz boosts) than facts about mass values. A proposed increase of mass helps a little to justify that an equal change in speed is harder to achieve according to an observer who didn't accelerate at all.
  • #44
One more once about mass
DW -- I'm a physicist too, a retired high energy theoretician. Physicist's are pretty smart people, and I doubt many have much difficulty in distinguishing rest mass from realtivistic mass, even if they are a bit sloppy with their language. I note that in the piece by Philip Gibbs he suggests the two "mass camps" are distinguished primarily by semantic notions. See
http://math.ucr.edu/home/baez/physics/Relativity/SR/mass.html,
A very excellent, nonpolemical piece, by the way.
I learned a lot of relativity from Moller's book, including the notion of relativistic mass. I still find a certain stately elegance to his text, and, to the best of my knowledge, he did no damage to my study of physics.
You will note in my previous post that I point out high energy folk tend to use the word energy for relativistic mass -- among other things, the energy approach facilitates covariant mechanics and kinematics, much favored in high energy physics. Not to worry, the mass subversives have yet to make a dent in practical physics. I don't think there is much call for a counter revolution.
Regards,
Reilly Atkinson
  • #45
That is indeed a good piece on the subject of mass dependence upon velocity. I buy the point made that one might need more than one mass variable (longitudinal and transverse). This wasn't a new development but was right there in the decade of special relativity launching. Lorentzian electrodynamics had multiple special mass terms and these punctuated the debates over electron theory and the generation of electron mass during that same time period.
I could be happy if I had a really excellent elementary argument for momentum being m*v*γ. Given that, I can get to the energy-momentum-mass relations. The only elementary arguments I know are tap-ball-into-the-side-pocket-shot elastic action or head-on-cue-balls inelastic action. Or is it necessary to invoke Minkowski spacetime-mathemagic, or fiddle around with making up a suitable special relativity Lagrangian function?
  • #46
q -- In beginning undergraduate courses, profs wave their hands a lot, and say "trust me". In more advanced courses, either an appeal to an invariant Lagrangian, or arguments that make F=dp/dt covariant are standard. Personally, I think working with E&M forces -- Lorentz's q(E + vXB) -- is the most clear. but this is not an elementary approach. Minkowski always seems to hang around with Einstein.
I'd be curious to know of a simpler way to get to relativistic mechanics.
Regards,
Reilly Atkinson
  • #47
"...a simpler way to get to relativistic mechanics."
I wish for this too.
Quart
  • #48
Reilly! How you doing ? Its me, Pete Brown. We used to work together in ther mid 90's in Waltham MA. Its GREAT to hear from you again and to see you posting here. You recall Joe Gibbs right? He used to work with us. He and I used to have this converationm way back even then.
Give me a call or e-mail me. Tonight I'm in the hospital at Brigham and Women's Hospital, Boston, MA, floor 10B room 31. I'm in for a slipped disk. Itd be nice to hear from you, expecially tonight to take my mind of my back. It'd be great to hear from you. Do you still keep in touch with any of those folks from our old workplace?
My e-mail address is pmb61@hotmail.com
Do you recall that problem that I was working on regarding the rotating magnet? Well I solved it.
dw has never been either or able or willing to understand that rather simple statement.
Many relativists use the term "mass" to refer to "inertial mass" (aka "relativistic mass".) A list of such relativists is at
www.geocities.com/physics_world/relativistic_mass.htm
re - "Reilly Atkinson"
I used to work with a gentleman named "Reilly Atkinson" in the early 90's in Waltham MA. Is that you Reilly? Its me, Peter Brown.
By the way, Bernard F. Schutz just published a new book last year and uses the term "inertial mass" to mean relativistic mass
Other well known physicists uses the term "mass" to mean "relativistic mass". In fact even the author of dw's relativity text uses it, i.e. Wolfgang Rindler.
:smile:
Reilly - See www.geocities.com/physics_world and take a look at "On the concept of mass in relativity". I'd enjoy your opinion.
Pete
ps - Again, really cool to see you posting here Rielly. You're sure going to class the place up! :smile:
  • #49
reilly said:
Talk to a particle physicist and, chances are he will say, "Sure, mass increases with speed." Push a little harder, and she will draw the distinction between rest mass and what most of us call relativistic mass -- gamma*(rest mass). But in doing kinematics, energy(kinetic) = gamma*(rest mass), so most of the time we use the term energy for gamma*(rest mass), just as momentum is gamma*v*(rest mass). Physicists are not always as rigorous as they could be with language and math. (When potential energy is involved, things get a little tricky. But all this stuff can be found in any intermediate or advanced text on relativity.) And, of course, the increase in relativistic mass, or energy comes from the work done by the force accelerating the particle.
Regards,
Reilly Atkinson
Particle physicists have their own lingo as do GR'ists, cosmologists etc. For example: If someone were to ask a particle physicist what the mass of a free neutron was he'd tell you 1.008665 u. Ask the very same particle physicist what the lifetime of a free neutron is he'll tell you its about 15 minutes. If that particle physicist does not ask you what speed of the neutron is does that mean that this particle physicist does not believe in time dilation? No. Of course not. It simply means that since you left out the speed then it was assumed to be the intrinsic property, i.e. that which is inherent and thefore d not need clarification.
However not all objects found in nature are particles. To be more general one has to use a second rank tensor to completely describe mass. Especially when you're interested only in part of a system or a system which is not closed.
Pete
  • #50
Pete
Mass does not need clarification of a speed because it does not depend on speed. It is the length of the momentum four vector according to any frame and that length has no speed dependence at all. Even for extended objects mass is not a tensor either. It is still an invariant. You are mistaking a density matrix for a mass, as well as a matrix for a tensor. The dimentions aren't even the same.
