Homework Help: Spring constant problem
  1. Aug 18, 2009 #1
    Two springs are set up on a table. The longer spring has a spring constant of 225 N/m and an initial length of 42.0 cm. The shorter spring has a spring constant of 675 N/m and an initial length of 28.0 cm. How far above the table is an 8.50-kg ball when it reaches its equilibrium position?
    2. Relevant equations
    f=-kx
    3. The attempt at a solution
    first change cm to m, then would i find the forces of each spring, add them up for find the total force, then use that and the 8.50 kg mass to find x?
  3. Aug 18, 2009 #2
    Re: Springs
    Yes, the springs combined must be equal to the gravitational force.
  4. Aug 18, 2009 #3
    Re: Springs
    how exactly do i use the force that i found to solve for x? because i dont know k
  5. Aug 18, 2009 #4
    Re: Springs
    k is the spring constant -- you have two springs and you know both their spring constants.
  6. Aug 18, 2009 #5
    Re: Springs
    o! so just add the two up.
  7. Aug 18, 2009 #6
    Re: Springs
    does this look right to you then?
    F=-kx
    F=(-225N/m x 0.42m)+(675N/m x 0.28m)
    F=-94.5 + -189N
    F= -283.5N
    X=f/-k
    X=-283.5N / -900N/m
    X= 0.315
Loading...
