- #1
Adrian07
- 84
- 1
Am a bit confused about the speed of light being constant, does this mean that whatever speed I am going at, up to and including the speed of light, I will always measure it as going 300000000 mts/sec faster than myself?
Welcome to PF!Adrian07 said:Am a bit confused about the speed of light being constant, does this mean that whatever speed I am going at, up to and including the speed of light, I will always measure it as going 300000000 mts/sec faster than myself?
Are you here talking about the car as an accelerated frame of reference?harrylin said:Now, if you do what you seem to suggest - take your physical system out of your lab and in your car, and measure the one-way speed of entering light rays while you are driving - then you may not find the same value.
Not necessarily so: "clock synchronization" is for each velocity different, so that it isn't a standard reference system anymore (it is not auto-correcting). Therefore I stressed the importance of synchronization at that velocity.Erland said:[..] if the car is moving with a constant velocity wrt the lab system, then, certainly, the speed of light will be measured to c inside the car.
Do you mean that if we put two synchronized clocks at different places in a car at rest, and then accelerate the car up to a constant velocity, then, after the acceleration, the clocks are no longer synchronized, wrt an observer inside the car?harrylin said:Not necessarily so: "clock synchronization" is for each velocity different, so that it isn't a standard reference system anymore (it is not auto-correcting). Therefore I stressed the importance of synchronization at that velocity.
Do you mean that if we put two synchronized clocks at different places in a car at rest, say one clock in the front seat and one in the back seat, and then accelerate the car up to a constant velocity, then, after the acceleration, the clocks are no longer synchronized, wrt an observer inside the car?harrylin said:Not necessarily so: "clock synchronization" is for each velocity different, so that it isn't a standard reference system anymore (it is not auto-correcting). Therefore I stressed the importance of synchronization at that velocity.
Exactly.Erland said:Do you mean that if we put two synchronized clocks at different places in a car at rest, say one clock in the front seat and one in the back seat, and then accelerate the car up to a constant velocity, then, after the acceleration, the clocks are no longer synchronized, wrt an observer inside the car?
Yes, just like sound: the speed of the emitter does not affect the speed of propagation.Adrian07 said:So does this mean if I am emitting the light it will always leave me at c whatever speed I am doing?
I think that the question should be phrased the other way round (often a misunderstanding already exists in the question). Someone who is not moving will still measure that light at c, independent of the motion of the source; that is the second postulate, based on a well established theory of electromagnetism and radiation.If I am moving at say 1/2 c and measure the light to be leaving me at c how can someone who is not moving still measure that light at c?
Probably you mean "time dilation". However, for one-way light speed, the first (and main!) change is a man-made change, as explained in the first section of the paper to which I gave you a link. He explains clock synchronisation. Did you understand it?You mention clocks and I think I read somewhere that einstein said something about time changing how does that work?
Yes, exactly.Adrian07 said:I am having problems with the fact that the speed of light is not dependant on the speed of the source, whereas normally the speed of something is dependant on its source i.e. if I fire a gun the speed of the bullet depends on the speed and direction of the gun although the speed is always the same relative to the gun. Someone standing still will measure the bullets speed as being different to that of the moving person holding the gun. With light I get the impression that both would measure it as moving at c, is this the case?
Doc Al said:Yes, exactly.
You might find the following discussion of special relativity easier to follow: Special Relativity. That's the first lecture in a series that covers all the usual relativistic effects, such as time dilation, length contraction, and the relativity of simultaneity.
One-way speed is the focus of the OP and I usually try to answer the question of the OP. But I fully agree that for a complete beginner it may be better to explain two-way speed of light measurements first (Fowler's lecture mixes them up however).Doc Al said:Sorry, harrylin, but I believe you are making things even more confusing for a beginner by focusing (as you often do) on one-way speed of light issues.
Einstein focused on the one-way speed of light issue in his 1905 paper introducing Special Relativity. His second postulate focuses on the one-way speed of light.Doc Al said:Sorry, harrylin, but I believe you are making things even more confusing for a beginner by focusing (as you often do) on one-way speed of light issues.
ghwellsjr said:Einstein focused on the one-way speed of light issue in his 1905 paper introducing Special Relativity. His second postulate focuses on the one-way speed of light.
Beginners need to understand that when we are talking about measuring the speed of light being equal to c, we are always talking measuring the round-trip speed of light. When we are talking about the one-way speed of light, we are not talking about a measurement but rather an arbitrary assignment, an arbitrary definition, an arbitrary stipulation, an arbitrary assumption, an arbitrary postulate, an arbitrary axiom, according to Einstein.
Look at the OP's question:
He's asking about measuring the one-way speed of light. We have to assume that he's asking about the speed of light in the direction that he is moving, not in the direction from where he is coming from, otherwise, he would have wondered if the light would be going slower than himself.
If we point out to him that if he measures the round-trip speed of light by putting a mirror in front of him (like Einstein discussed in his 1905 paper), he will get the same answer that he will get if he does the same measurement in the opposite direction by putting the mirror behind him. This usually surprises beginners until they realize that it's the same measurement, the only difference being the two directions of light travel happen in the opposite order.
Then they have to realize that it is impossible to know if it takes the same time for the light to traverse the distance to the mirror as it takes for the reflection to get back to the observer and this is where Einstein's arbitrary assignment of those two times being equal comes in. This is where we get the unmeasurable one-way speed of light being equal to the same value as the measured two-way speed of light--it's by assignment.
This is the foundational basis of Einstein's argument for Special Relativity, both in his 1905 paper and in his 1920 book. I don't understand why we should hide this from beginners. It's how the theory began. I support harrylin's focus and if he hadn't been here prior to now, I would have been.
Nobody, certainly not Einstein, said the speeds were different. The point is that we can't know. We can't measure the difference. We can't tell if they are the same or if they are different. We don't know.[/QUOTE]VegaMan said:wait so the speed of the light going to the mirror is not the same as the speed of the light being reflected from the mirror?
With regard to what we can measure, yes, it's only the total distance divided by the total time that always comes out the same.VegaMan said:Only that the total distance over the total time is the same?
No, this has nothing to do with energy or amplitude, only velocity. Have you read Einstein's 1905 paper, especially the first couple of sections?VegaMan said:That kinda makes sense since some energy is lost due to reflecting but I always thought that the amplitude was the lost energy not the velocity
Only the introduction and part 1, the explanation of how to set distant clocks are essential here. And yes, "inertial" is a term that people nowadays use for "Newtonian" or "Galilean" reference systems, which are systems in uniform rectilinear motion ("frames of reference for which the equations of mechanics hold good").Adrian07 said:Have tried to read the link but it seems long winded and difficult to follow. I assume that inertial means moving at a constant speed.
Not always "normally": light is not material, in certain ways it's more like sound or water waves than like bullets. The successful theory on which SR is based (Maxwell's electrodynamics), models light as a kind of wave in space. An essential feature of waves is that their speed c is independent of the motion of the source (to the precision that this has been verified).I am having problems with the fact that the speed of light is not dependant on the speed of the source, whereas normally the speed of something is dependant on its source i.e. if I fire a gun the speed of the bullet depends on the speed and direction of the gun although the speed is always the same relative to the gun.
As answered before: Yes, if you first synchronised your clocks at that velocity.[..] With light I get the impression that both would measure it as moving at c, is this the case?
Perception of speed relative to what?As you keep talking about synchronising clocks does time change somehow relative to the person doing the measurement so changing their perception of speed.
Adrian07 said:So does this mean if I am emitting the light it will always leave me at c whatever speed I am doing? If I am moving at say 1/2 c and measure the light to be leaving me at c how can someone who is not moving still measure that light at c?
harrylin said:Yes, just like sound: the speed of the emitter does not affect the speed of propagation.
First of all, the second postulate distinguishes SR from ballistic emission theories which just couldn't be made to work correctly.rbj said:i have trouble with "just like sound".
it is the case that with both sound and light that the speed of the emitter does not affect the speed of propagation. [..] what must be kept in mind is that the speed of propagation of sound is relative to the medium that sound propagates in. [..]
ghwellsjr said:Nobody, certainly not Einstein, said the speeds were different. The point is that we can't know. We can't measure the difference. We can't tell if they are the same or if they are different. We don't know.
That is correct.VegaMan said:Basically what I'm getting from the first 2 sections of the paper is that In order to synchronize 2 clocks the time it takes light to travel from A to B must equal the time it takes for light to be reflected from B and arrive back at A. Also, that the distance from A to B and B to A (round trip distance) divided by the time it takes light to originate from A, travel to B, reflect off of B, and travel back to A equals the speed of light. This makes sense if and only if the the distance between points A and B constantly remains the same.
That is correct.VegaMan said:My question is that if these are true then, wouldn't that technically mean that no 2 clocks in motion relative to each other could ever be synchronized?
Yes, that's the importance of Special Relativity. Time is relative, space is relative. We now talk about spacetime where space and time are not independent of each other.VegaMan said:And if the speed of light is constant, since v = d/t wouldn't that inherently mean that time and distance would end up being dependent on each other instead of independent variables? when referring to points A and B?
ghwellsjr said:That is correct.
That is correct.
Once you use Einstein's definition of a Reference Frame, any rigid object that is traveling is length contracted along its direction of motion and it's clocks take longer to tick which means they run slower. But if you transform everything to a different Reference Frame moving at some speed with respect to the first one, the speeds of those objects can be different, meaning their length contractions and time dilations can be different and you can always transform to a frame in which any given object is at rest in which case there will be no length contraction or time dilation.VegaMan said:So as you go faster lengths get smaller? Or does time flow faster? or both?
ghwellsjr said:Once you use Einstein's definition of a Reference Frame, any rigid object that is traveling is length contracted along its direction of motion and it's clocks take longer to tick which means they run slower. But if you transform everything to a different Reference Frame moving at some speed with respect to the first one, the speeds of those objects can be different, meaning their length contractions and time dilations can be different and you can always transform to a frame in which any given object is at rest in which case there will be no length contraction or time dilation.
Also, be aware that any object or ruler that is traveling with an object will have the same length contraction and time dilation so any measurement that is performed on a "moving" object with identically moving rulers and clocks will come out the same no matter which Reference Frame is used.
What you're saying is that in some particular Reference Frame, you're traveling at just under the speed of light and yes, everything is normal for you. But, of course, whatever is at rest or traveling at slow speeds in that frame will be traveling at just under the speed of light relative to you so it's not like you can't tell that you are traveling at a high speed.VegaMan said:ok, so if I'm traveling at let's say minutely just under the speed of light. To me, from my perspective, nothing changes. Time and space go on as normal?
How do you watch a beam of light? It's not like watching some kind of projectile traveling away from you for which you shine light on it and the reflected light off the surface of the projectile is what you are actually seeing, correct? Since projectiles travel at a very small fraction of the speed of light, you simply ignore the additional time it takes for the reflected light to get back to you and you approximately "see" the projectile moving away from you.VegaMan said:Or is it actually possible to turn on a flashlight and watch the beam of light slowly extend outward in front of me?
Didn't you start off your post by saying "To me, from my perspective, nothing changes. Time and space go on as normal?" To which I agreed. So even if you had accelerated from being at rest in the Reference Frame and you spent an enormous amount of energy getting to your high rate of speed, it would be just like you were at rest and you would have to start all over again to get back to your high rate of speed. You could repeat this as often as you wish and you'd be no closer to the speed of light than before you started.VegaMan said:Wouldn't time technically stop if i were to reach the speed of light?
Another meaningless question for the same reason.VegaMan said:From my perspective in a fast spaceship that reached the speed of light, would i just instantaneously skip over the speed of light "gap" or interval of time until my speed was reduced to that less than the speed of light?
Not to me and hopefully not to you some day.VegaMan said:man this is some freaky stuff
ghwellsjr said:What you're saying is that in some particular Reference Frame, you're traveling at just under the speed of light and yes, everything is normal for you. But, of course, whatever is at rest or traveling at slow speeds in that frame will be traveling at just under the speed of light relative to you so it's not like you can't tell that you are traveling at a high speed.
But you can't do that with light. What you have to do instead is have some portion of the light beam itself reflect off of other things placed at increasing distances away from you but now you can't ignore the additional time it takes for the reflected light to get back to you. And what will it look like? Since the light is making a round trip, when you turn on the flashlight, it will look like the beam is traveling at one-half the speed of light, do you understand that?
Now because you are traveling in the same direction that the beam is traveling, and light is defined to travel at c in the selected Reference Frame, the beam will be traveling very slowly away from you and then after it hits one of the objects out in front of you, the reflected light will travel back to you almost instantly. Remember how you can't tell if the light takes the same amount of time to go away as it does to come back? This is an example of how you can't tell. As far as you are concerned, it won't look any different than when you are at rest in the Reference Frame and the light takes the same amount of time to go away as it does to come back (by definition, not by observation).
But technically, you can't reach the speed of light, so there is no meaning to your question of what would happen if you were to reach it.
That is correct. It would take you 6.9282 years to get there according to your clock.VegaMan said:ok got it. So hypothetically, suppose we get the technology needed to travel to Proxima Centauri. It's about 4 light years away. We go there and travel from point A (being earth) to point B (being Proxima Centauri) at half the speed of light. Going off what Einstein said, me in the spaceship would perceive time to be traveling like normal, but it wouldn't take me 8 years to get there from MY time.
That is correct. In the common earth/Centauri rest frame, it takes 8 years to get there but it takes 12 years for the earthlings to see you get there.VegaMan said:Back on Earth though it would be an 8 year wait (technically 12 years since the first transmission sent out once the ship reaches Proxima Centauri would take 4 years to get back to earth).
In your rest frame, the distance that Proxima Centauri is away from you is not 4 light years but rather 3.4641 light years.VegaMan said:This sort of doesn't make sense. The distance between here and Proxima Centauri (for the purposes of the example) doesn't change.
Yes, that is correct. Your trip will take 6.9282 years and it will feel like 6.9282 years.VegaMan said:The velocity also does not change (suppose we got a running head start and only wanted to do a flyby of point B). Yet on the ship, both the distance and the time have changed? Is this correct? Could we actually calculate how long the trip would "feel" like on the ship?
Now, if you do what you seem to suggest - take your physical system out of your lab and in your car, and measure the one-way speed of entering light rays while you are driving - then you may not find the same value. However, after you re-synchronize your on-board clocks at that velocity, then you'll have again a standard reference system if you keep approximately an inertial course. Subsequently you'll find again the standard value.
Sorry but I can't follow you. A person who has set up a physical reference system uses as many clocks and detectors as he wants (the system that I referred to uses two clocks, typically as detailed in post #7). That has nothing to do with "altering distances".phyti said:harrylin #3
[..] The observer can't receive the same unidirectional signal he sends (unless he can move faster then light). If he uses a 2nd observer, a 2nd clock is needed and the synchronization problem appears. [..] Do you think it's possible to alter distance by setting a clock?
The concept of aether was important because it was believed to be the medium through which light and other electromagnetic waves traveled. It was thought to be a substance that filled all of space and provided a reference frame for measuring motion.
Several experiments, including the Michelson-Morley experiment, showed that the speed of light was constant in all directions, regardless of the motion of the observer. This contradicted the idea of aether as a stationary medium and led to its rejection.
The rejection of aether led to the development of the theory of relativity, which revolutionized our understanding of space, time, and motion. It also paved the way for the modern understanding of electromagnetic waves and the concept of the speed of light as a fundamental constant.
Some theories, such as the Lorentz Ether Theory, still incorporate the concept of aether as a reference frame for measuring motion. However, these theories are not widely accepted and are seen as alternative interpretations of existing evidence.
While the idea of aether has been largely rejected by modern science, there are still some unanswered questions and mysteries surrounding the nature of light and motion. It is possible that future research could uncover new evidence that may challenge our current understanding and potentially revive the concept of aether in some form.
