1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Spring and two masses-help please!
  1. Nov 28, 2007 #1
    This is a practice exam for the actual exam I have tomorrow and I need help understanding this problem. :-) Thanks!
    You hold up an object that consists of two blocks at rest, each of mass M = 3 kg, connected by a low-mass spring. Then you suddenly start applying a larger upward force, of constant magnitude F = 88 N (which is greater than 2Mg). The diagram shows the situation some time later, when the blocks have moved upward, and the spring stretch has increased.
    [​IMG]
    The heights of the centers of the two blocks are as follows:
    y1i = 0.3 m, y1f = 0.4 m
    y2i = 0.8 m, y2f = 1.2 m
    It helps to show these heights on a diagram. Note that the initial center of mass of the two blocks is (y1i + y2i)/2, and the final center of mass of the two blocks is (y1f + y2f)/2.
    How don't know how to treat work in this problem to find Ktrans? (Because it says its greater that 2M?)
Draft saved Draft deleted
Similar Discussions: Spring and two masses-help please!
Loading...
