Light Speed: Massless Particles, Unchangeable Velocity
In summary, according to Warren, the speed of light is arbitrary and can be changed if we use different units. Maxwell's equations predicted that the speed of electro-magnetic waves was independent of any motion, and this was later verified by Michelson and Morley.
piercas
1,141
Where does the speed of light (~300000km/sec in vacuum) come from
Is this the rotational speed of an electron. Up to Einstein a photon has no mass once it is in movement.
Is the absence of mass the reason why speed of light cannot be modified ?
Science news on Phys.org
From Maxwell's equations we have :
[tex] c = \sqrt { \frac 1 {\mu_0 \epsilon_0}}[/tex]
Where
The permeability of free space is
[tex] \mu_0 = 1.26 x 10^{-6} \frac H m [/tex]
and the permittivity of free space is
[tex] \epsilon_0 = 8.85x10^{-12} \frac F m [/tex]
These 2 constants are fundamental properties of space.
What do you mean by "the fundamental properties"?
I know speed of light can be slowed down (ex.water) but what is the origin of that 300000km/sec and why lightspeed is constant. Is there a physical reason for that
The speed of light is arbitrary. Why? Because the units we use to measure it are arbitrary.
It is 300,000 km/sec simply because of the way we defined the kilometer and the second.
We can make c equal to any number we like, if we select appropriate units. If we choose to work in units of years and light-years, for example, c is 1. Many people use this convention to simplify their calculations.
- Warren
- Warren
Just a personal opinion, but I think "simplifying calculations" short-chanegs the notion of natural units. They actually make the physical theory geometrically intiutive and elegant, which hints at a deeper mechanism which is at work.
The speed of light is not really slowed down in water. It takes more time for light to get through water (and all other transparent objects) due to the fact that the photons are forced to interact with the atoms and molecules of the substance. Light still travels at the same "c" in the space between each atom.
One way to think about what the limit is due to has to do with the aforementioned permeability and permittivity constants:
[tex]{\epsilon_0}[/tex] and [tex] {\mu_0} [/tex]
The first is a property of space that indicates "the ability for an electric field line to establish itself across a vacuum." THe second is the same thing for a magnetic field line. SInce light is electomagnetic in nature, then the limitations for the electric and magnetic fields must determine the limitation of the speed of light.
NOte: this description is ultimately flawed in its simplicity, but hey, if it could be explained in one paragraph, what's college for?
It means that those values are experimental in the case of the permittivity and geometrical for the permeability. These 2 constants define how electromagnetic fields interact in free space.
In 1867 Maxwell cast his system of equations into the form of the wave equation. The constant I posted above was the theoretical speed of the waves predicted by this formulation.
It was this prediction that set the world of Physics on its ear for the next half century. Up to that point all velocities were believed to obey the Galilean transforms, that is, the velocity of a body always depended upon the velocity of the source. Here was the velocity of electro magnetic waves which appeared, according to Maxwell, to be independent of ANY motion, it was simply determined by the fundamental properties of space itself. This came to be known as Maxwell Conundrum, many waited for Maxwell to find his error. Others, famously, Michelson and Morley, set out to prove Maxwell wrong, experimentally. Instead of proving him wrong, they conducted the most famous "experiment that failed" and verified experimentally that the speed of light was independent of the Earth's velocity.
If you are concerned why c has the number 3 x 108 m/s, then look at Chroots answer. If you are concerned with why it is constant then you must start by understanding Maxwell's equations, and the Partial Differential Equation called the Wave equation. If that still does not satisfy you, and you still want to know why, we must answer that we do not know why. Physics does not address why, we can only model what is.
i agree that the units are arbitrary [my favorate is the pascal ^_^], but that doesn't mean the speed of light is arbitrary. defining the speed would be arbitrary, but it doesn't travel any faster or slower [in the same medium] depending on the units used.
or, like the tshirt goes : ~3.00x10^8ms^-1 : its not just a good idea, its the law :)
1. What is light speed and how is it measured?
Light speed is the maximum speed at which all massless particles, including photons, can travel in a vacuum. It is measured to be approximately 299,792,458 meters per second, or about 670,616,629 miles per hour.
2. Why is light speed considered to be unchangeable?
According to Einstein's theory of relativity, the speed of light is a fundamental constant in the universe and cannot be changed. This is because the speed of light is directly related to the fundamental properties of space and time.
3. Are there any exceptions to the constant speed of light?
No, the speed of light is constant and the same for all observers, regardless of their relative motion. This is known as the principle of relativity and has been repeatedly confirmed by experiments.
4. How does the concept of light speed impact our understanding of the universe?
The constant speed of light has significant implications for our understanding of the universe. It allows us to accurately measure distances and time, and has led to the development of the theory of relativity and other important scientific theories.
5. Is it possible for anything to travel faster than light?
According to our current understanding of physics, it is not possible for anything to travel faster than the speed of light. As an object approaches the speed of light, its mass increases infinitely, making it impossible to reach or exceed light speed.
17K
