Speed of a boat
  • Thread starter davidge
A boat of mass 1000 kg is moving at 25 m/s. The friction force ##f## is proportional to the speed ##v## of the boat, ##f = 70v##. How many time will take for the boat to reduce its speed to 12.5 m/s?
##\vec{F_r} = m \vec{a_r}##
Since ##f## is proportional to ##v## at each instant ##t##, I integrated ##f## to get the total force.
$$f_{\text{total}} = \int_{v_o}^{v_f}-70vdv$$
the minus sign is because that force is opposite to the movement.
Then, I assumed that the total force equals the mass times the total acceleration. Next, I substituted the value for the total acceleration from the above expression and I used it in the equation: ##V = V_o + at## to get the total time ##t##. Is this correct?
Answers and Replies
haruspex
Insights Author
5,966
f=70v
The 70 has units. The equation ought to be given as f=70v kg/s.
I integrated f to get the total force.
To state your equation in full, ∫f.dv = ∫70v.dv. What is the physical meaning of ∫f.dv? I can't think of one.
Write the differential equation relating velocity to acceleration.
Thanks haruspex.
I think it's actually wrong, because it would give units $$\frac{kg}{s} \frac{m²}{s^2}$$ and this is not Newtons.
The 70 has units. The equation ought to be given as ##f = 70 v \ kg/s##.
Yes, I have forgotten to mention it in the OP post.
Would this be
$$v = \int \frac{d^2x}{dt^2} dt$$
haruspex
Insights Author
5,966
Would this be
That is a general true statement. I meant the DE (not an integral equation) representing the given problem, using the expression for f.
That is a general true statement. I meant the DE representing the given problem, using the expression for f.
Ah, ok.
$$f = -70v = ma \\ \Rightarrow a = - \frac{70v}{m}$$
The problem is that ##a## isn't constant, so how can we substitute it in the equation ##V = V_o + at## to solve for ##t##?
haruspex
Insights Author
5,966
a isn't constant
No, but it has a well-known relationship to v. Remember, we are looking for a differential equation.
Would this be
$$\frac{d^2x}{dt^2} = - 70 \frac{dx}{dt} \\
\frac{dx}{dt} = -70x \\
\Delta V = -70 \Delta x \\
\Rightarrow \Delta t = \frac{\Delta x}{\Delta v} = - \frac{1}{70}$$
haruspex
Insights Author
5,966
Would this be
The first integration stage is fine, except that you should allow for a constant of integration. For the second stage you need to rearrange the equation so that dt occurs on one side and only terms involving x (and dx) occur on the other.
Ok. So, $$ \frac{d^2x}{dt^2} = -70 \frac{dx}{dt} + a_o \\ \frac{dx}{x} = -70dt \\ lnx = -70t + a_ot + c \\ t = \frac{lnx - c}{(-70 +a_o)}$$ where it would remain to find ##a_o##, ##c## and ##x##... I guess ##a_o## could be taken to be equal to $$- \frac{70v_o}{m}$$
haruspex
Insights Author
5,966
Ok. So,##\frac{d^2x}{dt^2} = -70 \frac{dx}{dt} + a_o ##
No, the constant of integration comes in as you integrate, not before.
## \frac{dx}{x} = -70dt ##
That equation is after integration, and then dividing by x. You need to include the constant as part of the integration step, before dividing by x.
Related Threads on Speed of a boat
  • Last Post
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
