What are the speeds of molars and premolars going down in a compression test?
  • Thread starter marialaarni18
  • Tags
    Speed Teeth
In summary, to calculate the speed of molars and premolars going down in the given scenario, the parameters that should be measured are the distance between the pivot and the molars, the distance between the pivot and the premolars, the distance between the upper and lower molars, the distance between the upper and lower premolars, and the time of closure for both the molars and premolars. These measurements can then be used to calculate the speed of both the molars and premolars using the compression rate.
marialaarni18
How to calculate for the speed of molars and premolars going down. Lower jaw is stationary or don't move. Only the upper jaw, goes down. Upper jaw and lower jaw are connected by a pivot. The jaw was attached (the upper and lower part ) in the instron machine, with a load (2000 N) going down that pushes the upper jaw downwards. What parameters should I measure in order to derive this?
Given:
distance between the pivot and premolars= 78.3 mm
distance between the pivot and molars= 56.5 mm
I also measured the following:
distance between upper and lower molar= 21.85 mm
distance between upper and lower premolars= 23.23 mm
I conducted compression test with compression rate of 1 mm/sec
length of time of closure of molars= 33.03 sec
length of time of closure of premolars= 26.25 sec
Using the data above, I calculated the speed of the molars and premolars going down. The speed of the molars going down is calculated by: Speed of molars = (distance between upper and lower molar / time of closure of molars) x compression rate Speed of molars = (21.85 mm / 33.03 sec) x 1 mm/secSpeed of molars = 0.66 mm/sec The speed of the premolars going down is calculated by: Speed of premolars = (distance between upper and lower premolars / time of closure of premolars) x compression rate Speed of premolars = (23.23 mm / 26.25 sec) x 1 mm/secSpeed of premolars = 0.88 mm/sec
What is the "Speed of Teeth Going Down"?
The "Speed of Teeth Going Down" refers to the rate at which teeth move or shift within the mouth. This can be affected by factors such as age, genetics, and dental treatments.
How is the "Speed of Teeth Going Down" measured?
The "Speed of Teeth Going Down" can be measured using various methods, including dental X-rays, dental models, and digital scans. These methods allow for accurate measurements of tooth movement over time.
What factors can affect the "Speed of Teeth Going Down"?
Several factors can influence the "Speed of Teeth Going Down," including genetics, age, overall health, and dental treatments. Additionally, habits such as teeth grinding or jaw clenching can also impact the speed of tooth movement.
Can the "Speed of Teeth Going Down" be accelerated?
In some cases, the "Speed of Teeth Going Down" can be accelerated through orthodontic treatments, such as braces or clear aligners. These treatments apply gentle pressure to the teeth, causing them to shift at a faster rate.
Is the "Speed of Teeth Going Down" the same for everyone?
No, the "Speed of Teeth Going Down" can vary greatly from person to person. Factors such as age, genetics, and oral health can all play a role in how quickly teeth shift within the mouth.
9K
  • Astronomy and Astrophysics
12K
