Speed of an arrow from a bow
npu
Speed of an arrow from a bow (Latex format)
I am trying to determine the function for the velocity of an arrow out of a bow (leaf spring).
I am talking without considering factors such as air resistance and friction. I came up with:
[tex]
V=\sqrt{ \frac {2F_{av}S_f10}{m_d+ \frac {1}{2}m_fR^{-1}}}
[/tex]
[tex]S_f[/tex]= Spring tip movement in meters;
[tex]S_d[/tex]= Arrow's run in meters;
[tex]m_f[/tex]= Spring weight in Kg;
[tex]m_d[/tex]= Arrow weight in Kg;
[tex]F_{av}[/tex]= Average force exerted by the spring along [tex]S_f[/tex] in Newtons;
[tex]
R=\frac {S_d}{S_f}
[/tex]
Using this formula I got results which appear right:
Overall [tex]V[/tex] appears to be directly proportional to arrow to spring ratios in mass and distance.
Still I am unsure about it. Is it right?
If so, is there a more elegant formulation?
im not exactly an expert, but it seems to me like air ressistance and friction wont be flawing any simpler calcuations too greatly when your talking about the initial velocity, i wouldent even bother with them, mabye again thats because i cant exactly follow your equation, explain how you came up with it, i know i recoginse the format... honestly dont remember from what equation, but tell me how you ahve derived it and ill check over the math once im sure there is no inherent flaw if you dont mind.
2,788
It would help if you provided a derivation of this proof. Can't help you otherwise.
Astronuc
Staff Emeritus
1,563
This problem is being discussed in the Introductory Physics homework section.
https://www.physicsforums.com/showthread.php?t=123957
Not only does one have to consider the mass of the arrow, but also the mass of the spring, which is distributed along the spring.
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
