Spin half in rotating field
  1. Aug 6, 2011 #1
    A question given by my professor. Already solved three section and need help in other two. Please advice:
    The Hamiltonian of a spin $1/2$ in a magnetic field is given by [itex]\mathcal{H}=h(t)\cdot S[/itex], where the magnetic field is of the size [itex]|h(t)|=\Omega_0[/itex] and it is rotating on [itex]XY[/itex] plan with angular velocity [itex]\omega[/itex], so the angle it is forming with [itex]X[/itex] axis after time [itex]t[/itex] is [itex]\varphi = \omega t[/itex].
    In order to solve this question you may use the convention that the Hamiltonian of a spin in a rotating system is [itex]\tilde{\mathcal{H}}=\mathcal{H}-\omega S_z[/itex].
    (1) Find the angle of inflection [itex]\theta_0[/itex] in which you have to prepare the spin in order for it to follow in a constant angle after the rotating field.
    2. Relevant equations
    Convention given in the description
    3. The attempt at a solution
    Already solved:
    In the rotating system we can assume without any lost of generality that the magnetic field is always on the [itex]X[/itex] axis direction. Using this and the previous convention we get a new Hamiltonian: [itex]\mathcal{H}=\Omega_0 S_x-\omega S_z[/itex].
    We can consider this as a Hamiltonian of a system with an effective magnetic field [itex]\vec{B}=(\Omega_0,0,\omega)[/itex].
    If we want the magnetic field to stay constant in this system and not precssitate, we need to prepare it in that direction: [itex]\theta=\arctan\frac{\omega}{\Omega_0}[/itex]
    At time zero you prepare the spin in [itex]X[/itex] direction, and let the spin rotate half a circle.
    (2) What is the final direction of the spin in the limit [itex]\omega \to 0[/itex]?
    None
    Already solved:
    Using an educated guess, we can say that if the magnetic field is rotating "slowly enough", the spin will follow it and end the rotation in the same direction the field does: [itex]-\hat{x}[/itex].
    (3) What is the maximal angular error [itex]\Delta \theta[/itex] from the previous section if [itex]\omega[/itex] is finite?
    None
    Sorry, had no idea how to approach this.
    (4) Which values of [itex]\omega[/itex] give zero angular error?
    None
    Sorry, had no idea ho to solve this
    (5) What is the final direction of the spin in the limit [itex]\omega \to \infty[/itex]?
    None
    Already solved:
    Another educated guess: Now the field is rotating so fast so the spin won't have time to follow it and it will stay in its position: [itex]+\hat{x}[/itex].
