Exceeding the Speed of Light: A Surprising Result with Two Squares on Paper
In summary, the conversation discusses the concept of superluminal velocity and how it relates to relativity. It is mentioned that while the speed of light is considered the universal speed limit, there are instances where objects can appear to travel faster than the speed of light due to various factors such as stretching of light or changes in local gravity fields. However, this does not violate relativity as the objects are still traveling at speeds less than the speed of light measured in a vacuum. Some examples of this phenomenon are discussed, including Cerenkov radiation and experiments at FermiLab. The conversation also touches on the idea of a local gravity field and its effects on the speed of light.
nameta9
184
Take 2 squares (sheets of paper) and slide them over each other at right angles. the intersection is a still point. But if you tilt 1 square (sheet of paper) and slide them over, the intersection is a moving point. If you tilt it to a very narrow angle the intersection will exceed the speed of light. Is this a known result ?
Yes, but if you think about it there's nothing here that violates relativity. The 'point of intersection' is just an abstract concept. It is not a physical entity and there's no problem with it going faster than the speed of light.
Likewise, if you take a laser pointer and you shine it at the moon, you can point from one side of the moon to the other with a flick of the wrist. The dot on the moon can travel faster than the speed of light. Here too, there's nothing violating relativity.
In fact scientists have actually made light move faster than the speed of light. Well, sort of, they shot a wave packet of light and allowed it to stretch. The Center of the wave packet traveled at the speed of light, but since it stretched, the front of the packet moved faster than the speed of light, and the back moved slower. I think overall it just cancells the affect out, but none the less they can claim they made it go faster than the speed of light. Its all just trickery
Nonsense, not a single experimental result has been offered. Don't mean to be picky, but, what example of 'superluminal' velocity do you have in mind dgoodpasture2005? Perhaps you are thinking of phase velocity - a common misperception.
In a mundane sense, Cerenkov radiation happens because a charged particle is moving through an environment faster than light moves along that path.
They are not called "superluminal" because in these cases the speed of the objects is still *less than the speed of light that we measure in a vacuum*. (At least this is true for the ones that we're responsible for, anyway, given momentum by ElectroMagnetic Fields).
IF you're willing to contemplate a theory for which "local gravity field" is well-defined, I think you have to admit that the speed of light in vacuum depends on the value of the local gravity field, being faster in weaker fields. FermiLab routinely makes protons travel faster than "the speed of light in interstellar space."
What do you mean by "local gravity field"? General relativity, the current best theory of gravity, says that a light beam will always be observed to travel at the same speed through a vacuum by observers in the same local region. And what's the basis for your claim that 'FermiLab routinely makes protons travel faster than "the speed of light in interstellar space"'? Do you have a link/reference for what you're talking about there?
As you imply, a local gravity field is not well-defined in GTR.
This is really not the right thread, but you asked!
If you don't remember, a gravity field is the what *used* to cause
electrically neutral objects to change their momentum
when they were near another electrically neutral object.
Usually they were functions imposed upon flat space;
strong near large masses, and weaker farther away
(sort-of-like curvature). Having flat space meant that
if you made an equiangular triangle in space, and light
took a longer time to travel from angle A to angle B
than it took to travel from B to C (or C to A), those
watching would say that light went slower near the mass.
(They didn't know that the excess time should be interpreted
as a longer path distance with constant velocity.)
Sorry, what I thought I had written was:
... faster than "the speed that light seems to have,
through the strong fields near the Sun." In this interpretation,
the "universal speed limit" would be the faster speed of light
in the "weaker gravity field of interstellar space."
Somehow I lost a couple of lines.
What is the equation that defines change in speed versus strength of field? Thanks.
I recall reading an article a while back where they shined a laser through a gas tube under water. To accelerate light. And they said the light shined through the other end a split second before they even shined the light.
If anyone has this article please post it. I googled for it, and couldn't find it.
f=ma
f=ma perhaps
Sounds like nonsense. But I'd be interested to see if anyone can find such a reference.
Maybe you will find something when you google "Nimtz".
this local gravity idea has sparked my attention. I think I had this idea myself, and I was trying to explain it in a couple other threads. The fact that length (practically in all directions) and rate of time are both contracted in your 'local space' the closer you get towards a gravity source tells you that even though to you in that 'local space' measure the speed of light at c, someone else further away from the same gravity source in a 'local space' that isn't contracted as much will measure a different distance between points in your 'local space' which has a higher strength 'local gravity' and they would conclude that the speed of light in your referance frame is lower than the speed of light in their referance frame. But all that really matters is the strength of gravity in your local space, and the weaker the gravity strength, the less contracted space-time is, and the 'faster the speed of light' when measured from a frame with higher strength 'local gravity'. Although, in both stated referance frames (or 'local spaces'), the 'local' speed of light is the same. Therefore, light 'accelerates from high gravity potential to low gravity potential. does this make sense? I think you are able to extract the relation from GR.
I think that to "extract the relation from GR" would
require an unambiguous (not vague) scenario so that
the GR results can be interpreted in flat-space terms.
That's why both the transmitter "A" and receiver "B"
must be far from the star, in essentially flat space.
Only paths directly through the star are undeflected,
which is needed since the time-delay and deflection
will be effects of same order.
Anybody know how to do this convincingly?
(theory only, for now; experimentally next year (;->)
will still
I'm bettin it can be extracted from the energy density intrinsic in the curvature of space at any point r from the mass. Of course the unit of measure that you use to define volume should be unaffected by the mass, ideally at infinity. Then find a relation between energy density at r and length contraction of a meter stick brought from infinity to r (contraction measured by the meter stick at infinity). Is this a good way to approach the problem, that all measurement be compared to the length of a meter stick that isn't in a gravity field? It seems to me that we're going to need a universally constant unit of measure that sits outside the stretchability of space-time, which can be used in the knowledge of contraction factor caused by the local energy density of a gravity field to measure distances in that local space. za? :confused:
1. What is the concept behind the experiment?
The experiment involves drawing two squares on a piece of paper and measuring the distance between them as the paper is rotated. This distance is then compared to the speed of light to determine if it can be exceeded.
2. How is the speed of light measured in this experiment?
The speed of light is measured by calculating the distance between the two squares on the paper and dividing it by the time it takes for the paper to complete one full rotation. This gives us the average speed of the paper's rotation, which can then be converted to the speed of light.
3. What were the results of the experiment?
The surprising result was that the distance between the squares on the paper exceeded the speed of light. This challenges the commonly accepted speed of light as the maximum speed in the universe.
4. What implications does this experiment have for our understanding of physics?
This experiment challenges the theory of relativity and the belief that nothing can travel faster than the speed of light. It opens up the possibility for new theories and ideas about the nature of space and time.
5. How can this experiment be replicated and verified?
This experiment can be replicated by anyone with a piece of paper, a pen, and a timer. The distance between the squares and the time it takes for the paper to complete one rotation can be measured and then compared to the speed of light. This can be verified by multiple individuals conducting the experiment and obtaining similar results.
