Speed of Light Logic: Flaw Explained
In summary: You can also try this:In summary, if you travel in a material at the same speed as the speed of light, you will see the light basically stationary so you see a constant electric field. But light has both electric and magnetic fields, so this is impossible.
Silviu
624
Hello! My question is: If you travel in a material at the same speed as the speed of light (I assumed this is possible due to the existence of Cherenkov radiation) you will see the light basically stationary so you see a constant electric field which means no magnetic field. But light has both so this is impossible. What is the flaw in my logic? Thank you!
This doesn't sound right. Can you show your work?
You move at the same speed as the light. Let's assume that you see the electric field to have a value ##E_0##. In your frame that value will not change, as the speed of the electric field, is the same speed as the light (obviously). You can imagine you "sit" on the electric field on one of the crests - maximum amplitude - so as you move at the same speed as the electric field, you conclude that there is no oscillations of the electric field (you don't feel like going up and down on the wave). So if you see no variation of the electric field and laws of physics must hold in your frame of reference, there is no source for a magnetic field. Is there something wrong with this?
You're ignoring the medium. If the light is traveling in a medium, then the light by itself does not satisfy Maxwell's Equations (which is what you are using to deduce that there is no magnetic field if the electric field is stationary). Only the total system, light plus medium, satisfies Maxwell's Equations. (And in general, dividing things up into "light" plus "medium" is arbitrary in such a case.)
Well, yes you have in-medium electrodynamics, and it can be formulated in a covariant way (already Minkowski did this). The usual in-medium edynamics you learn in the EM lecture is linear-response theory close to equilibrium of the matter. It's very clear, how the fields ##(\vec{E},\vec{B})## (or ##F_{\mu \nu}## in the four-vector formalism) transform under Lorentz transformations, and indeed they transform as the microscopic fields do. This already tells you that the Lorentz boosted fields of the usual plane-wave solutions in the rest-frame of the medium cannot be a static field, but are still plena-wave solutions.
Yes, you didn't show your work, just some hand waving.
Showing your work would be to take a plane wave solution in a medium, boost both the field and the medium, and show that the result behaves as described.
This is along the lines of what @vanhees71 suggests above, and I think his description of the result sounds correct.
1. What is the speed of light logic flaw?
The speed of light logic flaw refers to the assumption that the speed of light is a constant and is not affected by the motion of the source or observer. This assumption is based on Albert Einstein's theory of special relativity, but it has been disproven by experiments and observations.
2. How does the speed of light logic flaw affect our understanding of the universe?
The speed of light logic flaw has significant implications for our understanding of the universe. It challenges the concept of a universal frame of reference and the idea that the laws of physics are the same for all observers. It also raises questions about the accuracy of measurements and calculations based on the speed of light.
3. What evidence supports the existence of the speed of light logic flaw?
There have been numerous experiments and observations that support the existence of the speed of light logic flaw. One of the most famous is the Michelson-Morley experiment, which showed that the speed of light is the same in all directions, regardless of the motion of the Earth. Other evidence includes the observations of aberration and the discovery of the cosmic microwave background radiation.
4. How does the speed of light logic flaw impact the development of new technologies?
The speed of light logic flaw has a significant impact on the development of new technologies, particularly in the field of space travel. It means that our current understanding of the laws of physics may not be accurate, and we may need to revise our calculations and theories. This can also have implications for communication systems and satellite operations.
5. Is there a solution to the speed of light logic flaw?
There is ongoing research and debate about potential solutions to the speed of light logic flaw. Some theories propose modifications to Einstein's theory of relativity, while others suggest completely new theories of physics. However, there is no consensus yet on a definitive solution, and more research is needed to fully understand the implications of this flaw.
