mmiller9913
- 14
. Block A has a mass m and block B has a mass 2m. Block A is pressed against a spring to compress the spring by a distance x. It is then released such that the block eventually separates from the spring and it slides across a surface where the friction coefficient is µk. The same process is applied to block B. Which one of the following statements concerning the distance that each block slides before stopping is correct?a) Block A slides one-fourth the distance that block B slides.
b) Block A slides one-half the distance that block B slides.
c) Block A slides the same distance that block B slides.
d) Block A slides twice the distance that block B slides.
e) Block A slides four times the distance that block B slides.
W= delta K
K= 1/2mv^2
Fx=-KX
W= -1/2Kx^2
I'm really not sure how to start. I'm not sure if both bocks start out with the same velocity? I'm guessing it's d just by making an educated guess. but is there a way to prove this?
