Spot the Mistake in Equation
  • Thread starter strokebow
  • Tags
    Mistake
In summary, the conversation is about a problem with equation [43] in a MATLAB function. The numerical answers in the pdf are correct, but the MATLAB function is not producing the same results. There are two possibilities for the discrepancy: a mistake in the function or a mistake/typo in equation [43]. The person is looking for help and suggestions to resolve the issue.
strokebow
123
Hi guys,
Please can someone look at this working (see attached).
The equation in question is [43]. It is highlighted with a red border.
The numerical answers in the pdf are correct and have been verified against published material.
That being said, I believe there must be a problem with equation [43] as I am not getting the same answers. I don't know how the algebra was simplified etc. to get to [43].
I have inputted [43] as it is in MATLAB and get incorrect results:
Code:
function [y] = inf_res_hex_odd(x,y,m,n)
y = ((1)/(4*(pi^2)))*((3-2*cos(y).*cos(m*x+n*y)-cos((m-1)*x+n*y))./(4-cos(y).*(cos(y)+cos(x))));
end
Example:
>> real((quad2d(@(x,y)inf_res_hex_odd(x,y,1,0),-pi,pi,-pi,pi)))
ans =
0.5422
There are 2 possibilities:
1) I made a mistake in my MATLAB function, or,
2) There is a mistake/typo in [43]
If anyone can offer any help with this I would be really appreciative.
Thanks
  • odd-hex.pdf
Mathematics news on Phys.org
No takers?
I've been staring at this bad boy for some time now... can't manage to find the problem.
any help/suggestions would be much appreciated... :-)
The material is too cryptic to respond to.
Don't expect people to look up MatLab syntax and command(s).
Type the equation in Latex so people can see it. What variables do you put in for x,y,m, and n? (I (and maybe others) don't know MatLab syntax/command(s) so don't know what the (x,y,1,0... -pi,pi,-pi,pi) stuff means, although it looks like ranges of evaluation)
In addition, your formatting was sloppy/lazy: there are more ))) on the one side of 1/4pi^2 than there are on the other. How is someone supposed to understand what you actually want?
Something like:
[tex]f(x,y,m,n)=\frac
{\frac {1} {4 \times \pi^2} \times \left ( 3-2 \times \cos{y} \right)
\times \cos \left( m \times x + n \times y \right ) - \cos \left ( \left (m-1 \right ) \times x + n \times y \right)}
{\left ( 4-\cos{y} \right ) \times \left (\cos{y} + \cos{x} \right ) } [/tex]
Hi there,
Thank you for bringing this to our attention. After reviewing the attached working and the equation in question [43], I believe there is a typo in the equation. The denominator should be (4-cos(y)*(cos(y)+cos(x))) instead of (4-cos(y)*(cos(y)+cos(x))). This small error could be causing the incorrect results in your MATLAB function.
I would recommend double checking the rest of your function and equations to ensure there are no other typos or mistakes. If the issue persists, it might be helpful to consult with a colleague or supervisor for a second opinion.
I hope this helps and good luck with your research.
1. What is "Spot the Mistake in Equation"?
"Spot the Mistake in Equation" is a game or activity that challenges individuals to identify and correct errors in mathematical equations.
2. Why is "Spot the Mistake in Equation" important?
"Spot the Mistake in Equation" is important because it helps improve critical thinking and problem-solving skills, as well as mathematical proficiency. It also promotes attention to detail and accuracy in mathematical calculations.
3. How do you play "Spot the Mistake in Equation"?
To play "Spot the Mistake in Equation", a set of equations with errors is presented and the player must identify and correct the mistakes. This can be done individually or in a group setting, and the player with the most correct answers wins.
4. What are the benefits of playing "Spot the Mistake in Equation"?
Aside from improving mathematical skills, playing "Spot the Mistake in Equation" can also enhance memory and focus, as well as develop perseverance and determination in solving problems.
5. Can "Spot the Mistake in Equation" be played for all levels of math?
Yes, "Spot the Mistake in Equation" can be adapted for different levels of math, from basic arithmetic to advanced calculus. It can also be tailored to cater to different age groups, making it a versatile and engaging activity for all.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
