Spherical Conductor
  • Thread starter jayz618
jayz618
27
A Spherical conductor has an Electric field near its surface of 180 volts per inch.
How much charge (in Coulombs) is on the sphere ?
How many excess electrons are on the sphere?
Will the air around the sphere break down and produce an arc ?
Well, I assume Gauss Law is going to be used
E= Ke ( q / r2)
isolated sphere:
C = 4πε₀r in Farads
ε₀ is 8.8542e-12 F/m
r is radius in m
Well, I haven't really been able to start getting anywhere with it, but a few things I know.
That once I am able to determine the total charge of the Sphere, I will be able to calculate the amount of excess electrons with simple math.
It seems to me that we would need to know the size of the sphere in this situation.
Answers and Replies
lightgrav
1,248
30
well, you can answer #3 already, because the E-field is given.
You're right that the _numerical_ answer to #1 will depend on the size of the ball.
They might want you to derive a _formula_ for Q , as a function of R ;
Physics 2 questions do this a LOT more often than Physics 1 questions .
on the other hand, that would make #2 quite peculiar.
jayz618
27
I wrote the question exactly as it reads.
I dont understand what I can really do only given one known value.
jayz618
27
Anyone have any suggestions ?
lightgrav
1,248
30
Yes, use Gauss! convert units to V/m , and obtain Q as a function of R .
then answer #3 .
skip #2 , unless you want to email your instructor and ask what the sphere radius is.
jayz618
27
Ok, so I converted 180 Volts/in and came out with 7086.61 Volt/meter.
7086.61 = 8.99x109 ( q / r2) ?
Do I know what q is ?
I think ive confused myself.
lightgrav
1,248
30
Gauss' Law situations typically yield a _surface_charge_density_ "sigma".
When your teacher tells you the radius, then you tell them |Q| .
When your teacher tells you the DIRECTION of the Electric field,
you can tell them the SIGN of the charge ... right?
If you know Q , do you know how to get the number of excess electrons?
Is there a diagram with this question, showing the size R and direction of E ?
jayz618
27
No, there is no diagram along with it. It reads exactly how I wrote the original question.
lightgrav
1,248
30
It is INCOMPLETE, then . Quit wasting time on it.
do you know the answer to part#3 ? if so, move on.
jayz618
27
The problem is, that it is a take home test and he said we were allowed to use any external source we want.
I emailed another person in my class to see if he is having the same problem.
Suggested for: Spherical Conductor
  • Last Post
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
