What is the Speed of Earth on its Orbit During Equinoxes and Solstices?
In summary: The angular speed pattern of the Earth's axis relative to the line between Earth and Sun.When you...The angular speed pattern of the Earth's axis relative to the line between Earth and Sun is what affects the rate at which the time of sunrise or sunset changes from one day to the next.
Yuri B.
137
While the mean speed of the Earth on its solar orbit is about 30km/sec, what is its approximate speed during the both equinoxes and the both solstices ?
Astronomy news on Phys.org
Eccentricity = 0.0167
Winter solstice comes around time of perihelion (fastest speed). Summer solstice is around aphelion. Just a coincidence, precession causes this to change gradually, so this is just how it happens to be in current millennium.
vperi/vap = vmax/vmin = (1+e)/(1-e) = 1.0167/0.9833 ≈ 1.034.
Probably you could google "perihelion speed Earth orbit" and get an exact figure. I don't happen to know. Someone else here may have a better estimate. But on a back of envelope rough guess basis I would say that around winter solstice the speed is about 1.7% faster than average and around summer solstice the speed is about 1.7% slower than average.
You know the average is about 30 km/s, so you can work out the answer approximately.
Thank you. But the difference is so small ? Then I do not understand why the day increase is so different at 23 December and at 23 March, for instance.
Someone else may want to explain why the length of the day changes (that is not orbit speed, it is axis tilt and depends on your latitude, how far north you live)
I googled to get the speed:
Mean orbital velocity (km/s) 29.78
Max. orbital velocity (km/s) 30.29
Min. orbital velocity (km/s) 29.29
http://nssdc.gsfc.nasa.gov/planetary/factsheet/earthfact.html
I probably do not understand your question. Are you wondering why there are fewer days between December 23 and March 23 than there are between March 23 and June 23? the "23" is just approximate here, maybe you would say 21 or 22 in some cases.
That is for a different reason. The sun is at a FOCUS of the ellipse, it is not in the CENTER of the ellipse. So the orbit path is actually longer from March to June than it is from December to March. There should be more days, and there are more days.
I am confused about what you are asking. Someone who understands better will hopefully help explain.
To a first approximation...
The length of the day correlates with the tilt of the north pole either toward the sun (summer in the northern hemisphere) or away from the sun (winter in the northern hemisphere).
The tilt of the north pole is constant but the direction to the sun changes at a reasonably constant rate. The sunward component of the tilt will therefore vary like a sine wave.
At the equinox (when the sine wave crosses the x axis) the sunward tilt will be changing rapidly.
At the solstice (when the sine wave is at a maximum) it will be changing slowly.
That's pretty much a tautology. The first derivitive (if it exists) of an arbitrary function will be zero at any local maximum. If the function is continuously differentiable, the first derivitive will be small near any local maximum.
Yes, thank you I have understood already why day in/de-crease slowly at solstices and do so more rapidly at equinoxes - angular speeds at perihelion/ aphelion vs the other parts of the orbit (do not know the right term) are different, not speed of Earth as I imagined.
Both the speed of the Earth in its orbit and its angular speed are roughly constant (to with a percentage point or so). Neither can account for the entire change in the rate of change in the time of sunrise or sunset from one day to the next.
Close your eyes and draw a wavy line on a piece of paper from left edge to right edge. Look at the slope of that line near one of its extreme points. Look at the slope of that line between successive extreme points. Which slope is shallower? Which slope is steeper.
Then this is due to the angular speed pattern of the Earth's axis relative to the line between Earth and Sun.
When you drew that wavy line on a piece of paper, did you carefully make it match the length of the daylight hours in successive days as a function of time?
Did it nonetheless display the property that its slope was small near the top of each peak and near the bottom of each valley and that the magnitude of its slope was generally larger in between?
Could you, perhaps, conclude that this is then a general property of [suitably smooth] graphs and not a property specific to the graph of daylight length as a function of time?
http://en.wikipedia.org/wiki/Mean_value_theorem
http://en.wikipedia.org/wiki/Maxima_and_minima
http://www.proofwiki.org/wiki/Derivative_at_Maximum_or_Minimum
I think practically and would prefer to draw the actual angles of the selestial planes and axes. Thus, I just imagined the Earth's axis to be paralllel to the axis of the Earth orbit's plane - there would be no season changes on our planet ..
In short, it is all clear, thank you !
1. What is the speed of Earth on its orbit?
The average speed of Earth on its orbit around the sun is about 107,000 kilometers per hour or 67,000 miles per hour.
2. Does the speed of Earth on its orbit change?
Yes, the speed of Earth on its orbit varies throughout the year due to its elliptical orbit and the gravitational pull of other planets.
3. How does the speed of Earth on its orbit affect our seasons?
The speed of Earth on its orbit does not directly affect our seasons. The tilt of Earth's axis is what causes the change in seasons.
4. What factors determine the speed of Earth on its orbit?
The speed of Earth on its orbit is determined by its distance from the sun, the gravitational pull of the sun, and the pull of other planets in the solar system.
5. Is the speed of Earth on its orbit constant?
No, the speed of Earth on its orbit is not constant. It may vary slightly due to external factors such as gravitational pull from other planets, but it remains relatively consistent over long periods of time.
  • Astronomy and Astrophysics
