Homework Help: Spring compression help
  1. Sep 10, 2010 #1
    A 0.40kg object connected to a light spring with a force constant of 19.6N/m oscillates on a frictionless horizontal surface. If the spring is compressed 4.0 cm and released from rest, determine (a) the maximum speed of the object.
    2. Relevant equations
    F = -kx
    3. The attempt at a solution
    Does this involve kinetic energy?
  3. Sep 10, 2010 #2
    Re: Springs!!
    Yes, you need to use the conservation of mechanical energy principle.
  4. Sep 10, 2010 #3
    Re: Springs!!
    so KE + KEs = 0
    1/2mv^2 + 1/2kx^2 = 0
    solve for v?
  5. Sep 10, 2010 #4
    Re: Springs!!
    Close, but the spring has no kinetic energy only the attached mass. The spring can store what type of energy? Also set it up so its all the energy at state 1 equal to all the energy at state 2 (the point of interest).
  6. Sep 10, 2010 #5
    Re: Springs!!
    sorry not kinetic energy but potential energy.
  7. Sep 10, 2010 #6
    Re: Springs!!
    Yes so you should arrive at:
    PEs = KE
    which would give the same result as if you used the work kinetic energy theorm:
    Ws = KE2-KE1
    where Ws is the work done by the spring on the block and is equal to the integral of the spring force with respect to x or:
    Ws = integral of Fdx = (1/2)kx^2
  8. Sep 11, 2010 #7
    Re: Springs!!
    so 1/2mv^2 = 1/2kx^2
    v = square root (kx^2/m)
  9. Sep 11, 2010 #8
    Re: Springs!!
    correct.
  10. Sep 11, 2010 #9
    Re: Springs!!
    k. i got the answer, the max speed is 0.28m/s.
    The next part of the question is, for what value of x does the speed equal one-half the maximum speed.
    What i did was to solve for x with v = 1/2(max speed)
    I got the answer wrong.
    Can someone point out where i went wrong?
  11. Sep 11, 2010 #10
    Re: Springs!!
    Again use the conservation of energy. Is your energy at state 1 (the compressed state) any different from part a? Then what forms of energy are present at state 2?
  12. Sep 11, 2010 #11
    Re: Springs!!
    at state 2, is it half the compressed state?
  13. Sep 11, 2010 #12
    Re: Springs!!
    No, that distance x is the unknown you are asked to solve for. At state 1 the only energy is potential energy which you know. At state two you know the kinetic energy of the mass because you know v=vmax/2, but you don't know the potential energy of the spring=(1/2)kx^2...
  14. Sep 11, 2010 #13
    Re: Springs!!
    So in state 1 there is potential energy, no kinetic energy. State 2 there's kinetic energy, where v is half of the max speed and there's potential energy and that's when we solve for x.
  15. Sep 11, 2010 #14
    Re: Springs!!
    correct.
  16. Sep 11, 2010 #15
    Re: Springs!!
    Thanks for you help! =)
