Uncovering the Mystery of Constant Velocity
In summary, while the speed of light appears to be the same in all directions, it is actually slowed down by the surrounding medium
monty37
225
if, a particular body rotates ,with a certain velocity
then every particle of that moves with the same velocity as that of body.if
the Earth is moving at a velocity,we also move with same velocity daily .
for eg:the speed of light was discovered to be 3x10^8m/s wrt to earth,but is it the same everwhere,including outer space??
Science news on Phys.org
My understanding is that the speed of light is the same everywhere and has been the same since the beginning. There is some speculation that the speed of light may have been different in the past but no observational evidence exists.
well but when speed is calculated ,sitting on Earth it varies,right,relative velocity!
but in space it is different
I accept the speed will differ in space. because the speed of the light is not same when it travels in different mediums so this may differ in space as well.
The speed of light in a vacuum is invariant. It is measured to be the same by everyone regardless of their relative motion. For example, a beam of light traveling past the Earth will have a measured relative velocity of 3e8 m/s wrt to the Earth as measured by the Earth, but an observer flying past with a speed of 1.5e8 m/s relative to the Earth will measure that same beam of light as having a relative velocity of 3e8 m/s wrt to himself
The historical measurements of the speed of light indicate that it dropped by about 100 kilometers per second from 1880 to 1980. See http://www.sigma-engineering.co.uk/light/lightindex.shtml
This drop is nearly within experimental error, and is probably due to experimenters fudging their numbers until partial agreement with other measurements was obtained.
Light always travels at a constant speed of a bought 2.99*10[tex]^{8}[/tex] m/s.
The only reason that it would appear to travel slower when traveling through matter is because, photons excite the adjoining particles that in turn transfer the energy to the neighbor.
The time it takes for the light to be absorbed and then transfer out again is what would make light seem slower than in a vacuum.
This has to do with special relativity. You should google on the Michelson Morley experiment. It is an experiment in around 1900 I believe, where they basically tried to measure different speeds of light in different directions.
Agreed, the Michelson-Morley experiment is proof that the speed of light is invariant to the motion of the observer.
how do you say michelson's experiment is a proof,it was conducted on earth,and was found to be 3x10^8. Do we have any other experiment whose value for speed of light
coincided with michelson's.well,consider the light rays emitted from stars,in space
,they won't travel with speed-3x10^8,they would vary ,due to relative velocity.
Not true, the speed of light is absolute. In other words the speed of light is always c irrespective of the relative motion of the observer and the emitter (as Janus has already said).
In terms of experimental verification, see here: http://math.ucr.edu/home/baez/physi...ts.html#3. Tests of Einstein's two postulates
The only thing that varies is the frequency of the light (Doppler effect), which is dependent on the radial velocity of the stars with respect to earth. The frequency of the light decreases for receding objects (redshift) and increases for approaching objects (blueshift).
so according to what you say,anywhere in the universe,any object
acting as a light source would emit and will emit light at the speed of
3x10^8m/s.
3x10^8m/s.
Yes. And that speed will be constant and have the same value as measured by any locally inertial observer.
3x10^8m/s.
yes - this is exactly the weird thing about reality that made special relativity so hard for people to accept at the time (100 yrs ago now).
also, aside from the MM experiment, the invariance of light speed (constant c) can be inferred from the Maxwell equations. I think that's what Einstein said he was doing (and the basis for his statements that he didn't hear about MM experiment until later).
If you are interested in this (as you appear to be) get yourself a book on special relativity that's written for someone with your background, and have a go at it.
Michelson-Morley is not about proving that the speed of light is c, it proves that it is invariant to the frame of motion. It addresses your assertions in the OP.
*First time poster*
I'm not too clued up on things of this nature and so thought I'd ask a question.
If extreme gravity can bend light then can it speed it up or slow it down?
JimboLittle said:
*First time poster*
No, since the speed of light is constant according to special relativity.
Welcome to the forums, by the way!
The reason I ask is that if gravity can have an effect of the physical elements within light regarding its direction, then might it be possible for it to affect its speed in a straight line?
I understand the idea of the speed of light being constant, though I can't help but wonder.
Thanks for the welcome, and for the speedy reply.
The basic idea of general relativity is that masses create curvature in space-time. So although the path of the light looks bent to us, it's actually following a straight path (geodesic) in space-time. So masses change space time, which affects the path of the photon that travels through it, but not the speed.
I know it's odd, but that's why I like physics :)
So then what about black-holes?
They appear black because the gravitational field is too strong for light to escape (correct me at any point, as I said, not too clued up!). Does this mean that any light which reflects reflect off the surface of the body is slowed to a stop and then pulled back in?
Once an object reaches the event horizon or a black hole no more light reaches outwards to any possible viewer because the gravity is too strong for light to leave. Any light reflected off what would be the rear of any object sent in would not appear because it is slowing, and being drawn back to the centre-mass. Thoughts?
With respect to what observer?
And for the others?
I'm not sure what you mean by light that reflects off 'the surface' (what surface?).
And for the others?
According to special relativity the speed of light is the same for all inertial observers regardless of the motion of the source.
but JimboLittle is asking about gravity => general relativity
The surface of the object crossing the event horizon. Surely if no more light can escape due to the gravitational field being too strong it must head back towards the surface of the body.
if somone was in a spaceship going 99.99c, say someone onboard was to play ping pong, how would it look to an observer on earth?
and if we do the opposite, how would someone on Earth playing ping pong look to an observer going 99.99c?
Watching the ping pong game would be pretty boring. With a gamma of 70.7, it would be about 1 minute between each ping and pong, almost time enough to run into the kitchen for a snack. I would rather watch a game of ping pong in one of NASA's astronaut centrifuges going at about 5 G.
You would probably confuse the spaceship with a photon :tongue:
A minor quibble, 99.99c is impossible, perhaps you meant .9999c ?
The only change would be that the images would be severly red shifted.
Yet another minor quibble, the speed of light is ASSUMED constant by SR, so it cannot be used as a justifcation of the constancy of c. You need to refer to Maxwells Equations to get that.
  • #31
In my opinion, it can be used to show that c must be constant since the theoretical implications of the constancy of c are discussed in SR, and they turn out to be empirically correct. But it's not worth a discussion :smile:
1. What is constant velocity?
Constant velocity is the rate at which an object moves in a straight line without changing its speed. It is a measure of how fast an object is moving in a specific direction.
2. How is constant velocity different from average velocity?
Constant velocity is the velocity of an object at a specific moment in time, while average velocity is the total displacement of an object divided by the total time taken. Constant velocity means that the object is moving at the same speed and in the same direction throughout its motion, while average velocity can vary if the object changes its speed or direction.
3. What factors affect constant velocity?
The two main factors that affect constant velocity are the mass of the object and the force acting upon it. Objects with a larger mass require more force to maintain a constant velocity, while objects with a smaller mass can maintain a constant velocity with less force.
4. How is constant velocity measured?
Constant velocity can be measured using a variety of tools and methods, such as a stopwatch, a motion sensor, or a speedometer. The distance traveled by the object in a given time can be used to calculate its velocity.
5. Why is understanding constant velocity important in science?
Constant velocity is an important concept in science because it helps us understand the motion of objects and how they interact with their environment. It is also a key component in many scientific principles and laws, such as Newton's First Law of Motion and the Law of Inertia.
  • Other Physics Topics
9K
  • Astronomy and Astrophysics
