Spin up or spin down
  • Thread starter xXDEMAMAXx
xXDEMAMAXx
Hello,
I have read about Schrodinger's cat saying we do not know whether or not a particle has a spin up or spin down. It is only when we check it that we know which one it is.
I understand the concept however I do not understand what do scientists mean when they say "spin up/down".
What are 'spins'?
Answers and Replies
jtbell
Mentor
15,866
4,463
Spin is intrinsic angular momentum, the quantum-mechanical analog to the classical angular momentum of an object spinning around its own axis, like a spinning top or the Earth's daily rotation. Each elementary particle has a fixed amount (magnitude) of spin, which is a fundamental property of that particle, like its mass and electric charge.
There are only certain allowable values for the magnitude of spin, namely ##S = \sqrt {s(s+1)} \hbar## where ##s## can have either positive integer or half-integer values, or zero. Electrons have ##s = 1/2## so ##S = \sqrt{3/4} \hbar##. (beware the distinction between lower-case ##s## and upper-case ##S##)
Analogous to the way that we can orient a spinning top so its axis of rotation points in different directions, we can (loosely speaking) think of a particle's spin as being oriented in different directions. We describe this using the component of spin along a given reference direction which we customarily call the z-direction although it can actually be any direction we like. The z-component of spin is restricted to a set of values which depend on the magnitude of spin: ##S_z = m_s \hbar## where ##m_s## can have values from ##-s## to ##+s## in steps of 1. Electrons have ##s = 1/2## so they must have either ##m_s = -1/2## (##S_z = -\hbar/2##) or ##m_s = +1/2## (##S_z = +\hbar/2##). We call these two states "spin down" and "spin up".
Unlike a particle's spin magnitude ##S## which is fixed, we can change ##S_z## ("flip the spin") by various methods.
For further information see e.g. Wikipedia: https://en.wikipedia.org/wiki/Spin_(physics)
xXDEMAMAXx
Thank you so much for your help. I am now reading more about spins and quantum numbers. :)
Related Threads on Spin up or spin down
  • Last Post
  • Last Post
  • Last Post
28K
  • Last Post
