Speed of Light
  1. Jul 31, 2008 #1
    I've always been terribly confused as to the logic behind why the speed of light is a constant. Say for a moment that you have a photon that's traveling along a radio wave at the speed of light. Then you have another photon traveling along a gamma wave at the speed of light. Now, assuming that they both have to travel the same distance under the same conditions, and started at the same time, why will they arrive at the same time. I always thought that the photon traveling along the radio wave would arrive first. This is because the periods on the radio wave are shorter, and the wave itself is "straighter". Wouldn't this mean that the radio wave is a more direct path-which implies less distance. And if that were true then the photon that was on the radio wave would arrive first? Please understand that I have an extremely limited background in physics, and no understanding of any of the theories on light. This is just a question that I emailed to my school chemistry teacher (we don't have a physics one) and they couldn't answer.
  3. Jul 31, 2008 #2
    Staff Emeritus
    Photons do not follow a wave like path. One way to visualize a photon is as a wave packet. A envelope which contains the waves composing the frequency of the photon. So the photon travels straight while oscillations occur at the frequency determined by the energy of the photon.
  4. Jul 31, 2008 #3
    Do louder noises travel faster than quieter ones? Nope. And yet they have a bigger amplitude in their "wave".
    A wave is just something that has an oscillating amplitude basically. Look up "wave particle duality".
  5. Jul 31, 2008 #4
    As integral said photons are not like waves on a string.
    A usefull picture is a flashing light on a police car, suppose the blue light flashes twice per second as the car comes toward you, alongside is a fire engine with a red light flashing once per second - but they are both going at the same speed.
    Now imagine painting a mark on the ground next to the car each time the light flashes, the distance between the marks is the wavelength. The spacing depends on the frequency and speed, the gaps between the fire engine's marks would be twice as large. The frequency is half as much and it's wavelength is twice as long.
  6. Jul 31, 2008 #5
    Wow, that is an ingenious way to describe it, mgb_phys!
  7. Aug 5, 2008 #6
    Perhaps you could elaborate on the word packet. Is this a substantive packet, ie does it have material form. If so how can it not have mass. If not then what exactly is the means by which energy is transmitted? What is it that is oscillating?
  8. Aug 5, 2008 #7
    It's a little hard to explain here. You might want to pick up an intro freshman physics textbook for a clearer explanation.
  9. Aug 5, 2008 #8
    The problem is that the freshmen physics textbooks do not really address the question.
    Either the photon must have substantial form, in which case how to explain that it has no mass, or the environment in which it is moving is the cause of its existence, but this is to re-invent the ether by another name.
  10. Aug 5, 2008 #9
    Why are these the only two options you allow?
    Energy is (rest)massless, yet it travels through vacuum.
  11. Aug 5, 2008 #10
    The question is how does it do so?
  12. Aug 5, 2008 #11
    I've been looking up "photon frequency" on Google and what I've come up with is that the frequency of light is really the vibrating of the photon, that this vibrating is a form of energy, the measured wavelength of light is really a measure of how quickly the photon is vibrating, and that degree of this vibration is determined by whatever is emitting the photons.
    Is this right? If so, is the vibration of the photon the same phenomena as the vibrations of a heated atom?
  13. Aug 5, 2008 #12
    Staff: Mentor
    No. Photons are not like normal particles. They can't be viewed as descrete particles that are vibrating. But they have a frequency/wavelength.
  14. Aug 5, 2008 #13
    So what is vibrating ?
  15. Aug 5, 2008 #14
    "Something vibrating" is a very simplistic "macro" concept of waves. Light (more generally, electro-magnetic fields) satisfies the wave equation. That is sufficient.
    But, russ, according to quantum theory, not just photons but any sufficiently small "particles" have wave properties.
  16. Aug 5, 2008 #15
    Staff: Mentor
    I realize that -- though isn't it any particle of any size has wave properties?
  17. Aug 5, 2008 #16
    That tells me what photons are not.
    My question is what are photons?
    It comes back to the question: what is vibrating, is it the photon that has substance or is it the environment?
    The former poses the problem of how then the photon has zero mass, and the latter faces the problem that it is the ether by another name - and the ether has been shown not to exist.
  18. Aug 5, 2008 #17
    I think photons are vibrating "virtual" electron-positron pairs because of the fact that high energy photons decay in an electron and a positron, if passing strong electric field, for example highly charged atomic nucleus. Vice versa electron and positron convert into photons.
  19. Aug 5, 2008 #18
    They cannot be described in natural, human-scale terms. We do not have macroscopic counterparts to phenomena at the atomic, subatomic or photonic scale.
    We will find that the only meaningful answer to your question is the mathematical equation that describes it. Any attempt to convert it to more comfortable words will, by definition, cause some degree of loss in the translation from equation to descriptive "model".
  20. Aug 7, 2008 #19
    I've heard that Einstein stated that nothing can exceed light in terms of speed as it will require infinite energy to further increase the speed once the speed of light is achieved.My doubt is originating from the fact that light itself is made up of particles called photons(which i assume have mass....no matter how small)...so how come these particles called photons travel at such a high speed...nd why there cant be any other particle wid mass a millionth fraction of these photons and speed more than light...?
  21. Aug 7, 2008 #20
    but wont that mean ki photon photons have mass...a finite mass...?
