• Support PF! Buy your school textbooks, materials and every day products Here!
Spinning Disk - Angular Speed
  • Thread starter cstout
1. Homework Statement
A disk with a radial line painted on it is mounted on an axle perpendicular to it and running through its center. It is initially at rest, with the line at theta 0 = -90°. The disk then undergoes constant angular acceleration. After accelerating for 3.1 s, the reference line has been moved part way around the circle (in a counterclockwise direction) to theta f = 130°.
Given this information, what is the angular speed of the disk after it has traveled one complete revolution (when it returns to its original position at -90°)?
2. Homework Equations
w = lim(change in theda)/(change in time)
3. The Attempt at a Solution
change in theda is 140 degrees
change in time is 3.1 seconds
Answers and Replies
G01
This is a problem involving a constant angular acceleration and you need to use that information to solve this problem.
HINT:
Can you state the kinematic equations for rotational motion?
Related Threads for: Spinning Disk - Angular Speed
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
