pimpalicous
- 16
The other day, my professor mentioned projectiles have a force on them due to their spin. The example he gave is how a baseball curves because of the spin of a curve ball. What's the name of this force?
The force behind a curve ball is a combination of spin and the Magnus effect. The spin on the ball creates a difference in air pressure on each side, causing the ball to move in a curved path.
Spin causes the ball to experience a force known as the Magnus effect, which deflects the ball in the direction of the spin. This results in a curved trajectory instead of a straight path.
Yes, any object that is rotating as it moves through the air can experience the Magnus effect and have a curved trajectory. This includes baseballs, footballs, and even tennis balls.
The amount of curve on a curve ball is determined by the speed of the ball, the spin rate, the direction of the spin, and the density of the air. A higher spin rate and greater speed will result in more curve, while denser air will decrease the curve.
Yes, there are different techniques for throwing a curve ball, but all involve applying a spin to the ball with the fingers while releasing it. This can be achieved by using a two-finger grip, such as the "12-6" grip, or by snapping the wrist in a certain way while releasing the ball.
