Spinning slingshot
  1. Oct 17, 2016 #1
    A rock initially at rest in a sling of length r meters is
    brought to a speed of n rotations per second after three complete revolutions. It is then released , leaving the sling at an angle of θ above horizontal.
    When the rock is released, write the initial velocity and
    its horizontal and vertical components in terms of the variables provided above
    given equation: 1541ea407be0853d58465bed8abc9c82.png
    https://gyazo.com/1541ea407be0853d58465bed8abc9c82
    my question is isn't the Accel tan of whn the sling is release = Vi? if not, why and how can I get the Vi?
  3. Oct 17, 2016 #2
    gneill
    Staff: Mentor
    Hi Just_enough, Welcome to Physics Forums/
    Your question is not clear; please use complete words, not abbreviations. Can you restate it and show what you've already tried? What is your understanding of information that you are given in the problem statement?
  4. Oct 17, 2016 #3
    That all I was asked (mostly what Im confused on). I've upload the assignment as an attachment. but basically how do I find the initial velocity after the sling has been released? I think that the acceleration tangent of when the sling is spin is equal to the velocity initial after it's release is it not?
  5. Oct 18, 2016 #4
    haruspex
    An acceleration cannot equal a velocity. How is the angular velocity related to the linear velocity?
    By the way, the question is flawed. It asks for the average angular acceleration, suggesting that the acceleration is not constant, or need not be constant to answer the question. But you are given the initial and final angular velocities and the angle traversed, not the time taken. It is not possible to deduce the time taken or the average angular acceleration from that information. For example, the stone might be spun around slowly for 2.9 revolutions, then given a huge acceleration at the end. That would take longer than with a constant acceleration, yet satisfy all the given conditions.
    To solve the question it will be necessary to assume that the acceleration is constant.
  6. Oct 18, 2016 #5
    CWatters
    The problem statement actually asks a series of questions that you didn't mention or answer. Like many multi step problems it has been designed to lead you towards the final answer. If you haven't already done so I would work through them all one at a time.
  7. Oct 18, 2016 #6
    I don't know, Im dumb with it comes to physics
    So I should tell me professor to give us a time?
    I have (hopefully it's correct) but I dont see a connect those and this question
  8. Oct 18, 2016 #7
    haruspex
    No, since time is asked for. I suggest stating "assuming constant angular acceleration" and proceding on that basis. If the prof objects that the assumption is unnecessary, give her my proof that it is.
  9. Oct 18, 2016 #8
    lol sorry, I do not follow. should I start with that quote and say that the projectile could be spun slowly within 3 rev, that it's not possible to find the average acceleration without a given time it take for the projectile to spin 3 rev? also is this needed in order to find initial velocity of when the person release the projectile after spinning it?
  10. Oct 18, 2016 #9
    haruspex
    No, you can get that easily and directly from the information given.
    State that you are assuming constant angular acceleration, then solve the problem using that assumption. What equations do you know for constant acceleration?
    Later, if the prof claims that the assumption was not needed, use the slow starting spin wxample to prove that the assumption is neede.
  11. Oct 18, 2016 #10
    what? how? I'm sorry, but I'm really slow when it comes to physics. are you refering to using the V0y = V0sinθ equation?
  12. Oct 18, 2016 #11
    CWatters
    If you are familiar with the equations for linear motion under constant acceleration (eg SUVAT) then those for rotation under constant angular acceleration are similar. It might be worth spending time comparing the two sets of equations as they work in much the same ways.
  13. Oct 18, 2016 #12
    haruspex
    From my post #4:
Have something to add?
Draft saved Draft deleted
Similar Discussions: Spinning slingshot
  1. The slingshot effect (Replies: 1)
  2. Oscillating Slingshot (Replies: 11)
  3. Spacecraft Slingshot (Replies: 1)
  4. Slingshot Problem (Replies: 5)
  5. Gravitational slingshot (Replies: 22)
Loading...
